<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[npm istall problem]]></title><description><![CDATA[[[topic:post-is-deleted]]]]></description><link>https://forum.magicmirror.builders/topic/14073/npm-istall-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 09:37:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14073.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Nov 2020 20:06:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to npm istall problem on Fri, 20 Nov 2020 20:40:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> if u had run the install script, it would have done this for you</p>
]]></description><link>https://forum.magicmirror.builders/post/84890</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84890</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 20 Nov 2020 20:40:54 GMT</pubDate></item><item><title><![CDATA[Reply to npm istall problem on Fri, 20 Nov 2020 20:57:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marczy236" aria-label="Profile: marczy236">@<bdi>marczy236</bdi></a> run the fixsandbox script from the scripts site, see</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">I don’t have a fast link to it like the others, but u should be able to do it the same</p>
]]></description><link>https://forum.magicmirror.builders/post/84887</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/84887</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 20 Nov 2020 20:57:00 GMT</pubDate></item></channel></rss>
