<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Office365 Calendar issue]]></title><description><![CDATA[<p dir="auto">There is a strange issue with MM 2.13 and Calendar for Office365 users.<br />
I have already applied the calendar fix, but the following;</p>
<p dir="auto">I have placed the calendar.ics file in the config.js as required and it is showing me calendar topics.<br />
The thing is it is only showing recurring calendar topics, it will not show daily calendar topics that are not recurring.</p>
<p dir="auto">Checked the error logs, but nor error as well.</p>
<p dir="auto">Any idea?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14239/office365-calendar-issue</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 10:36:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14239.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Dec 2020 08:03:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Office365 Calendar issue on Sat, 02 Jan 2021 05:20:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok so what do I need to do to provide you the information you need?</p>
]]></description><link>https://forum.magicmirror.builders/post/86564</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86564</guid><dc:creator><![CDATA[SdR]]></dc:creator><pubDate>Sat, 02 Jan 2021 05:20:13 GMT</pubDate></item><item><title><![CDATA[Reply to Office365 Calendar issue on Tue, 22 Dec 2020 13:36:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdr" aria-label="Profile: SdR">@<bdi>SdR</bdi></a> that (no debug) means uvare not running the develop branch fixes</p>
]]></description><link>https://forum.magicmirror.builders/post/86033</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86033</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 22 Dec 2020 13:36:13 GMT</pubDate></item><item><title><![CDATA[Reply to Office365 Calendar issue on Tue, 22 Dec 2020 07:33:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/85839">Office365 Calendar issue</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdr" aria-label="Profile: SdR">@<bdi>SdR</bdi></a> come on,</p>
<p dir="auto">line in config.js</p>
<pre><code>logLevel: ["INFO", "LOG", "WARN", "ERROR"],
<p dir="auto">add</p>
<pre><code>"DEBUG"
<p dir="auto">to that list</p>
<p dir="auto">I added it in config.js at this location;</p>
<p dir="auto">*/</p>
<p dir="auto">var config = {<br />
logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”,“DEBUG”],<br />
address: “localhost”, // Address to listen on, can be:</p>
<p dir="auto">I will send the result in PM, but I don’t see any DEBUG line in pm2.log</p>
]]></description><link>https://forum.magicmirror.builders/post/86026</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86026</guid><dc:creator><![CDATA[SdR]]></dc:creator><pubDate>Tue, 22 Dec 2020 07:33:40 GMT</pubDate></item><item><title><![CDATA[Reply to Office365 Calendar issue on Mon, 21 Dec 2020 13:27:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> tnx…</p>
<p dir="auto">regarding “<a class="plugin-mentions-user plugin-mentions-a" href="/user/sdr" aria-label="Profile: SdR">@<bdi>SdR</bdi></a> come on”… I’m no pro in Raspberry… doing all by google…and trial &amp; error. So yes I need some help  with this…</p>
<p dir="auto">Will add it tomorrow and let you know the results.</p>
]]></description><link>https://forum.magicmirror.builders/post/85979</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85979</guid><dc:creator><![CDATA[SdR]]></dc:creator><pubDate>Mon, 21 Dec 2020 13:27:50 GMT</pubDate></item><item><title><![CDATA[Reply to Office365 Calendar issue on Fri, 18 Dec 2020 12:19:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdr" aria-label="Profile: SdR">@<bdi>SdR</bdi></a> come on,</p>
<pre><code>"DEBUG"
]]></description><link>https://forum.magicmirror.builders/post/85839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85839</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 18 Dec 2020 12:19:43 GMT</pubDate></item><item><title><![CDATA[Reply to Office365 Calendar issue on Fri, 18 Dec 2020 07:31:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> can you help?</p>
]]></description><link>https://forum.magicmirror.builders/post/85835</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85835</guid><dc:creator><![CDATA[SdR]]></dc:creator><pubDate>Fri, 18 Dec 2020 07:31:54 GMT</pubDate></item><item><title><![CDATA[Reply to Office365 Calendar issue on Tue, 15 Dec 2020 12:53:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Yes, I can, but can you provide an example how to do that in the config.js file</p>
]]></description><link>https://forum.magicmirror.builders/post/85775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85775</guid><dc:creator><![CDATA[SdR]]></dc:creator><pubDate>Tue, 15 Dec 2020 12:53:38 GMT</pubDate></item><item><title><![CDATA[Reply to Office365 Calendar issue on Fri, 18 Dec 2020 12:20:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdr" aria-label="Profile: SdR">@<bdi>SdR</bdi></a> can u add ‘Debug’ to the logLevel list in config.js and run mm again.</p>
<p dir="auto">It will output to to console if u use npm start or to the logs if you use pm2</p>
]]></description><link>https://forum.magicmirror.builders/post/85769</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85769</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 18 Dec 2020 12:20:09 GMT</pubDate></item></channel></rss>
