<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2screen in wall no mirror project]]></title><description><![CDATA[<p dir="auto">Work is not finished , but let me know what you are thinking about my information panel</p>
<p dir="auto">The Buttons on the left side are Busch Jaeger Zigbee trigger to control the pages and actions on the screens</p>
<p dir="auto"><img src="/assets/uploads/files/1606944180930-ded62085-2f19-492c-a416-e333815456d4.jpeg" alt="DED62085-2F19-492C-A416-E333815456D4.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1606944269604-bce6f838-2944-4b4d-ac91-8abafdab6ed0.jpeg" alt="BCE6F838-2944-4B4D-AC91-8ABAFDAB6ED0.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/14164/2screen-in-wall-no-mirror-project</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 10:38:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14164.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Dec 2020 21:27:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2screen in wall no mirror project on Fri, 04 Dec 2020 19:14:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/babene1" aria-label="Profile: Babene1">@<bdi>Babene1</bdi></a><br />
Hi , I try to explain a bit more.<br />
Everything is in the wall . I used one Raspberry 4 and an housing with a quit fan on top .<br />
On top of the wooden wall is the PIR mounted. Works fine if someone is going from our kitchen to the living room. Both monitors come back in 5 seconds . If I am about 3 meters away the wake up process starts. Perfect for me and my family.<br />
The controlling of the screens is a quite „push the Button“ Action . I started to control everything with Alexa , but early in the morning or quite late in the evening I don’t like to talk to much … but in general it also works .<br />
Back to the buttons . I use a conbee Zigbee stick in a second Raspi placed in our basement of the house. On this second Raspi the software ioBroker is installed . So if I push the Zigbee button it will send an trigger to the ioBroker via conbee. The ioBroker translates with an program script the Zigbee trigger into an MQTT trigger . This MQTT is uses with the MQTT Bridge in the MagicMirror to push notifications to the MagicMirror … yes quite difficult, but it works fine and the delay is not to big ( Max 0.5 sec.)<br />
I also started to test with real wired buttons. The plan was to bore holes in the wood an place a few buttons , but I decided to do in regards of a cleaner view of the wood wall.</p>
<p dir="auto">Here some more pictures<br />
<img src="/assets/uploads/files/1607105700552-c8cf75f6-0094-4c33-a615-b8eb26afa5db.jpeg" alt="C8CF75F6-0094-4C33-A615-B8EB26AFA5DB.jpeg" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1607109247581-1607105700550-a9d693d0-b964-49fb-8461-e92119d321e8.jpeg" alt="1607105700550-a9d693d0-b964-49fb-8461-e92119d321e8.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/85435</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85435</guid><dc:creator><![CDATA[icemanmw]]></dc:creator><pubDate>Fri, 04 Dec 2020 19:14:19 GMT</pubDate></item><item><title><![CDATA[Reply to 2screen in wall no mirror project on Fri, 04 Dec 2020 07:02:28 GMT]]></title><description><![CDATA[<p dir="auto">Looks really great, respect.<br />
Can you take more picture? And/or describe more?<br />
How did you mount the monitors? Did you use two raspberry for that? Where’s the equipment? behind the monitors?</p>
<p dir="auto">Thank you very much</p>
]]></description><link>https://forum.magicmirror.builders/post/85420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85420</guid><dc:creator><![CDATA[Babene1]]></dc:creator><pubDate>Fri, 04 Dec 2020 07:02:28 GMT</pubDate></item><item><title><![CDATA[Reply to 2screen in wall no mirror project on Wed, 02 Dec 2020 21:51:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/icemanmw" aria-label="Profile: icemanmw">@<bdi>icemanmw</bdi></a> awesome!!</p>
]]></description><link>https://forum.magicmirror.builders/post/85380</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85380</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Dec 2020 21:51:09 GMT</pubDate></item></channel></rss>
