<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[help for mmm-pages und indicator please]]></title><description><![CDATA[<p dir="auto">Hello everyone, I’m currently working on my MagicMirror and I have several modules that don’t all fit on the screen …</p>
<p dir="auto">Now I wanted it so that the page then changes from 1 to 2 and I can then display modules on page 2 that are not displayed on page 1 because of that. the size.</p>
<p dir="auto">I have attached my config.js here … can you please explain to me using the module page udn indicator what I am there for example. must enter?</p>
<p dir="auto">I would like to thank you many times in advance for tips and a sample config of MMM pages and indicators.</p>
<p dir="auto">Thank you very much</p>
<pre><code>{
				module: "MMM-Traffic",
				position: "bottom_center",
				accessToken: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
				originCoords: "xxxxxxxxxxxxxxxxxxxxxxx",
				destinationCoords: "xxxxxxxxxxxxxxxxxxxxxxxxxxx",
				firstLine: "{duration} mins",
				secondLine: "xxxxxxxxxxxxxxxxxxx"
    module: 'MMM-ioBroker',
    position: 'top_right',
      host: '1xxxxxxxxxx',
      port: '8082',
      https: false,
      devices: [
          { name: 'xxxxxxxxxxxxxx',
            deviceStates: [
                              { id: 'zigbee.0.00158d0002fb4915.temperature', icon: 'wi wi-thermometer', suffix: '&amp;deg;' },
                              { id: 'zigbee.0.00158d0002fb4915.humidity',    icon: 'wi wi-humidity',    suffix: '%' }
		{ name: 'xxxxxxxxxxxxxxxxxx',
            deviceStates: [
                              { id: 'fhem.0.Temperatur_Feuchte_Speicher.temperature', icon: 'wi wi-thermometer',  suffix: '&amp;deg;' },
                              { id: 'fhem.0.Temperatur_Feuchte_Speicher.humidity',     icon: 'wi wi-humidity', suffix: '%' }
            deviceStates: [
                              { id: 'fhem.0.Temp_Feuchte_Wohnen_EG.measured-temp', icon: 'wi wi-thermometer',  suffix: '&amp;deg;' },
                              { id: 'fhem.0.Temp_Feuchte_Wohnen_EG_Climate.humidity',     icon: 'wi wi-humidity', suffix: '%' }
			{ name: 'xxxxxxxxxxxxxxxx',
            deviceStates: [
                              { id: 'fhem.0.Temp_Feuchte_Wohnen_OG.measured-temp', icon: 'wi wi-thermometer',  suffix: '&amp;deg;' },
                              { id: 'fhem.0.Temp_Feuchte_Wohnen_OG_Climate.humidity',     icon: 'wi wi-humidity', suffix: '%' }
			module: "newsfeed",
			position: "lower_third",
				feeds: [
						title: "ARD News",
						url: "http://www.tagesschau.de/xml/rss2"
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
			module: 'MMM-Tankerkoenig',
			header: 'Super (E10)',
			updateInterval: 600,
			maxWidth: "300px",// die angegeben 200px verursachen unschöne Zeilenumbrüche
			api_key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
			lat: xx.5xxx240, // das sind die Koordinaten von xxxxxxxxxxx/Mitte, siehe https://www.latlong.net
			lng: xx.6xxx140,
			type: "xxx", // alternativ “e5” oder “diesel”
			radius: x, // Suche in 1km Umkreis (in 5km Umkreis passt die Liste nicht mehr auf den Bildschirm)
  module: "MMM-PublicTransportHafas",
    stationID: "000xxxxxx",                   // Replace with your stationID!
    stationName: "xxxxxxxxxxxxxxxxxxx",   // Replace with your station name!
    direction: "",                    // Show only departures heading to this station. (A station ID.)
    ignoredLines: [],                 // Which lines should be ignored? (comma-separated list of line names)
    excludedTransportationTypes: [],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: StN for tram, BuN for bus, s for suburban
    timeToStation: 7,                // How long do you need to walk to the next Station?
    showColoredLineSymbols: true,     // Want colored line symbols?
    useColorForRealtimeInfo: true,    // Want colored real time information (timeToStation, early)?
    showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
    maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
    maxReachableDepartures: 7,        // How many reachable departures should be shown?
    customLineStyles: "",             // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
    showOnlyLineNumbers: false        // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
  module: 'MMM-COVID19-AMPEL',
  config:	{
    header: 'COVID-19 Inzidenzwert', // Header Title of Display on MagicMirror
    cityID: ["xxx","xx","xx"], // City ID from  https://npgeo-corona-npgeo-de.hub.arcgis.com/datasets/917fc37a709xxxxxx3be077a786c17_0/data
    infoRowClass: "small", // small, medium
    showUpdateDateInHeader: true, //Show update date in header
    showUpdateDateInRow: false, //Show update date in each row
    showStatusLightLeft: true, //Show left status light
    showStatusLightRight: true, // Show right status light
    showTitle: true, //Show Title row with headlines if you want to display more than one information
    showCases: true, //Show amount of active cases in city
    showCasesPerPeople: true, //Show Percentage of active cases per inhabitant
    showDeathRatePerPeople: true, //show death rate in % of infected people
    show7DayIncidence: true, // Show 7 day incidence value for your location
    numberOfDigits: 2, //Round the Percentage and incidence value to number of digits
    updateInterval: 3600000, // update interval in milliseconds // 1 Hour - Values are only refreshed every 24 H on Server
    fadeSpeed: 4000
        module: 'MMM-pages',
                modules:
                    [[ "MMM-OpenmapWeather", "weatherforecast", "newsfeed", "MMM-Fuel", "MMM-COVID19-AMPEL", "MMM-pages", "MMM-PublicTransportHafas"],
                     [ "calendar", "compliments" ]],
                fixed: ["clock", "MMM-OpenmapWeather", "weatherforecast", "newsfeed", "MMM-ioBroker", "calendar", "MMM-page-indicator"],
                hiddenPages: {
                    "screenSaver": [ "clock", "MMM-SomeBackgroundImageModule" ],
                    "admin": [ "MMM-ShowMeSystemStatsModule", "MMM-AnOnScreenMenuModule" ],
				animationTime:1000,
				rotationTime: 0.5*0.5*0.5,
				rotationDelay: 15000,
        module: 'MMM-page-indicator',
        position: 'bottom_bar',
            pages: 3,
    		module: "MMM-Fuel",
        	api_key: "xxxxxxxxxxx",
        	lat: xx.5062,
       		lng: x.6657,
        	types: ["e10"],
       		radius: 10
]]></description><link>https://forum.magicmirror.builders/topic/14051/help-for-mmm-pages-und-indicator-please</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 19:48:29 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14051.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Nov 2020 14:43:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to help for mmm-pages und indicator please on Wed, 18 Nov 2020 09:57:14 GMT]]></title><description><![CDATA[<p dir="auto">is there anyone here who can help me about mmm.pages in my config.js?</p>
<p dir="auto">best regards</p>
]]></description><link>https://forum.magicmirror.builders/post/84806</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84806</guid><dc:creator><![CDATA[kusselin]]></dc:creator><pubDate>Wed, 18 Nov 2020 09:57:14 GMT</pubDate></item></channel></rss>
