<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weather Module struggles]]></title><description><![CDATA[<p dir="auto">I gave the weather module a try and while I can get it to show the current weather, I can not get it to show the 5 day forecast after numerous changes. The page dedicated to this module says just use the module twice and and that is what I did, in addition to using weathergov as data source.<br />
I looked at the weather.js code and I am not  great at reading code but it seems like there is no code to adjust in config.js</p>
<p dir="auto">For example there is a line<br />
<code>timeFormat: config.timeFormat</code> in weather.js<br />
Then this in config.js <code>timeFormat: 12,</code></p>
<p dir="auto">The wiki?? page tells about the different options such as current, forecast, and daily as configuration items but again,  I can’t find a corresponding lines in weather.js to result in image on page.</p>
<p dir="auto">As an aside to that, it looks like when placed in middle_center it is thinking it is in one of the X_third configurations as it draws a line full screen width under the location text. top_center and bottom_center draw the line correctly under location text.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14160/weather-module-struggles</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 12:54:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14160.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Dec 2020 18:41:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weather Module struggles on Mon, 15 Feb 2021 23:06:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jamaces" aria-label="Profile: jamaces">@<bdi>jamaces</bdi></a> as i recall, there is a different apikey for 5 day…</p>
]]></description><link>https://forum.magicmirror.builders/post/88530</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88530</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 15 Feb 2021 23:06:39 GMT</pubDate></item><item><title><![CDATA[Reply to Weather Module struggles on Mon, 15 Feb 2021 22:57:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ankonaskiff17" aria-label="Profile: ankonaskiff17">@<bdi>ankonaskiff17</bdi></a></p>
<p dir="auto">these settings might help</p>
<p dir="auto">type: “daily”</p>
<p dir="auto">weatherEndpoint: “/onecall”,</p>
<p dir="auto">I could not get the 5day to work, kept on saying loading.</p>
]]></description><link>https://forum.magicmirror.builders/post/88529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88529</guid><dc:creator><![CDATA[jamaces]]></dc:creator><pubDate>Mon, 15 Feb 2021 22:57:53 GMT</pubDate></item></channel></rss>
