<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[White Screen after starting Magic Mirror]]></title><description><![CDATA[<p dir="auto">I try to build my own Module. When i start the MagicMirror now i get a blank white screen and i cant Quit the mirror no more. The only way to quit is a restart. but that sucks because i want to read the Terminal. When i Open Terminal then i get a new blank Terminal. How can i Quit the Terminal or how can i see my other Open Windows behind the Mirror?</p>
]]></description><link>https://forum.magicmirror.builders/topic/1421/white-screen-after-starting-magic-mirror</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 20:31:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1421.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 15 Jan 2017 17:08:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to White Screen after starting Magic Mirror on Sun, 15 Jan 2017 18:47:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/squirrel" aria-label="Profile: Squirrel">@<bdi>Squirrel</bdi></a><br />
Yes, I forgot to mention that. You can also press ctrl + c in console to kill the mirror process. So you don’t have to close the terminal every time</p>
]]></description><link>https://forum.magicmirror.builders/post/11127</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11127</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Sun, 15 Jan 2017 18:47:37 GMT</pubDate></item><item><title><![CDATA[Reply to White Screen after starting Magic Mirror on Sun, 15 Jan 2017 17:59:14 GMT]]></title><description><![CDATA[<p dir="auto">i got it! When i change with alt + tab to the Terminal i can close the Terminal and that also Quits my mirror! Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/11120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11120</guid><dc:creator><![CDATA[Squirrel]]></dc:creator><pubDate>Sun, 15 Jan 2017 17:59:14 GMT</pubDate></item><item><title><![CDATA[Reply to White Screen after starting Magic Mirror on Sun, 15 Jan 2017 17:51:01 GMT]]></title><description><![CDATA[<p dir="auto">No. Ctrl + q is not working… It works when the mirror is running but with my white screen it is now more possible to quit it with this command…</p>
]]></description><link>https://forum.magicmirror.builders/post/11118</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11118</guid><dc:creator><![CDATA[Squirrel]]></dc:creator><pubDate>Sun, 15 Jan 2017 17:51:01 GMT</pubDate></item><item><title><![CDATA[Reply to White Screen after starting Magic Mirror on Sun, 15 Jan 2017 17:40:32 GMT]]></title><description><![CDATA[<p dir="auto">Ctrl+q quits the mirror, ctrl+r reloads the page.</p>
]]></description><link>https://forum.magicmirror.builders/post/11116</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11116</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sun, 15 Jan 2017 17:40:32 GMT</pubDate></item><item><title><![CDATA[Reply to White Screen after starting Magic Mirror on Sun, 15 Jan 2017 17:38:55 GMT]]></title><description><![CDATA[<p dir="auto">Yes i work on raspberry directly. Sadly i did mot found a way to test my work on my mac!? Ok thanks! alt + tab is working. But it still s**** a bit when i have to restart my raspberry after ever fault i did…</p>
]]></description><link>https://forum.magicmirror.builders/post/11115</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11115</guid><dc:creator><![CDATA[Squirrel]]></dc:creator><pubDate>Sun, 15 Jan 2017 17:38:55 GMT</pubDate></item><item><title><![CDATA[Reply to White Screen after starting Magic Mirror on Sun, 15 Jan 2017 17:27:21 GMT]]></title><description><![CDATA[<p dir="auto">Are you working on your raspberry directly? You should be able to switch with alt + tab.</p>
<p dir="auto">As an alternative you could run <code>node serveronly</code>, open the browser on your own and go to <a href="http://localhost:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080</a></p>
]]></description><link>https://forum.magicmirror.builders/post/11111</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11111</guid><dc:creator><![CDATA[yawns]]></dc:creator><pubDate>Sun, 15 Jan 2017 17:27:21 GMT</pubDate></item></channel></rss>
