<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SoccerLiveScore  from github with username&#x2F;pass]]></title><description><![CDATA[<p dir="auto">Hallo Zusammen,</p>
<p dir="auto">ich wollte das Modul von hier installieren:</p>
<p dir="auto"><a href="http://github.com/LukeSkywalker92/MMM-SoccerLiveScore.git/mrtysn/MMM-SoccerLiveScore" target="_blank" rel="noopener noreferrer nofollow ugc">github.com/LukeSkywalker92/MMM-SoccerLiveScore.git/mrtysn/MMM-SoccerLiveScore</a></p>
<p dir="auto">wenn ich mit putty installieren will kommt diese Meldung…</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/LukeSkywalker92/MMM-SoccerLiveScore.git
Klone nach 'MMM-SoccerLiveScore' ...
Username for 'https://github.com': xxxxx
Password for 'https://xxxxx@github.com':
remote: Repository not found.
fatal: repository 'https://github.com/LukeSkywalker92/MMM-SoccerLiveScore.git/' not found
<p dir="auto">oder geht das nicht weil die offizielle Seite bei github nicht online ist?</p>
<p dir="auto">Über ne kurze Rückinfo besten Dank.</p>
<p dir="auto">Gruss</p>
]]></description><link>https://forum.magicmirror.builders/topic/14044/mmm-soccerlivescore-from-github-with-username-pass</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 16:37:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14044.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Nov 2020 17:33:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Thu, 19 Nov 2020 13:39:20 GMT]]></title><description><![CDATA[<p dir="auto">chassain 0…YOU ARE THE BEST!!!</p>
<p dir="auto">Now i understand it. it was not true for me at the beginning with the [[ ]]!!</p>
<p dir="auto">best regards</p>
]]></description><link>https://forum.magicmirror.builders/post/84843</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84843</guid><dc:creator><![CDATA[kusselin]]></dc:creator><pubDate>Thu, 19 Nov 2020 13:39:20 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Wed, 18 Nov 2020 19:52:31 GMT]]></title><description><![CDATA[<p dir="auto">it’s easy to understand.<br />
The line 1 is the page 1 with mmm-wallpaper, darsky nameday…<br />
page 2 with …calendarext2, newfeed…<br />
etc…</p>
<p dir="auto">and you have to putt all config of differents modules before with position…you have to really try with 2 or 3 modules and see the results on MagicMirror…</p>
]]></description><link>https://forum.magicmirror.builders/post/84827</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84827</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Wed, 18 Nov 2020 19:52:31 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Wed, 18 Nov 2020 19:47:29 GMT]]></title><description><![CDATA[<p dir="auto">Ok thanks,</p>
<p dir="auto">But what must stand in [[ ]]</p>
<p dir="auto">And what modules names must stan in [ ]</p>
<p dir="auto">This is what i will understand</p>
]]></description><link>https://forum.magicmirror.builders/post/84826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84826</guid><dc:creator><![CDATA[kusselin]]></dc:creator><pubDate>Wed, 18 Nov 2020 19:47:29 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Wed, 18 Nov 2020 17:00:27 GMT]]></title><description><![CDATA[<p dir="auto">don’t afraid to test with a config test with 2 or three modules…and you can see a lot of config here with research</p>
]]></description><link>https://forum.magicmirror.builders/post/84816</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84816</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Wed, 18 Nov 2020 17:00:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Wed, 18 Nov 2020 16:58:32 GMT]]></title><description><![CDATA[<p dir="auto">what’s the problem about this module ? With example on github you have all explications.<br />
Here my config</p>
<pre><code>	{
    			module: "MMM-pages",
		disabled: false,
            				modules:
			[[ "MMM-Wallpaper" ,  "MMM-DarkSkyForecast" , "MMM-NameDay" , "MMM-RAIN-MAP" , "clock" , "newsfeed" , "MMM-VigilanceMeteoFrance" , "MMM-MoonPhase" ],
			[ "MMM-Wallpaper" , 'MMM-CalendarExt2' , "newsfeed" ],
			[ "MMM-Widget1" ],
			[ "MMM-Wallpaper" ,  "MMM-EmbedYoutube" , 'MMM-GooglePhotos' , "MMM-OnThisDay" , "MMM-Widget11" , "newsfeed" , "clock" ],
			[ "MMM-Wallpaper" ,  "MMM-EmbedYoutube" , 'MMM-GooglePhotos' , 'MMM-CoinRanking' ,  "MMM-Widget12" , "newsfeed" , "clock" ],
			[ "MMM-Wallpaper" , "MMM-Widget20",  "MMM-Widget21" , "MMM-Widget18",  "MMM-Widget19" ],
			[ "MMM-Wallpaper" , "MMM-PublicTransportHafas" , "MMM-Consumer-Flights" , "MMM-Provider-JSON" ,"clock" , "newsfeed" , "MMM-EasyPix" , "MMM-EasyPix2" ],
			[ "MMM-Wallpaper" , "MMM-Widget22" , "MMM-Widget23" , "MMM-Widget24"],
			[ "MMM-Wallpaper" , "MMM-Widget30" , "MMM-Widget31" , "MMM-Widget32"],
			[ "MMM-Wallpaper" ,  "MMM-EmbedYoutube" , 'MMM-GooglePhotos' , 'MMM-MovieListings' , "MMM-Cocktails" , "newsfeed" , "clock"  ],
			[ "MMM-Wallpaper" , , "MMM-EmbedYoutube" , 'MMM-GooglePhotos' , "MMM-Widget13" , "clock" , "newsfeed" ],
			[ "MMM-Wallpaper" ,  "MMM-EmbedYoutube" , 'MMM-GooglePhotos' , 'MMM-SoccerLiveScore' , 'MMM-soccer' , "clock" , "newsfeed" ],
			[ "MMM-Wallpaper" ,  "MMM-EmbedYoutube" , 'MMM-GooglePhotos' , "MMM-NowPlayingOnSpotify" , "MMM-PiTemp" , "newsfeed" , "clock" ]],
    				rotationTime: 15000,
			animationTime: 0,
]]></description><link>https://forum.magicmirror.builders/post/84815</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84815</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Wed, 18 Nov 2020 16:58:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Wed, 18 Nov 2020 09:56:14 GMT]]></title><description><![CDATA[<p dir="auto">is there anybody who can help me about mmm-pages??</p>
]]></description><link>https://forum.magicmirror.builders/post/84805</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84805</guid><dc:creator><![CDATA[kusselin]]></dc:creator><pubDate>Wed, 18 Nov 2020 09:56:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Mon, 16 Nov 2020 18:27:42 GMT]]></title><description><![CDATA[<p dir="auto">i don’t know/ sorry</p>
]]></description><link>https://forum.magicmirror.builders/post/84752</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84752</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Mon, 16 Nov 2020 18:27:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Mon, 16 Nov 2020 18:26:55 GMT]]></title><description><![CDATA[<p dir="auto">kennst du dich auch mit dem mmm-iobroker aus bissl?</p>
]]></description><link>https://forum.magicmirror.builders/post/84751</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84751</guid><dc:creator><![CDATA[kusselin]]></dc:creator><pubDate>Mon, 16 Nov 2020 18:26:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Mon, 16 Nov 2020 18:23:59 GMT]]></title><description><![CDATA[<p dir="auto">bitte :)</p>
]]></description><link>https://forum.magicmirror.builders/post/84750</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84750</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Mon, 16 Nov 2020 18:23:59 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Mon, 16 Nov 2020 18:23:10 GMT]]></title><description><![CDATA[<p dir="auto">o.k. danke</p>
]]></description><link>https://forum.magicmirror.builders/post/84749</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84749</guid><dc:creator><![CDATA[kusselin]]></dc:creator><pubDate>Mon, 16 Nov 2020 18:23:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SoccerLiveScore  from github with username&#x2F;pass on Mon, 16 Nov 2020 18:07:42 GMT]]></title><description><![CDATA[<p dir="auto">Hello.</p>
<p dir="auto">try with this</p>
<p dir="auto">git clone <a href="https://github.com/massi1990/MMM-SoccerLiveScore.git" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/massi1990/MMM-SoccerLiveScore.git</a></p>
]]></description><link>https://forum.magicmirror.builders/post/84746</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84746</guid><dc:creator><![CDATA[chassain 0]]></dc:creator><pubDate>Mon, 16 Nov 2020 18:07:42 GMT</pubDate></item></channel></rss>
