<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Google photo error when executing node generate_token.js]]></title><description><![CDATA[<p dir="auto">I’ve installed the MMM-Google photo module on a windows pc with git bash<br />
I’ve created a client_secret_xxx.apps.googleusercontent.com.json file and renamed it to credentials.json and placed it into the MMM-Google photo module directory.<br />
The problem occurs when I execute node generate_token.js. See the error below. What is wrong and how do I fix it?</p>
<p dir="auto">$ node generate_token.js<br />
[GPHOTOS:CORE] Error: Missing Credentials.<br />
C:\Users\administrator\MagicMirror-master\modules\MMM-GooglePhotos\GPhotos.js:13<br />
3<br />
throw e<br />
^</p>
<p dir="auto">Error: Missing Credentials.<br />
at new Auth (C:\Users\administrator\MagicMirror-master\modules\MMM-GooglePho<br />
tos\GPhotos.js:31:11)<br />
at GPhotos.onAuthReady (C:\Users\administrator\MagicMirror-master\modules\MM<br />
M-GooglePhotos\GPhotos.js:130:14)<br />
at GPhotos.generateToken (C:\Users\administrator\MagicMirror-master\modules<br />
MMM-GooglePhotos\GPhotos.js:141:10)<br />
at Object. (C:\Users\administrator\MagicMirror-master\modules\MMM<br />
-GooglePhotos\generate_token.js:10:9)<br />
at Module._compile (internal/modules/cjs/loader.js:1138:30)<br />
at Object.Module._extensions…js (internal/modules/cjs/loader.js:1158:10)<br />
at Module.load (internal/modules/cjs/loader.js:986:32)<br />
at Function.Module._load (internal/modules/cjs/loader.js:879:14)<br />
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js<br />
:71:12)<br />
at internal/main/run_main_module.js:17:47</p>
]]></description><link>https://forum.magicmirror.builders/topic/14128/mmm-google-photo-error-when-executing-node-generate_token-js</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 17:50:10 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14128.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Nov 2020 20:11:10 GMT</pubDate><ttl>60</ttl></channel></rss>
