<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-ProfileSwitcher, A Profile/User/Layout Switching Module]]></title><description><![CDATA[<p dir="auto"><a href="https://github.com/tosti007/MMM-ProfileSwitcher" target="_blank" rel="noopener noreferrer nofollow ugc">This Module</a> adds the ability to have different layouts for different profiles. I noticed that other were looking for it aswell and might not want to have Paviro’s <a href="https://github.com/paviro/MMM-Facial-Recognition" target="_blank" rel="noopener noreferrer nofollow ugc">Facial Recognition Module</a> with it.<br />
This module uses the configured module’s classes and hides/shows them according to the current active profile.</p>
<h4>Features</h4>
<ul>
<li>Set any number of modules per profile</li>
<li>Use module name as profile</li>
<li>Configure multiple profiles</li>
<li>Set module for every profile</li>
<li>Set multiple custom messages for each profile (randomly chosen)</li>
</ul>
<p dir="auto">You can find it <a href="https://github.com/tosti007/MMM-ProfileSwitcher" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>.<br />
[card:tosti007/MMM-ProfileSwitcher]</p>
<hr />
<h3>Version 1</h3>
<ul>
<li>First version and implementation</li>
<li>Bug fixes and minor changes</li>
<li>Added random chosen message</li>
</ul>
<hr />
<h3>Version 2</h3>
<ul>
<li>Added configurable timers!</li>
<li>Add the use of lockstrings (thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/jopyth" aria-label="Profile: Jopyth">@<bdi>Jopyth</bdi></a>)</li>
<li>Support older browsers</li>
<li>Added Spanish translations (thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/roramirez" aria-label="Profile: roramirez">@<bdi>roramirez</bdi></a>)</li>
</ul>
<hr />
<h3>Version 2.1</h3>
<ul>
<li>Added possibility to set a timer on the default class</li>
<li>Added French translation (thanks to <a class="plugin-mentions-user plugin-mentions-a" href="/user/patriceg" aria-label="Profile: PatriceG">@<bdi>PatriceG</bdi></a>)</li>
</ul>
<hr />
<p dir="auto">If you have any questions or requests for future features, don’t hesitate to ask!<br />
<strong>Note:</strong> If you use this module in combination with Paviro’s <a href="https://github.com/paviro/MMM-Facial-Recognition" target="_blank" rel="noopener noreferrer nofollow ugc">Facial Recognition Module</a> and you update his then don’t forget to update this module and read the line numbers again.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1402/mmm-profileswitcher-a-profile-user-layout-switching-module</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 13:08:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1402.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Jan 2017 14:21:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Fri, 24 Feb 2023 21:33:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/3squaremirror" aria-label="Profile: 3squaremirror">@<bdi>3squaremirror</bdi></a> some code needs to use the force parameter on the show() or hide()  functions.</p>
<p dir="auto">but I can’t tell from the log which code issued the show/hide. only that the profileswitcher had it locked</p>
]]></description><link>https://forum.magicmirror.builders/post/108027</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108027</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 24 Feb 2023 21:33:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Fri, 24 Feb 2023 19:23:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> thank you, i think you’re right. i read about forcing a module to unhide the lockstring. not sure how to get that done.</p>
]]></description><link>https://forum.magicmirror.builders/post/108023</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108023</guid><dc:creator><![CDATA[3squaremirror]]></dc:creator><pubDate>Fri, 24 Feb 2023 19:23:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Fri, 24 Feb 2023 15:10:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/3squaremirror" aria-label="Profile: 3squaremirror">@<bdi>3squaremirror</bdi></a><br />
I think the problem is the pages module. It uses lockstrings as well and may block the module of being shown.<br />
Tried combining pages and profiles a view years ago and had very similar problems.</p>
<p dir="auto">But you can ralize all you can do with  <a href="https://github.com/edward-shen/MMM-pages" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-pages</a> and <a href="https://github.com/edward-shen/MMM-page-indicator" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-page-indicator</a> with <a href="https://github.com/tosti007/MMM-ProfileSwitcher" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-ProfileSwitcher</a> and <a href="https://github.com/Tom-Hirschberger/MMM-ProfileControl" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-ProfileControl</a>. So there is no need to mix Pages and Profiles.</p>
]]></description><link>https://forum.magicmirror.builders/post/108019</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108019</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Fri, 24 Feb 2023 15:10:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Fri, 24 Feb 2023 08:24:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wishmaster270" aria-label="Profile: wishmaster270">@<bdi>wishmaster270</bdi></a> i also use the Touch and Pages module.</p>
]]></description><link>https://forum.magicmirror.builders/post/108017</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108017</guid><dc:creator><![CDATA[3squaremirror]]></dc:creator><pubDate>Fri, 24 Feb 2023 08:24:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Fri, 24 Feb 2023 07:24:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/3squaremirror" aria-label="Profile: 3squaremirror">@<bdi>3squaremirror</bdi></a><br />
Do you use any other modules which may hide/show modules?<br />
If i copy your configuration to my test environment and add some notifications (change day/night every minute) everything works as expected.</p>
]]></description><link>https://forum.magicmirror.builders/post/108015</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108015</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Fri, 24 Feb 2023 07:24:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Thu, 23 Feb 2023 19:59:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/3squaremirror" aria-label="Profile: 3squaremirror">@<bdi>3squaremirror</bdi></a> sorry, no idea.  was just a thought. know nothing about the module</p>
]]></description><link>https://forum.magicmirror.builders/post/108010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108010</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Feb 2023 19:59:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Thu, 23 Feb 2023 19:30:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> my apology about the double posting, it’s noted. i am not clear on how to force profile switcher to switch. can you elaborate that?</p>
]]></description><link>https://forum.magicmirror.builders/post/108009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108009</guid><dc:creator><![CDATA[3squaremirror]]></dc:creator><pubDate>Thu, 23 Feb 2023 19:30:21 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Thu, 23 Feb 2023 19:23:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/3squaremirror" aria-label="Profile: 3squaremirror">@<bdi>3squaremirror</bdi></a> yes. profileswitcher says it’s in charge of hiding and showing modules (via lockstring)</p>
<p dir="auto">so. can u force profile switcher to switch to that users profile?</p>
]]></description><link>https://forum.magicmirror.builders/post/108007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108007</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Feb 2023 19:23:23 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Thu, 23 Feb 2023 19:08:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/3squaremirror" aria-label="Profile: 3squaremirror">@<bdi>3squaremirror</bdi></a> don’t know, but please don’t double post.</p>
<p dir="auto">members with reputation below 2 have every post reviewed.</p>
<p dir="auto">this stops the unrelated spam we get every day (6 this morning).</p>
]]></description><link>https://forum.magicmirror.builders/post/108006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108006</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Feb 2023 19:08:49 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Thu, 23 Feb 2023 18:43:10 GMT]]></title><description><![CDATA[<p dir="auto">having issue showing MMM-Profilepicture using MMM-ModuleScheduler and MMM-ProfileSwitcher.</p>
<p dir="auto">I’m trying to switch a day and night time image with profilepicture. Using modulescheduler to switch the image based on the time.</p>
<p dir="auto">As far as I can tell, each module is running correctly, as I’m not seeing any error in the console log.</p>
<p dir="auto">i think the issue has to do with LockStrings, and i don’t know how to fix it</p>
<pre><code>Will not show MMM-Profilepicture. LockStrings active: module_2_MMM-ProfileSwitcher
<p dir="auto">my configs</p>
<pre><code>//////////////////// profile ///////////////////////////
            module: 'MMM-ProfileSwitcher',
            disabled: false,
            classes: 'default everyone',
                    defaultClass: 'default',
                    everyoneClass: 'everyone',
        module: 'MMM-ModuleScheduler',
        disabled: false,
            notification_schedule: [
                // SWITCH TO THE DAY PROFILE AT 07:30 EVERY DAY
                {notification: 'CURRENT_PROFILE', schedule: '30 7 * * *', payload: 'day'},
                // SWITCH TO THE NIGHT PROFILE AT 23:30 EVERY DAY
                {notification: 'CURRENT_PROFILE', schedule: '30 18 * * *', payload: 'night'},
            module: "MMM-Profilepicture",
            position: "fullscreen_below",
            classes: "day",
            disabled: false,
                url: "https://images.unsplash.com/photo-1623150502742-6a849aa94be4?ixlib=rb-4.0.3&amp;ixid=MnwxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8&amp;auto=format&amp;fit=crop&amp;w=1980&amp;q=80",
                opacity: 1,
                maxWidth: "120%",
                maxHeight: "120%",
            classes: "night",
            disabled: false,
                url: "https://images.unsplash.com/photo-1620121692029-d088224ddc74?ixlib=rb-4.0.3&amp;ixid=MnwxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8&amp;auto=format&amp;fit=crop&amp;w=1980&amp;q=80",
                opacity: 1,
                maxWidth: "140%",
                maxHeight: "140%",
    ////////////////end profile //////////////////////////
]]></description><link>https://forum.magicmirror.builders/post/108005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108005</guid><dc:creator><![CDATA[3squaremirror]]></dc:creator><pubDate>Thu, 23 Feb 2023 18:43:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Tue, 09 Oct 2018 00:29:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyberdyne" aria-label="Profile: cyberdyne">@<bdi>cyberdyne</bdi></a> I had the same idea two days ago and did some research on it. I also asked /r/smartmirrors for some advice on it and got pretty good tips. The bottom line is, if you want to have a solid, non hacky solution supporting both iOS/android go the other way round with the use of beacons.</p>
<p dir="auto">Thread is <a href="https://www.reddit.com/r/smartmirrors/comments/9m82ny/multi_user_profiles_through_bluetooth_proximity" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
]]></description><link>https://forum.magicmirror.builders/post/45158</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45158</guid><dc:creator><![CDATA[fcornelius]]></dc:creator><pubDate>Tue, 09 Oct 2018 00:29:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Mon, 08 Oct 2018 08:47:03 GMT]]></title><description><![CDATA[<p dir="auto">Is it possible to include a BT detection to switch profiles? RPi3 has a build BT which is not used (at least in my configuration) by the MagicMirror. It would be great if personal stuff like the calender could be switched depending on the BT device (Smartphone, Smartwatch, Fitnesstracker, …) which is near by.</p>
<p dir="auto">I was searching for identification via BT on the RPi and this is what I have found so far:</p>
<p dir="auto">“…present/absent can be done with very little power consumption on rPi and iPhone. Install bluetooth dongle on rPi as: (sudo aptitude install bluetooth bluez-utils bluez-compat). Figure out mac of your phone device by making it searchable and then do (hcitool scan) on rPi. Then connect to your device (make sure its searchable) as: sudo bluez-simple-agent hci0 mac_of_your_device and say yes on both sides. Then sudo bluez-test-device trusted mac_of_your_device. Now they both “know” each other. Then do sudo hcitool name mac_of_your_device in your favourite script to figure out if the iphone is nearby. This will not create a connection - but just say hi to it. If it returns a name, phone is nearby. If it returns nothing - phone is not nearby or bluetooth is switched off. Compared to creating connections or other distance computation methods out there - this method conserves battery on both sides and keeps airwave pollution to a minimum.” (found <a href="https://raspberrypi.stackexchange.com/questions/15454/detect-if-iphone-android-nearby" target="_blank" rel="noopener noreferrer nofollow ugc">here</a>)</p>
<p dir="auto">and this would be even better with distance sensing:<br />
<a href="https://www.raspberrypi.org/forums/viewtopic.php?f=37&amp;t=47466" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/forums/viewtopic.php?f=37&amp;t=47466</a></p>
]]></description><link>https://forum.magicmirror.builders/post/45137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/45137</guid><dc:creator><![CDATA[Cyberdyne]]></dc:creator><pubDate>Mon, 08 Oct 2018 08:47:03 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Mon, 05 Feb 2018 08:05:52 GMT]]></title><description><![CDATA[<p dir="auto">Hello and thanks for creating this module! I have experimenting with creating a photo frame and hope that your ProfileSwitcher will get me the rest of the way there.</p>
<p dir="auto">I am having an issue with MMM-ProfileSwitcher and using it with MMM-RandomBackground or MMM-RandomPhoto. I have tried some simple troubleshooting steps, but am not sure how to proceed further and hope you could help.</p>
<p dir="auto">I have simplified my config.js to try and eliminate other sources as being the issue. Currently I am experimenting using only the clock module, MMM-RandomBackground and MMM-ProfileSwitcher. I have 3 profiles ‘TestA’, ‘TestB’ and default. I ideally like to be able to show a random photo on my frame and alternate having overlays of weather / time / news / etc. based on the profile.</p>
<p dir="auto">My idea is to have a class that shows the random photo at a reduced opacity that can have some overlay infomation (clock, weather, news, etc.). And another class that only shows the photo at full opacity.</p>
<p dir="auto">The problem I have is that if my config.js has more than one entry for MMM-RandomBackground, it ignores more than the one entry. I am sure I have configured it correctly and have included my config.js below, but I only see a background photo for “TestA” Profile.</p>
<pre><code>modules: [
			header: 'Profile',
				defaultTime: 10000,
				useLockStrings: true,
				leaveMessages: false,
				enterMessages: false,
				timers: {
					// when TestA is selected swap to the defaultClass after the defaultTime
					"TestA": {},
				        // When TestB is selected swap to TestA after 20 seconds
				        "TestB": {
						profile: "TestA",
					    //	time: 20 * 1000
					"default": {
						profile: "TestB"
			module: 'alert',
			displayTime: 10000
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			disabled: false,
			classes: "TestA",
			position: "bottom_left",
				timeFormat: 12,
				displaySeconds: false,
				showPeriod: false,
				clockBold: false,
				dateFormat: "MMMM Do"
			module: "clock",
			disabled: false,
			classes: "default",
				timeFormat: 12,
				showPeriod: false,
				clockBold: false,
			module: "clock",
			disabled: false,
			classes: "TestB",
				timeFormat: 12,
				showPeriod: false,
				clockBold: false,
			module : 'MMM-RandomBackground',
			disabled: false,
			classes: "TestA",
			position : 'fullscreen_below', // Any region but this one makes the most sense
			config : {
				animationSpeed : 2000,
				updateInterval : 50000,
				opacity : 1
			disabled: false,
			classes: "TestB",
			config : {
				opacity : 0.5
<p dir="auto">If you are able to offer any insight as to why this might be happening or further troubleshooting I could do, I would greatly appreciate it.</p>
<p dir="auto">*** Full disclosure ***<br />
I originally posted this help request under another topic, but thought there would be a better chance that I might get more timely help with my issue in this topic. Sorry for the cross-post. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/35240</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/35240</guid><dc:creator><![CDATA[jdfraser]]></dc:creator><pubDate>Mon, 05 Feb 2018 08:05:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Mon, 29 Jan 2018 13:31:29 GMT]]></title><description><![CDATA[<p dir="auto">My mirror is just about finished, I have the MMM-PIRSensor working and MMM-Buttons working which both allow me to wake/sleep the monitor working fine.</p>
<p dir="auto">However i’d like to use MMM-Buttons as a toggle switch to enable me to essentially enable or disable the PIR sensor module:</p>
<p dir="auto">i.e.<br />
Profile 1 - PIRSensor wakes and turns off the monitor as normal<br />
Profile 2 - PIRSensor doesn’t do anything on motion being detected and the screen stays off</p>
<p dir="auto">I was thinking of modifying the code to do this but does anyone know if this module will allow me to achieve the results? Essentially having two profiles the same but profile 1 includes the PIRSensor module?</p>
]]></description><link>https://forum.magicmirror.builders/post/34872</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/34872</guid><dc:creator><![CDATA[paul.calladine]]></dc:creator><pubDate>Mon, 29 Jan 2018 13:31:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Fri, 19 May 2017 07:27:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/binog" aria-label="Profile: Binog">@<bdi>Binog</bdi></a><br />
I understand your question not really.</p>
<p dir="auto">I send the current_profile with MMM-Buttons and use it with MMM-RadioDE,<br />
with<br />
classes: ‘Radio’<br />
under the module name</p>
]]></description><link>https://forum.magicmirror.builders/post/21840</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21840</guid><dc:creator><![CDATA[Blackmirror]]></dc:creator><pubDate>Fri, 19 May 2017 07:27:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Thu, 18 May 2017 15:09:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blackmirror" aria-label="Profile: Blackmirror">@<bdi>Blackmirror</bdi></a><br />
Where to You let Current_profile been read?</p>
]]></description><link>https://forum.magicmirror.builders/post/21783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21783</guid><dc:creator><![CDATA[Binog]]></dc:creator><pubDate>Thu, 18 May 2017 15:09:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Wed, 17 May 2017 15:08:32 GMT]]></title><description><![CDATA[<p dir="auto">so the Notification,.,. is a compiling-error of this board. as mentioned above or elsewhere it does look correct in the config file.<br />
Actually I am a bit further, and ruled out some errors,.none the less I am not able to switch profiles!<br />
If I press one of my - not working - bottoms, I get these errors:</p>
<p dir="auto">konsole:<br />
<img src="/assets/uploads/files/1495033669289-konsole-resized.jpeg" alt="0_1495033667132_konsole.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">source-code:<br />
<img src="/assets/uploads/files/1495033669102-source.jpeg" alt="1_1495033667133_source.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/21716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21716</guid><dc:creator><![CDATA[Binog]]></dc:creator><pubDate>Wed, 17 May 2017 15:08:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Wed, 17 May 2017 14:58:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/binog" aria-label="Profile: Binog">@<bdi>Binog</bdi></a> To be honest I have no clue why there would be an additional <code>/</code>, try pulling all the new updates from the magicmirror framework (perhaps it was a bug?). The config looks fine for me except the url looks a bit strange <code>NOTIFICATION¬ification</code> that part especially. Does it work when you go to the link manually?</p>
]]></description><link>https://forum.magicmirror.builders/post/21715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21715</guid><dc:creator><![CDATA[tosti007]]></dc:creator><pubDate>Wed, 17 May 2017 14:58:58 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Mon, 15 May 2017 17:10:06 GMT]]></title><description><![CDATA[<p dir="auto">OK, this should be relevant:<br />
If I press on one of my bottom “you” this is what comes up in the console:</p>
<pre><code>[Error] TypeError: undefined is not an object (evaluating 'modules[i].name')
	(anonyme Funktion) (MMM-Modulebar.js:83)
<p dir="auto">this is at this line:<br />
if (modules[i].name === data.module) {</p>
<p dir="auto">and this is what the bottoms look like:</p>
<pre><code>```buttons: {
		"1": {
		     module: "MMM-MotionEye",
		     text: "door",
		     showUrl: "http://ip:8081/motioneye/1",
		     hideUrl: "http://ip:8081/motioneye/1/hide",
                "2": {
		    module: "MMM-Remote-Control",
                    symbol: "refresh",
                    showUrl: "http://ip:8080/remote?action=REFRESH",
                "3": {
                    symbol: "globe",
                    showUrl: "http://ip:8080/remote?action=UPDATE",
                "4": {
                    module: "MMM-ProfileSwitcher",
                    //Ignium: 1,
                    //text: "me",
                    //showUrl: "this.sendNotification('CURRENT_PROFILE', 'me');",
                    img: "url.jpg",
                    showUrl: "http://localhost:8080/remote?action=NOTIFICATION¬ification=CURRENT_PROFILE&amp;payload=%22me%22",
                     width: 30,
		     height: 40,
		     //profilename: "me",
                "5": {
                    //text: "You",
                    img: "url.jpg",
		    showUrl: "http://ip:8080/remote?action=NOTIFICATION¬ification=CURRENT_PROFILE&amp;payload=%22default%22",
                    width: 30,
		    height: 40,
		    //profilename: "You",
<pre><code>of course, ip has a relevant IP-adress. Interestingly button 1-3 work, except for 4 and 5. Any one could help?</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/21617</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21617</guid><dc:creator><![CDATA[Binog]]></dc:creator><pubDate>Mon, 15 May 2017 17:10:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Mon, 15 May 2017 04:39:17 GMT]]></title><description><![CDATA[<p dir="auto">missed something:</p>
<p dir="auto">undefined is not an object (evaluating ‘modules[i].name’)</p>
<p dir="auto">I cannot really interpret the output of the console: here it is:<br />
<img src="/assets/uploads/files/1494823154755-konsole-resized.jpeg" alt="0_1494823153170_Konsole.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/21609</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21609</guid><dc:creator><![CDATA[Binog]]></dc:creator><pubDate>Mon, 15 May 2017 04:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Mon, 15 May 2017 04:30:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tosti007" aria-label="Profile: tosti007">@<bdi>tosti007</bdi></a><br />
The only error is located with to TouchNacigations:</p>
<p dir="auto">The log says<br />
Cannot GET /modules/MMM-TouchNavigations//MMM-TouchNavigations.js</p>
<p dir="auto">Where does the double // comes from? (Between …Navigations and MMM-Touch…)<br />
I don’t find it in the config of TouchNavigations…<br />
Any ideas?</p>
]]></description><link>https://forum.magicmirror.builders/post/21608</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21608</guid><dc:creator><![CDATA[Binog]]></dc:creator><pubDate>Mon, 15 May 2017 04:30:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Sun, 14 May 2017 20:04:04 GMT]]></title><description><![CDATA[<p dir="auto">Will work, I have the Current_profile not read. Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/21595</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21595</guid><dc:creator><![CDATA[Blackmirror]]></dc:creator><pubDate>Sun, 14 May 2017 20:04:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Sun, 14 May 2017 16:35:08 GMT]]></title><description><![CDATA[<p dir="auto">No, will not work. :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/21588</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21588</guid><dc:creator><![CDATA[Blackmirror]]></dc:creator><pubDate>Sun, 14 May 2017 16:35:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-ProfileSwitcher, A Profile/User/Layout Switching Module on Sun, 14 May 2017 16:03:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blackmirror" aria-label="Profile: Blackmirror">@<bdi>Blackmirror</bdi></a> try doing it like this:</p>
<pre><code class="language-javascript">    longPress: {
      notification: "CURRENT_PROFILE",
      payload: "default"
    shortPress: {
      payload: "Radio"
]]></description><link>https://forum.magicmirror.builders/post/21584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/21584</guid><dc:creator><![CDATA[tosti007]]></dc:creator><pubDate>Sun, 14 May 2017 16:03:24 GMT</pubDate></item></channel></rss>
