<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can&#x27;t access MM² when run on &#x27;localhost&#x27;]]></title><description><![CDATA[<p dir="auto">Hi all!<br />
I’ve installed a Raspberry Pi camera and also the <a href="https://github.com/rejas/MMM-MotionDetector" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-MotionDetector</a> module, which works perfect. But since this module requires MM² to run at ‘<code>localhost</code>’ and not ‘<code>0.0.0.0</code>’ (due to requirements in Chrome for getUserMedia) I can’t access the MM2 from my PC at http://[MM²-IP]:8080/. As for what I understand the proxy solution mentioned in the README for the motion detector module is for other modules, not for accessing MM² from another device.<br />
Is there some kind of guide for a novice when it comes to these kinds of things, how to make my mirror accessible again?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14140/can-t-access-mm-when-run-on-localhost</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 17:19:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14140.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Nov 2020 11:43:02 GMT</pubDate><ttl>60</ttl></channel></rss>
