<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update v2.13.0 Black Screen]]></title><description><![CDATA[<p dir="auto">hello,<br />
I updated MagicMirror. After that, the screen was black.<br />
The Log is:</p>
<p dir="auto">/home/pi/.pm2/logs/mm-error.log last 15 lines:<br />
1|mm       |<br />
1|mm       | npm ERR! A complete log of this run can be found in:<br />
1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-11-06T17_59_29_121Z-debug.log<br />
1|mm       |<br />
1|mm       | (electron:973): Gtk-WARNING **: 18:59:30.649: cannot open display: :10.0<br />
1|mm       | npm ERR! code ELIFECYCLE<br />
1|mm       | npm ERR! errno 1<br />
1|mm       | npm ERR! magicmirror@2.13.0 start: <code>DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js</code><br />
1|mm       | npm ERR! Exit status 1<br />
1|mm       | npm ERR!<br />
1|mm       | npm ERR! Failed at the magicmirror@2.13.0 start script.<br />
1|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.<br />
1|mm       |<br />
1|mm       | npm ERR!     /home/pi/.npm/_logs/2020-11-06T17_59_30_692Z-debug.log</p>
]]></description><link>https://forum.magicmirror.builders/topic/13987/update-v2-13-0-black-screen</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 05:08:33 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/13987.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Nov 2020 18:43:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update v2.13.0 Black Screen on Tue, 10 Nov 2020 10:00:42 GMT]]></title><description><![CDATA[<p dir="auto">:grinning_face: :thumbs_up:<br />
Many thanks.<br />
I’m so happy</p>
]]></description><link>https://forum.magicmirror.builders/post/84468</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84468</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Tue, 10 Nov 2020 10:00:42 GMT</pubDate></item><item><title><![CDATA[Reply to Update v2.13.0 Black Screen on Sat, 07 Nov 2020 19:29:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a> ok, see the instructions for fix at the top.of the troubleshooting section</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix">https://forum.magicmirror.builders/topic/13774/2-13-back-screen-translation-file-error-fix</a></p>
]]></description><link>https://forum.magicmirror.builders/post/84393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84393</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Nov 2020 19:29:08 GMT</pubDate></item><item><title><![CDATA[Reply to Update v2.13.0 Black Screen on Sat, 07 Nov 2020 18:56:18 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1604775374409-24d071d2-a67b-431e-9c89-ea831d1fac89-grafik.png" alt="24d071d2-a67b-431e-9c89-ea831d1fac89-grafik.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/84392</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84392</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Sat, 07 Nov 2020 18:56:18 GMT</pubDate></item><item><title><![CDATA[Reply to Update v2.13.0 Black Screen on Sat, 07 Nov 2020 17:55:23 GMT]]></title><description><![CDATA[<p dir="auto">hello<br />
yes, I have git pull &amp;&amp; npm install.</p>
<p dir="auto">the red text is:</p>
<pre><code>0.0.0.0/:5 Uncaught SyntaxError: Unexpected token / in JSON at position 79
    at JSON.parse (&lt;anonymous&gt;)
    at XMLHttpRequest.xhr.onreadystatechange (translator.js:22)
]]></description><link>https://forum.magicmirror.builders/post/84388</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84388</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Sat, 07 Nov 2020 17:55:23 GMT</pubDate></item><item><title><![CDATA[Reply to Update v2.13.0 Black Screen on Sat, 07 Nov 2020 13:55:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a> ok. did u do<br />
npm install<br />
after the update?</p>
<p dir="auto">there were new dependencies</p>
<p dir="auto">also open the developers window, ctrl-shift-i, then select the tab labeled console, and scroll up to see any errors, usually red text</p>
]]></description><link>https://forum.magicmirror.builders/post/84385</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84385</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Nov 2020 13:55:51 GMT</pubDate></item><item><title><![CDATA[Reply to Update v2.13.0 Black Screen on Sat, 07 Nov 2020 13:26:13 GMT]]></title><description><![CDATA[<p dir="auto">OK.<br />
I changed <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> .<br />
The error message “cannot open display: :10.0” is gone.<br />
The screen is still black!</p>
<pre><code>
1|mm       | [2020-11-07 14:19:38.615] [LOG]    Connecting socket for: MMM-Sonos
1|mm       | [2020-11-07 14:19:38.616] [LOG]    Sonos helper started ...
1|mm       | [2020-11-07 14:19:38.616] [LOG]    Connecting socket for: MMM-DarkSkyForecast
1|mm       | [2020-11-07 14:19:38.616] [LOG]    ====================== Starting node_helper for module [MMM-DarkSkyForecast]
1|mm       | [2020-11-07 14:19:38.617] [LOG]    Connecting socket for: MMM-FRITZ-Box-Callmonitor
1|mm       | [2020-11-07 14:19:38.617] [LOG]    Starting module: MMM-FRITZ-Box-Callmonitor
1|mm       | [2020-11-07 14:19:38.618] [LOG]    Connecting socket for: calendar
1|mm       | [2020-11-07 14:19:38.618] [LOG]    Starting node helper for: calendar
1|mm       | [2020-11-07 14:19:38.619] [LOG]    Connecting socket for: MMM-iCloud-Client
1|mm       | [2020-11-07 14:19:38.620] [LOG]    Starting helper: MMM-iCloud-Client
1|mm       | [2020-11-07 14:19:38.620] [LOG]    loading Database
1|mm       | [2020-11-07 14:19:38.621] [LOG]    Connecting socket for: newsfeed
1|mm       | [2020-11-07 14:19:38.622] [LOG]    Starting node helper for: newsfeed
1|mm       | [2020-11-07 14:19:38.622] [LOG]    Sockets connected &amp; modules started ...
1|mm       | [2020-11-07 14:19:38.712] [LOG]    Launching application.
]]></description><link>https://forum.magicmirror.builders/post/84384</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84384</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Sat, 07 Nov 2020 13:26:13 GMT</pubDate></item><item><title><![CDATA[Reply to Update v2.13.0 Black Screen on Sat, 07 Nov 2020 12:43:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a><br />
cannot open display: :10.0</p>
<p dir="auto">that makes no sense</p>
<p dir="auto">can u change package.json to day DISPLAY:0.0</p>
<p dir="auto">mm is trying to run on the display attached to the pi</p>
]]></description><link>https://forum.magicmirror.builders/post/84383</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84383</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Nov 2020 12:43:53 GMT</pubDate></item><item><title><![CDATA[Reply to Update v2.13.0 Black Screen on Sat, 07 Nov 2020 12:06:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/84355">Update v2.13.0 Black Screen</a>:</p>
<p dir="auto">to.losd</p>
<p dir="auto">Yes!</p>
]]></description><link>https://forum.magicmirror.builders/post/84382</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84382</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Sat, 07 Nov 2020 12:06:14 GMT</pubDate></item><item><title><![CDATA[Reply to Update v2.13.0 Black Screen on Sat, 07 Nov 2020 12:41:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a> u have to.load the graphical.os version right?</p>
]]></description><link>https://forum.magicmirror.builders/post/84355</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84355</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Nov 2020 12:41:00 GMT</pubDate></item></channel></rss>
