<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rotate the display 2560X1080 Raspberry Pi4]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I have a 2560x1080 display on the Raspberry Pi4. I cannot rotate the display. My settings are:</p>
<pre><code>@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@lxterminal
@leafpad
@xrandr --output HDMI-1 --rotate right
@xscreensaver -no-splash@
<p dir="auto">and /boot/config.txt:</p>
<pre><code>hdmi_safe=1
hdmi_drive=2
hdmi_ignore_edid=0xa5000080
hdmi_aspect_21_9=7
hdmi_pixel_freq_limit=400000000
hdmi_cvt=2560 1080 50 7 0 0 1
config_hdmi_boost=4
max_framebuffer_width=2560
max_framebuffer_height=1080
display_rotate = 2
avoid_warnings=1
hdmi_group=2
hdmi_mode=87
hdmi_force_hotplug=1
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
<p dir="auto">Can somebody help me?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14104/rotate-the-display-2560x1080-raspberry-pi4</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 23:21:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14104.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Nov 2020 13:39:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rotate the display 2560X1080 Raspberry Pi4 on Wed, 02 Dec 2020 16:12:32 GMT]]></title><description><![CDATA[<p dir="auto">I found the mistake. The HDMI cable was defective. I installed a new cable and now it automatically detects the resolution. The display is now correctly rotated.</p>
]]></description><link>https://forum.magicmirror.builders/post/85368</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85368</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Wed, 02 Dec 2020 16:12:32 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate the display 2560X1080 Raspberry Pi4 on Thu, 26 Nov 2020 09:23:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a> I think your original problem was in <em>/boot/config.txt</em> where you had spaces around the equal sign for <em>display_rotate</em>.</p>
]]></description><link>https://forum.magicmirror.builders/post/85148</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85148</guid><dc:creator><![CDATA[Alvinger]]></dc:creator><pubDate>Thu, 26 Nov 2020 09:23:28 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate the display 2560X1080 Raspberry Pi4 on Wed, 25 Nov 2020 16:35:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
sometimes i can also solve a problem except for myself</p>
]]></description><link>https://forum.magicmirror.builders/post/85102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85102</guid><dc:creator><![CDATA[raf]]></dc:creator><pubDate>Wed, 25 Nov 2020 16:35:47 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate the display 2560X1080 Raspberry Pi4 on Wed, 25 Nov 2020 16:16:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raf" aria-label="Profile: raf">@<bdi>raf</bdi></a> yes, thanks. That is where it was</p>
]]></description><link>https://forum.magicmirror.builders/post/85099</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85099</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Nov 2020 16:16:27 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate the display 2560X1080 Raspberry Pi4 on Wed, 25 Nov 2020 16:02:14 GMT]]></title><description><![CDATA[<p dir="auto">that does not work</p>
]]></description><link>https://forum.magicmirror.builders/post/85096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85096</guid><dc:creator><![CDATA[wuermchen]]></dc:creator><pubDate>Wed, 25 Nov 2020 16:02:14 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate the display 2560X1080 Raspberry Pi4 on Wed, 25 Nov 2020 14:21:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wuermchen" aria-label="Profile: wuermchen">@<bdi>wuermchen</bdi></a> there should be an option in the raspi-config program (run from a terminal  window)  for rotation</p>
<p dir="auto">sudo raspi-config</p>
]]></description><link>https://forum.magicmirror.builders/post/85085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85085</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Nov 2020 14:21:47 GMT</pubDate></item><item><title><![CDATA[Reply to Rotate the display 2560X1080 Raspberry Pi4 on Wed, 25 Nov 2020 14:21:06 GMT]]></title><description><![CDATA[<p dir="auto">i rotated my screen through the pi itself<br />
preferences and screen rotation</p>
]]></description><link>https://forum.magicmirror.builders/post/85084</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85084</guid><dc:creator><![CDATA[raf]]></dc:creator><pubDate>Wed, 25 Nov 2020 14:21:06 GMT</pubDate></item></channel></rss>
