<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New LCD Controller Board for Tv]]></title><description><![CDATA[<p dir="auto">Hello, this is my first Magic Mirror and I’m struggling with the hardware. I bought a used TV with a LG LC220WXE TBA1 screen.<br />
Now I want to buy a new controller board but don’t know which one to chose and how to power it. I’m a total newbie so please help me out!</p>
]]></description><link>https://forum.magicmirror.builders/topic/14014/new-lcd-controller-board-for-tv</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 13:55:30 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14014.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Nov 2020 16:53:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Tue, 26 Jan 2021 15:51:08 GMT]]></title><description><![CDATA[<p dir="auto">At this point it’s really hard to troubleshoot from the distance.<br />
Of course it’s possible that either the board or the panel is broken. I suppose the menu isn’t displaying either?</p>
<p dir="auto">Have you made sure you loaded the correct firmware onto the board? You should be able to try any firmware which fits your resolution plus 1-ch 8-bit (iirc, check yourself please).</p>
]]></description><link>https://forum.magicmirror.builders/post/87836</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87836</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Tue, 26 Jan 2021 15:51:08 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Tue, 26 Jan 2021 07:19:05 GMT]]></title><description><![CDATA[<p dir="auto">Yes it is. I can see white lights coming out from the back of the display.</p>
]]></description><link>https://forum.magicmirror.builders/post/87823</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87823</guid><dc:creator><![CDATA[habedehab]]></dc:creator><pubDate>Tue, 26 Jan 2021 07:19:05 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Sat, 23 Jan 2021 16:27:09 GMT]]></title><description><![CDATA[<p dir="auto">Is the backlight powered?</p>
]]></description><link>https://forum.magicmirror.builders/post/87687</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87687</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Sat, 23 Jan 2021 16:27:09 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Thu, 21 Jan 2021 14:42:59 GMT]]></title><description><![CDATA[<p dir="auto">So…I got the right LCD Cable for my screen, i connected it to my controller board. After I turn it on i dont get the white screen anymore, but now its black. The board reacts to the remote (changes color when i press a button) but i cant find a way to get a picture on screen. I already tried the hdmi and vga port, but had no success.</p>
<p dir="auto">Did I miss something? Or is the board i bought broken?</p>
]]></description><link>https://forum.magicmirror.builders/post/87616</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87616</guid><dc:creator><![CDATA[habedehab]]></dc:creator><pubDate>Thu, 21 Jan 2021 14:42:59 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Wed, 02 Dec 2020 18:41:30 GMT]]></title><description><![CDATA[<p dir="auto">Should have mentioned that not all Vcc or GND pins are always populated. It’s just important that in the position of Vcc or GND there is no white or blue cable and vice versa.<br />
Have a look <a href="https://www.aliexpress.com/item/32806276869.html?aff_platform=link-c-tool&amp;sk=6YaRvLi&amp;aff_trace_key=51fc662355994361b20ba7439ff3bacc-1606934032017-00827-6YaRvLi&amp;terminal_id=b7e407b8a2bb45468c2b51c2baf583de&amp;tmLog=new_Detail" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>. The second pic in the description looks like it fits your LCD. The Vcc is where it should be, but only 3 instead of 5 pins are used. Same with the GND. Just not all GND pins are used (7. 10. 13, and 19 are not used, the rest is where they should be).</p>
<p dir="auto">You can also the correct cable yourself. Just change the pin order the way you need. (Don’t forget to do that on both ends of the cable).</p>
]]></description><link>https://forum.magicmirror.builders/post/85372</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85372</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Wed, 02 Dec 2020 18:41:30 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Wed, 02 Dec 2020 12:23:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: MadScientist">@<bdi>MadScientist</bdi></a> …I can’t find one where the cable matches. Either the power cables are on the left side and not like my panel, or the GND Cables are not matching at all…how to I proceed now?<br />
<img src="/assets/uploads/files/1606911790480-screenshot_20201202-132226.jpg" alt="Screenshot_20201202-132226.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/85366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85366</guid><dc:creator><![CDATA[habedehab]]></dc:creator><pubDate>Wed, 02 Dec 2020 12:23:17 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Sun, 29 Nov 2020 11:12:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/habedehab" aria-label="Profile: habedehab">@<bdi>habedehab</bdi></a> I am pretty sure it’s the LVDS cable. The product description says it’s 1-ch 6-bit but your screen is 8bit. IIRC they are not compatible. The pinout for the Vcc and GND are different! Get a proper cable and try again. 2-ch 8-bit cables should work too but check the position of the black GND wires beforehand. Google your LCD panel name + datasheet to make sure they are correct.</p>
]]></description><link>https://forum.magicmirror.builders/post/85273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85273</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Sun, 29 Nov 2020 11:12:29 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Sat, 28 Nov 2020 17:37:57 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: MadScientist">@<bdi>MadScientist</bdi></a>,<br />
I bought this Controller board</p>
<p dir="auto"><a href="https://m.banggood.com/de/T_SK106A_03-Universal-LCD-LED-TV-Controller-Driver-Board-+7-Key-button+1ch-6bit-30Pins-LVDS-Cable+1-Lamp-Inverter+Speaker+EU-Power-Adapter-p-1401877.html?akmClientCountry=DE&amp;rmmds=search&amp;act_poa=SKUA72427&amp;cur_warehouse=CN" target="_blank" rel="noopener noreferrer nofollow ugc">https://m.banggood.com/de/T_SK106A_03-Universal-LCD-LED-TV-Controller-Driver-Board-+7-Key-button+1ch-6bit-30Pins-LVDS-Cable+1-Lamp-Inverter+Speaker+EU-Power-Adapter-p-1401877.html?akmClientCountry=DE&amp;rmmds=search&amp;act_poa=SKUA72427&amp;cur_warehouse=CN</a></p>
<p dir="auto">cause it looked like a good kit to install my monitor.<br />
Then I realized that I need a different inverter so I ordered this on too:</p>
<p dir="auto"><a href="https://m.banggood.com/de/4-Lamp-Universal-CCFL-Inverter-10V-30V-Output-For-15-24-inch-LCD-Display-Monitor-With-4-Cords-p-1497719.html?akmClientCountry=DE&amp;rmmds=orderdetail" target="_blank" rel="noopener noreferrer nofollow ugc">https://m.banggood.com/de/4-Lamp-Universal-CCFL-Inverter-10V-30V-Output-For-15-24-inch-LCD-Display-Monitor-With-4-Cords-p-1497719.html?akmClientCountry=DE&amp;rmmds=orderdetail</a></p>
<p dir="auto">Now after installing the firmware and flashing it on the board and connecting all the cables, my screen just turns white. I have to mention that the firmware installing process didn’t go like in the description. My led turned on red and after a couple of seconds it turned off. After a couple of minutes I turned it off and on again an then it went from red to blue.<br />
Can you or anybody else help me with my white screen? Is it because of the firmware or do need to get a different LVDS cable? I can do pictures if needed</p>
]]></description><link>https://forum.magicmirror.builders/post/85247</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85247</guid><dc:creator><![CDATA[habedehab]]></dc:creator><pubDate>Sat, 28 Nov 2020 17:37:57 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Wed, 18 Nov 2020 12:38:58 GMT]]></title><description><![CDATA[<p dir="auto">You can buy the LVDS cables for cheap. Sometimes they already come in a set with the controller board. AFAIK you can use a 2Ch-8bit cable on a 1-Ch-(bit LCD but you should check the pinout of the LCD beforehand. I am not 100% sure though. You can look for the position of the GND and Vcc pins to varify.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lindataylor11" aria-label="Profile: lindataylor11">@<bdi>lindataylor11</bdi></a> I have seen your post but didn’t reply because you left us in the dark about what you want to do exactly (PIR or not, relay ok or not ok, does money play a big role etc…).</p>
]]></description><link>https://forum.magicmirror.builders/post/84810</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84810</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Wed, 18 Nov 2020 12:38:58 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Mon, 16 Nov 2020 19:31:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/madscientist" aria-label="Profile: MadScientist">@<bdi>MadScientist</bdi></a> thank you for the answer, that’s was very helpful. I tried to find a LCD board with a p two connection (that’s the cable from my monitor). Do I need to get some kind of adapter or how can I connect a P-two cable into a LVDS Board? :(</p>
]]></description><link>https://forum.magicmirror.builders/post/84756</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84756</guid><dc:creator><![CDATA[habedehab]]></dc:creator><pubDate>Mon, 16 Nov 2020 19:31:35 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Fri, 13 Nov 2020 17:30:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys!! I am new to this forum. I am also facing similar situation and cannot decide which controller board to use.</p>
]]></description><link>https://forum.magicmirror.builders/post/84578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84578</guid><dc:creator><![CDATA[lindataylor11]]></dc:creator><pubDate>Fri, 13 Nov 2020 17:30:22 GMT</pubDate></item><item><title><![CDATA[Reply to New LCD Controller Board for Tv on Wed, 18 Nov 2020 12:40:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/habedehab" aria-label="Profile: habedehab">@<bdi>habedehab</bdi></a> said in <a href="/post/84499">New LCD Controller Board for Tv</a>:</p>
<p dir="auto">LG LC220WXE TBA1</p>
<p dir="auto">According to the datasheet it’s a simple LVDS LVD. 1-channel, 8-bit with a resolution of 1366x768 pixels.<br />
You can basically use any universal LCD controller board. I use a V56 or a V53 LCD controller board. You can flash its firmware via a USB flash drive. However, if you’re planning on using a PIR-sensor then you’ll also have to add a relay because it won’t go into standby mode. Instead it will complain about “No Signal”.</p>
<p dir="auto">One like <a href="https://www.aliexpress.com/item/32885922700.html?spm=a2g0o.productlist.0.0.955628acW3l6JX&amp;algo_pvid=226b2f34-7126-4008-a9f3-728b6742b7c4&amp;algo_expid=226b2f34-7126-4008-a9f3-728b6742b7c4-15&amp;btsid=2100bdd516051935128812849eaf52&amp;ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_" target="_blank" rel="noopener noreferrer nofollow ugc">this</a> is very cheap and can be configured by a set of jumpers. Drawback is it only has a VGA port. So you’ll need an additional VGA-to-HDMI-adapter. However, the cheapest will do.</p>
<p dir="auto">You’ll also need an inverter for your LCD backlight. You need one with 4 connections.</p>
<p dir="auto">Have a read <a href="https://sites.google.com/site/lcd4hobby/home" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>. This site has all the information you’ll need.</p>
<p dir="auto">Don’t be shy to ask if you have more questions. I might not be able to answer them all but I’ll try my best to help.</p>
]]></description><link>https://forum.magicmirror.builders/post/84529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84529</guid><dc:creator><![CDATA[MadScientist]]></dc:creator><pubDate>Wed, 18 Nov 2020 12:40:53 GMT</pubDate></item></channel></rss>
