<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[layer definition: here MMM-Globe overlaps left panel]]></title><description><![CDATA[<p dir="auto">I tested my Magic Mirror today with a rotated display and found, that the picture of my globe in MMM-Globe overlaps the left panel side. That is also, if I move the MMM-Globe in the config.sys to the top. The right panel side is nicely in the background and above the globe.<br />
Is there a way to show change the layer visibility?</p>
<p dir="auto"><img src="/uploads/files/1484175612902-2017-01-11-235604_1080x1920_scrot.png" alt="0_1484175611136_2017-01-11-235604_1080x1920_scrot.png" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/1393/layer-definition-here-mmm-globe-overlaps-left-panel</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 03:24:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1393.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Jan 2017 23:00:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Sun, 21 Nov 2021 09:24:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi everyone,<br />
if anyone has still trouble with it. I installed the MMM-Globe module and had the same issue. I declared all modules to foreground and just the globe one layer behind all. Keep an eye onto the z-index config. Worked fine for me.</p>
<p dir="auto">I use the globe module in config.js at the middle_center:</p>
<pre><code>module: 'MMM-Globe',
position: 'middle_center',
<p dir="auto">What I’ve declared in custom.css:</p>
<pre><code>.module {
z-index: 1;
width: 300px;
transform: scale(1.3);
padding-bottom: 15%;
.MMM-Globe {
z-index: 0;
width: 100%;
height: 100%;
position: absolute;
margin: auto;
padding-top: 120%;
opacity: 0.7;
<p dir="auto">Greets,<br />
Dee.</p>
]]></description><link>https://forum.magicmirror.builders/post/96616</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/96616</guid><dc:creator><![CDATA[DeeZett]]></dc:creator><pubDate>Sun, 21 Nov 2021 09:24:41 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Sat, 16 Sep 2017 13:53:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> nope :( does not work either</p>
]]></description><link>https://forum.magicmirror.builders/post/28145</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28145</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Sat, 16 Sep 2017 13:53:20 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Sat, 16 Sep 2017 12:37:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a> hmm… try to re-install the modul!</p>
]]></description><link>https://forum.magicmirror.builders/post/28144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28144</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Sat, 16 Sep 2017 12:37:15 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 15 Sep 2017 22:04:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> nope does not work for me… strange! i changed the location of the globe (lower third), without any success.</p>
]]></description><link>https://forum.magicmirror.builders/post/28133</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28133</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Fri, 15 Sep 2017 22:04:38 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 15 Sep 2017 13:41:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a> This is my Entry at the custom.css.</p>
<pre><code>.region.lower.third {
	z-index: 0;
	position: absolute;
<p dir="auto">Maybe you have to change the position in the custom.css like <code>.region.top.center</code>.</p>
]]></description><link>https://forum.magicmirror.builders/post/28122</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28122</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Fri, 15 Sep 2017 13:41:22 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 15 Sep 2017 13:23:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> yes</p>
]]></description><link>https://forum.magicmirror.builders/post/28121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28121</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Fri, 15 Sep 2017 13:23:22 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 15 Sep 2017 13:17:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a> Without this in your custom.css the Globe is working?</p>
]]></description><link>https://forum.magicmirror.builders/post/28120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28120</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Fri, 15 Sep 2017 13:17:13 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 15 Sep 2017 12:57:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a>  <a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a><br />
Hi guys! I crashed my sd card and now this :<br />
<code>.region.top.center { z-index: -2 position: absolute; }</code><br />
work anymore!?! If I c+p this in my custom.css the globe disappears!?</p>
]]></description><link>https://forum.magicmirror.builders/post/28119</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/28119</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Fri, 15 Sep 2017 12:57:27 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Sat, 04 Feb 2017 17:12:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a><br />
yes!! Thats it! I just have to change the region to lower.third…</p>
<p dir="auto">Thanks a lot!</p>
]]></description><link>https://forum.magicmirror.builders/post/13601</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13601</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Sat, 04 Feb 2017 17:12:16 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Sat, 04 Feb 2017 17:00:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a></p>
<p dir="auto">for me the following is working</p>
<pre><code>.region.top.center {
z-index: -2
position: absolute;
]]></description><link>https://forum.magicmirror.builders/post/13596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13596</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 04 Feb 2017 17:00:00 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Sat, 04 Feb 2017 16:48:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a></p>
<p dir="auto">nope… it’s not working for me…</p>
]]></description><link>https://forum.magicmirror.builders/post/13592</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13592</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Sat, 04 Feb 2017 16:48:12 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Sat, 04 Feb 2017 16:15:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> thats my custom.css:</p>
<pre><code>/*****************************************************
 * Magic Mirror                                      *
 * Custom CSS                                        *
 * By Michael Teeuw http://michaelteeuw.nl           *
 * MIT Licensed.                                     *
 * Add any custom CSS below.                         *
 * Changes to this files will be ignored by GIT. *
body {
  margin: 20px;
  position: absolute;
  height: calc(100% - 40px);
  width: calc(100% - 40px);
  background: #000;
  color: #aaa;
  font-family: "Roboto Condensed", sans-serif;
  font-weight: 400;
  font-size: 2em;
  line-height: 1.5em;
  -webkit-font-smoothing: antialiased;
.brightb {
color: #55acee;
.currentweather .wi-sunrise {
color: #ffd700;
.currentweather .wi-sunset {
color: #ffa500;
.currentweather .wi-day-sunny {
color: #ffff00;
.currentweather .wi-night-showers {
color: #55acee;
.currentweather .wi-degrees {
color: #415;
.currentweather .wi-rain {
color: #55acee;
.currentweather .wi-showers {
color: #55acee;
color: #55acee;
.currentweather .wi-night-alt-cloudy-windy {
color: #aaa;
.currentweather .wi-night-cloudy {
color: #aaa;
.currentweather .wi-cloudy {
color: #aaa;
.currentweather .wi-day-cloudy {
color: #aaa;
color: #aaa;
.currentweather .wi-cloudy-windy {
color: #aaa;
color: #55acee;
.currentweather .wi-thunderstorm {
color: #ff00ff;
.currentweather .wi-snow {
color: #fff;
.currentweather .wi-fog {
color: #999;
.currentweather .wi-night-clear {
color: #fff;
.currentweather .wi-night-rain {
color: #55acee;
.currentweather .wi-night-thunderstorm {
color: #ff00ff;
.currentweather .wi-night-snow {
color: #fff;
.weatherforecast .wi-sunrise {
color: #ffd700;
.weatherforecast .wi-sunset {
color: #ffa500;
.weatherforecast .wi-day-sunny {
color: #ffff00;
.weatherforecast .wi-night-showers {
color: #55acee;
.weatherforecast .wi-degrees {
color: #415;
.weatherforecast .wi-rain {
color: #55acee;
.weatherforecast .wi-showers {
color: #55acee;
color: #55acee;
.weatherforecast .wi-night-alt-cloudy-windy {
color: #aaa;
.weatherforecast .wi-night-cloudy {
color: #aaa;
.weatherforecast .wi-cloudy {
color: #aaa;
.weatherforecast .wi-day-cloudy {
color: #aaa;
color: #aaa;
.weatherforecast .wi-cloudy-windy {
color: #aaa;
color: #55acee;
.weatherforecast .wi-thunderstorm {
color: #ff00ff;
.weatherforecast .wi-snow {
color: #fff;
.weatherforecast .wi-fog {
color: #999;
.weatherforecast .wi-night-clear {
color: #fff;
.weatherforecast .wi-night-rain {
color: #55acee;
.weatherforecast .wi-night-thunderstorm {
color: #ff00ff;
color: #fff;
.region.fullscreen {
  position: absolute;
  top: -20px;
  left: -20px;
  right: -20px;
  bottom: -20px;
<p dir="auto">where should i put ?</p>
<pre><code> .MMM-Globe {
z-index: 2;
position: relative;
<p dir="auto">everywhere I tried it, it´s not working :see_no_evil:</p>
]]></description><link>https://forum.magicmirror.builders/post/13582</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13582</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Sat, 04 Feb 2017 16:15:28 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Sat, 04 Feb 2017 16:06:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/schlachtkreuzer6" aria-label="Profile: schlachtkreuzer6">@<bdi>schlachtkreuzer6</bdi></a></p>
<p dir="auto">can you test</p>
<pre><code>.MMM-Globe {
z-index: 2;
position: relative;
<p dir="auto">if this is not working i will download the module and debug it myself</p>
]]></description><link>https://forum.magicmirror.builders/post/13581</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13581</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sat, 04 Feb 2017 16:06:01 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Sat, 04 Feb 2017 15:59:09 GMT]]></title><description><![CDATA[<p dir="auto">not working for me too</p>
]]></description><link>https://forum.magicmirror.builders/post/13579</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13579</guid><dc:creator><![CDATA[schlachtkreuzer6]]></dc:creator><pubDate>Sat, 04 Feb 2017 15:59:09 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 03 Feb 2017 19:10:52 GMT]]></title><description><![CDATA[<p dir="auto">no, it is not working… I try -1, also -20 and -50</p>
]]></description><link>https://forum.magicmirror.builders/post/13466</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13466</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Fri, 03 Feb 2017 19:10:52 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 03 Feb 2017 18:55:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> when you set it to two it will be above all, you have to set a lower value than the other have like -1</p>
]]></description><link>https://forum.magicmirror.builders/post/13462</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13462</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Fri, 03 Feb 2017 18:55:30 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 03 Feb 2017 18:51:52 GMT]]></title><description><![CDATA[<p dir="auto">Like:</p>
 * Magic Mirror                                      *
 * Custom CSS                                        *
 * MIT Licensed.                                     *
 body {
.compliments .xlarge {
    font-size: 40px;
    line-height: 40px;
    letter-spacing: 0px;
    font-weight: 400;
.calendar {
	width: 100%;
	font-size: 15px;
.MMM-FRITZ-Box-Callmonitor {
	width: 90%
.currentweather {
	width: 100%
.weatherforecast {
	width: 100%
.MMM-DWD-WarnWeather {
	width: 100%
.MMM-Globe {
z-index: 2;
]]></description><link>https://forum.magicmirror.builders/post/13460</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13460</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Fri, 03 Feb 2017 18:51:52 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 03 Feb 2017 18:46:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> how does your custom.css look like</p>
]]></description><link>https://forum.magicmirror.builders/post/13459</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13459</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Fri, 03 Feb 2017 18:46:57 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 03 Feb 2017 18:43:43 GMT]]></title><description><![CDATA[<p dir="auto">I did, but it’s not working… :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/13458</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13458</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Fri, 03 Feb 2017 18:43:43 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 03 Feb 2017 18:41:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/niggich" aria-label="Profile: Niggich">@<bdi>Niggich</bdi></a> <code>~/MagicMirror/css/custom.css</code></p>
]]></description><link>https://forum.magicmirror.builders/post/13457</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13457</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Fri, 03 Feb 2017 18:41:17 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Fri, 03 Feb 2017 18:38:09 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I’m sorry, but where I have to change the Settings to arrange the layers?</p>
]]></description><link>https://forum.magicmirror.builders/post/13456</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13456</guid><dc:creator><![CDATA[Niggich]]></dc:creator><pubDate>Fri, 03 Feb 2017 18:38:09 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Thu, 12 Jan 2017 07:00:17 GMT]]></title><description><![CDATA[<p dir="auto">thanks! Works like a charm now!</p>
]]></description><link>https://forum.magicmirror.builders/post/10908</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10908</guid><dc:creator><![CDATA[binderth]]></dc:creator><pubDate>Thu, 12 Jan 2017 07:00:17 GMT</pubDate></item><item><title><![CDATA[Reply to layer definition: here MMM-Globe overlaps left panel on Thu, 12 Jan 2017 06:55:01 GMT]]></title><description><![CDATA[<p dir="auto">Yes, using z-index on the modules you can arrange the layers.</p>
<p dir="auto">Like</p>
z-index: 2;
<p dir="auto">Will put the globe module above everyother module, you can also apply this to regions.</p>
]]></description><link>https://forum.magicmirror.builders/post/10907</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/10907</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Thu, 12 Jan 2017 06:55:01 GMT</pubDate></item></channel></rss>
