<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[how can I display MM on my 2nd screen (just one pi 4)]]></title><description><![CDATA[<p dir="auto">hi,<br />
how can I display MM on my 2nd screen ?<br />
thx</p>
]]></description><link>https://forum.magicmirror.builders/topic/14118/how-can-i-display-mm-on-my-2nd-screen-just-one-pi-4</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 14:21:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14118.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Nov 2020 18:29:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to how can I display MM on my 2nd screen (just one pi 4) on Fri, 27 Nov 2020 14:53:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ;-)<br />
Thx for all!</p>
]]></description><link>https://forum.magicmirror.builders/post/85218</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85218</guid><dc:creator><![CDATA[Axel51]]></dc:creator><pubDate>Fri, 27 Nov 2020 14:53:10 GMT</pubDate></item><item><title><![CDATA[Reply to how can I display MM on my 2nd screen (just one pi 4) on Fri, 27 Nov 2020 14:51:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axel51" aria-label="Profile: Axel51">@<bdi>Axel51</bdi></a> i was talking about the the physical ports on the PI4.  not the logical DISPLAY number</p>
]]></description><link>https://forum.magicmirror.builders/post/85217</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85217</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 27 Nov 2020 14:51:42 GMT</pubDate></item><item><title><![CDATA[Reply to how can I display MM on my 2nd screen (just one pi 4) on Fri, 27 Nov 2020 14:46:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axel51" aria-label="Profile: Axel51">@<bdi>Axel51</bdi></a> for rpi, there is only one display port number 0</p>
]]></description><link>https://forum.magicmirror.builders/post/85216</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85216</guid><dc:creator><![CDATA[Axel51]]></dc:creator><pubDate>Fri, 27 Nov 2020 14:46:01 GMT</pubDate></item><item><title><![CDATA[Reply to how can I display MM on my 2nd screen (just one pi 4) on Fri, 27 Nov 2020 14:26:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  yes absolutely<br />
you can do the same with y</p>
]]></description><link>https://forum.magicmirror.builders/post/85215</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85215</guid><dc:creator><![CDATA[Axel51]]></dc:creator><pubDate>Fri, 27 Nov 2020 14:26:12 GMT</pubDate></item><item><title><![CDATA[Reply to how can I display MM on my 2nd screen (just one pi 4) on Fri, 27 Nov 2020 14:24:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axel51" aria-label="Profile: Axel51">@<bdi>Axel51</bdi></a> said in <a href="/post/85213">how can I display MM on my 2nd screen (just one pi 4)</a>:</p>
<p dir="auto">x is the abscissa of the letf corner of your MM</p>
<p dir="auto">eh?</p>
<p dir="auto">if u have two screens left and right,  in port 0 and 1</p>
<p dir="auto">then to get MM to display on the right monitor, in port 1, u need to set x to the width of the left monitor (port 0),</p>
<p dir="auto">and If you are doing above and below</p>
<p dir="auto">y (instead of x), the height of the monitor 0 in pixels.</p>
<p dir="auto">on my desktop in use x:1920<br />
on my pi i use x:3840 (running in 4k mode)</p>
]]></description><link>https://forum.magicmirror.builders/post/85214</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85214</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 27 Nov 2020 14:24:17 GMT</pubDate></item><item><title><![CDATA[Reply to how can I display MM on my 2nd screen (just one pi 4) on Fri, 27 Nov 2020 14:21:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thx for your help.<br />
In fact, x is the abscissa of the letf corner of your MM. So, you have to take in account if there 's a second screen on the left. In this case, x would be the width of the left screen. If not, x would be 0.</p>
]]></description><link>https://forum.magicmirror.builders/post/85213</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85213</guid><dc:creator><![CDATA[Axel51]]></dc:creator><pubDate>Fri, 27 Nov 2020 14:21:15 GMT</pubDate></item><item><title><![CDATA[Reply to how can I display MM on my 2nd screen (just one pi 4) on Thu, 26 Nov 2020 19:44:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/axel51" aria-label="Profile: Axel51">@<bdi>Axel51</bdi></a> add to config.js</p>
<p dir="auto">electonOptions:{x:1920},</p>
<p dir="auto">X = size of display width</p>
]]></description><link>https://forum.magicmirror.builders/post/85191</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85191</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 26 Nov 2020 19:44:04 GMT</pubDate></item></channel></rss>
