<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2 SolarEdge PV systems in 1 M-Mirror]]></title><description><![CDATA[<p dir="auto">Hello I would like to display 2 SolarEdge PV systems at the same time in a MagicMirror. Unfortunately, only the data from one system is displayed, despite two separate API key and location ID. Does anyone know?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14218/2-solaredge-pv-systems-in-1-m-mirror</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 09:07:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14218.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Dec 2020 18:23:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2 SolarEdge PV systems in 1 M-Mirror on Tue, 15 Dec 2020 17:16:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashishtank" aria-label="Profile: ashishtank">@<bdi>ashishtank</bdi></a> Thanks - I will change the module to the “darickc” version. You get ASAP an final feedback, from my side.</p>
]]></description><link>https://forum.magicmirror.builders/post/85779</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85779</guid><dc:creator><![CDATA[SiJuAtHome11]]></dc:creator><pubDate>Tue, 15 Dec 2020 17:16:15 GMT</pubDate></item><item><title><![CDATA[Reply to 2 SolarEdge PV systems in 1 M-Mirror on Fri, 11 Dec 2020 19:14:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sijuathome11" aria-label="Profile: SiJuAtHome11">@<bdi>SiJuAtHome11</bdi></a> Which module you are using ? <a href="https://github.com/darickc/MMM-SolarEdge" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/darickc/MMM-SolarEdge</a> this one looks okay by code and looks like it supports multiple instance of same modules.</p>
<p dir="auto">If you are using <a href="https://github.com/bertieuk/MMM-SolarEdge" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bertieuk/MMM-SolarEdge</a> this one then from code it looks like it does not support multiple modules.</p>
]]></description><link>https://forum.magicmirror.builders/post/85663</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85663</guid><dc:creator><![CDATA[ashishtank]]></dc:creator><pubDate>Fri, 11 Dec 2020 19:14:52 GMT</pubDate></item></channel></rss>
