<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Symbolic Link fault Question]]></title><description><![CDATA[<p dir="auto">I’m trying to copy my MM from existing Pi4 setup to another Pi4<br />
The process is mostly working but I’m getting some "cannot create symbolic link messages in iFrame node modules and node modules in a Vendor folder and others as it copies to SD card.</p>
<p dir="auto">Is there a way to copy MM from one Pi to another without incurring these faults. Physically, I’m copying the ~/MagicMirror and all its contents to an SD card which I will put in usb port and then copy to ~ on second Pi</p>
<p dir="auto">I’m not a programmer but can fumble my way through basic file manipulation but this is a problem and it is slow as molasses.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14095/symbolic-link-fault-question</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 00:03:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14095.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Nov 2020 17:02:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Symbolic Link fault Question on Tue, 24 Nov 2020 18:11:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> i also wouldn’t copy the node_modules folder, but redo npm install.</p>
<p dir="auto">Or zip the whole thing and unzip on target, instead of copy</p>
]]></description><link>https://forum.magicmirror.builders/post/85050</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85050</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 24 Nov 2020 18:11:44 GMT</pubDate></item><item><title><![CDATA[Reply to Symbolic Link fault Question on Tue, 24 Nov 2020 18:09:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a> should be no problem, although any symlinks may not work, if the source doesn’t exist on the copy to system.</p>
<p dir="auto">Only places I have symlinks is to my photo mount from my server,  and one for  my motion detection folder,  so it can be shared  between multiple  apps</p>
]]></description><link>https://forum.magicmirror.builders/post/85049</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85049</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 24 Nov 2020 18:09:40 GMT</pubDate></item></channel></rss>
