<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror runs in small window after update]]></title><description><![CDATA[<p dir="auto">Hi, I just updated my Magic Mirror. After rebooting the mirror dashboard is no longer running in full screen. It looks like an overlay window without borders which is on top of the desktop.<br />
I did not change anything in my setup and have no clue where to look to fix this.<br />
I checked main.css and everything looks fine.<br />
Does anyone have an idea where this might come from and how to fix it?<img src="/assets/uploads/files/1607378771524-magicmirror-window.jpg" alt="magicmirror-window.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/14199/magicmirror-runs-in-small-window-after-update</link><generator>RSS for Node</generator><lastBuildDate>Sat, 12 Sep 2026 23:49:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14199.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Dec 2020 22:06:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Sun, 13 Dec 2020 16:31:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> My .folders are</p>
<pre><code>.cirlceci
.git
.github
<p dir="auto">No .config folder.</p>
]]></description><link>https://forum.magicmirror.builders/post/85715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85715</guid><dc:creator><![CDATA[maxheartrate]]></dc:creator><pubDate>Sun, 13 Dec 2020 16:31:22 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Sat, 12 Dec 2020 19:59:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxheartrate" aria-label="Profile: maxheartrate">@<bdi>maxheartrate</bdi></a> note it starts w a dot<br />
do</p>
<pre><code>ls ~/* -laF
]]></description><link>https://forum.magicmirror.builders/post/85687</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85687</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 12 Dec 2020 19:59:05 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Sat, 12 Dec 2020 18:11:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sorry. I didn’t mean to push you. I just checked my home directory. There is no config folder. I don’t really see any other folder that looks like one.</p>
]]></description><link>https://forum.magicmirror.builders/post/85684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85684</guid><dc:creator><![CDATA[maxheartrate]]></dc:creator><pubDate>Sat, 12 Dec 2020 18:11:19 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Fri, 11 Dec 2020 16:41:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> there is a folder where electron settings are saved… off your home folder… dont remember name …   starts with a .</p>
<p dir="auto">~/.config maybe</p>
]]></description><link>https://forum.magicmirror.builders/post/85656</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85656</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 11 Dec 2020 16:41:51 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Fri, 11 Dec 2020 16:30:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxheartrate" aria-label="Profile: maxheartrate">@<bdi>maxheartrate</bdi></a> i am away from my computer for another week. So can’t try  things.</p>
]]></description><link>https://forum.magicmirror.builders/post/85655</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85655</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 11 Dec 2020 16:30:04 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Fri, 11 Dec 2020 16:25:04 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately, I wasn’t able to fix my problem yet. Does anyone have an idea how to get the full fullscreen?<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> or someone else? Advise would be highly appreciated. Best, Max</p>
]]></description><link>https://forum.magicmirror.builders/post/85653</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85653</guid><dc:creator><![CDATA[maxheartrate]]></dc:creator><pubDate>Fri, 11 Dec 2020 16:25:04 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Wed, 09 Dec 2020 12:48:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/85546">MagicMirror runs in small window after update</a>:</p>
<p dir="auto">grep version ~/MagicMirror/package.json</p>
<p dir="auto">Hi Sam,</p>
<p dir="auto">it’s <code>"version": "2.13.0"</code>.</p>
<p dir="auto">Best, Max</p>
]]></description><link>https://forum.magicmirror.builders/post/85598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85598</guid><dc:creator><![CDATA[maxheartrate]]></dc:creator><pubDate>Wed, 09 Dec 2020 12:48:46 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Tue, 08 Dec 2020 13:41:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxheartrate" aria-label="Profile: maxheartrate">@<bdi>maxheartrate</bdi></a> good question. Can u tell me the version.</p>
<p dir="auto">The develop branch is a big jump on electron version…</p>
]]></description><link>https://forum.magicmirror.builders/post/85546</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85546</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 08 Dec 2020 13:41:18 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Tue, 08 Dec 2020 13:37:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> O.k. Thank you for the information. I still wonder why the Magic Mirror does not cover the full desktop. Before the latest update, I did not see anything but the Mirror window.</p>
]]></description><link>https://forum.magicmirror.builders/post/85545</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85545</guid><dc:creator><![CDATA[maxheartrate]]></dc:creator><pubDate>Tue, 08 Dec 2020 13:37:47 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Tue, 08 Dec 2020 12:47:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxheartrate" aria-label="Profile: maxheartrate">@<bdi>maxheartrate</bdi></a> kiosk sets full-screen to true</p>
]]></description><link>https://forum.magicmirror.builders/post/85542</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85542</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 08 Dec 2020 12:47:00 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Tue, 08 Dec 2020 12:45:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you for your advise, Sam.<br />
This is what I already tried - and just tried again:</p>
<p dir="auto"><code>electronOptions:{ x:0, width: 1081, height: 1921, fullscreen: false, kiosk: true }</code></p>
<p dir="auto">The problem remains the same. I also added more than one pixel to width and height but it wouldn’t change the result.</p>
]]></description><link>https://forum.magicmirror.builders/post/85541</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85541</guid><dc:creator><![CDATA[maxheartrate]]></dc:creator><pubDate>Tue, 08 Dec 2020 12:45:19 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Tue, 08 Dec 2020 12:03:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxheartrate" aria-label="Profile: maxheartrate">@<bdi>maxheartrate</bdi></a> x:0, and width: add one</p>
]]></description><link>https://forum.magicmirror.builders/post/85538</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85538</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 08 Dec 2020 12:03:36 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Tue, 08 Dec 2020 12:02:45 GMT]]></title><description><![CDATA[<p dir="auto">I was able to almost fix my problem using</p>
<pre><code>electronOptions : { width: 1080, height: 1920 }
<p dir="auto">However, I have a thin line from the desktop at the right and bottom edge shining through. The electron window does not cover the whole screen. I tried to use <code>fullscreen: true </code>and <code>kiosk: true</code>and set the width and height to values higher than my display size but it didn’t change anything. Interesting though, when I set <code>x: 1</code> in electronOptions to offset the window by a pixel, the thin line will disappear on the right side but appears on the left.</p>
<p dir="auto">Any ideas how to fix this? <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/85537</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85537</guid><dc:creator><![CDATA[maxheartrate]]></dc:creator><pubDate>Tue, 08 Dec 2020 12:02:45 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Tue, 08 Dec 2020 07:04:34 GMT]]></title><description><![CDATA[<p dir="auto">I just tried to start MM with npm start from the MagicMirror directory. Didn’t work.</p>
<p dir="auto">This is the message I receive:</p>
<p dir="auto">magicmirror@2.13.0 start /home/pi/MagicMirror<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
]]></description><link>https://forum.magicmirror.builders/post/85533</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85533</guid><dc:creator><![CDATA[maxheartrate]]></dc:creator><pubDate>Tue, 08 Dec 2020 07:04:34 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Tue, 08 Dec 2020 06:50:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi Sam, CTRL + “-” decreases the size of the modules in the window. However, the Magic Mirror window’s overall size remains the same. I would like to show it full screen again so that I don’t see the desktop.<br />
Best, Max</p>
]]></description><link>https://forum.magicmirror.builders/post/85532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85532</guid><dc:creator><![CDATA[maxheartrate]]></dc:creator><pubDate>Tue, 08 Dec 2020 06:50:10 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror runs in small window after update on Mon, 07 Dec 2020 22:34:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maxheartrate" aria-label="Profile: maxheartrate">@<bdi>maxheartrate</bdi></a> try ctrl-- ( minus sign)</p>
]]></description><link>https://forum.magicmirror.builders/post/85527</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85527</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 07 Dec 2020 22:34:32 GMT</pubDate></item></channel></rss>
