<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SpeedTest Fails to Install]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> Thanks for the great module but I am having issues with installing the above module. I managed to install it fine on my Laptop running Ubuntu on Windows. When I tried to install it on my Raspberry Pi 3B+ I get an error. The error I get right at the end of the install is as follows:</p>
<pre><code>8734 silly lifecycle MMM-SpeedTest@1.0.0~postinstall: Args: [ '-c',
8734 silly lifecycle   'echo \'Building SpeedTest module, please wait...\' &amp;&amp; electron-rebuild 2&gt;/dev/null &gt;/dev/null' ]
8735 silly lifecycle MMM-SpeedTest@1.0.0~postinstall: Returned: code: 1  signal: null
8736 info lifecycle MMM-SpeedTest@1.0.0~postinstall: Failed to exec postinstall script
8737 verbose stack Error: MMM-SpeedTest@1.0.0 postinstall: `echo 'Building SpeedTest module, please wait...' &amp;&amp; electron-rebuild 2&gt;/dev/null &gt;/dev/null`
8737 verbose stack Exit status 1
8737 verbose stack     at EventEmitter.&lt;anonymous&gt; (/home/pi/.npm-global/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
8737 verbose stack     at EventEmitter.emit (events.js:180:13)
8737 verbose stack     at ChildProcess.&lt;anonymous&gt; (/home/pi/.npm-global/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
8737 verbose stack     at ChildProcess.emit (events.js:180:13)
8737 verbose stack     at maybeClose (internal/child_process.js:936:16)
8737 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
8738 verbose pkgid MMM-SpeedTest@1.0.0
8739 verbose cwd /home/pi/MagicMirror/modules/MMM-SpeedTest
8740 verbose Linux 4.14.52-v7+
8741 verbose argv "/usr/bin/node" "/home/pi/.npm-global/bin/npm" "install"
8742 verbose node v9.11.2
8743 verbose npm  v6.14.8
8744 error code ELIFECYCLE
8745 error errno 1
8746 error MMM-SpeedTest@1.0.0 postinstall: `echo 'Building SpeedTest module, please wait...' &amp;&amp; electron-rebuild 2&gt;/dev/null &gt;/dev/null`
8746 error Exit status 1
8747 error Failed at the MMM-SpeedTest@1.0.0 postinstall script.
8747 error This is probably not a problem with npm. There is likely additional logging output above.
8748 verbose exit [ 1, true ]
<p dir="auto">I tried uploading the full log but keep getting an error.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14234/mmm-speedtest-fails-to-install</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 18:56:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14234.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Dec 2020 11:15:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SpeedTest Fails to Install on Mon, 14 Dec 2020 12:55:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> Updated and it now works fine. Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/85739</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85739</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Mon, 14 Dec 2020 12:55:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpeedTest Fails to Install on Mon, 14 Dec 2020 11:44:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: Bugsounet">@<bdi>Bugsounet</bdi></a> Thanks for the response. Will update and try again.</p>
]]></description><link>https://forum.magicmirror.builders/post/85735</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85735</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Mon, 14 Dec 2020 11:44:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SpeedTest Fails to Install on Mon, 14 Dec 2020 11:26:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mumblebaj" aria-label="Profile: mumblebaj">@<bdi>mumblebaj</bdi></a> hi, I see your log and I have see very old version of node and npm.<br />
Again I see an old Linux firmware. Try to update your rpi ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/85734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85734</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 14 Dec 2020 11:26:21 GMT</pubDate></item></channel></rss>
