Monitor is slightly larger than the Mirror
Hello everyone!
I’ve recently started my smart mirror build and I’m using an Asus vg248qe monitor which is 24 inches across, with 12.5 by 22. I bought a 12 x 22 glass and made the mistake of not double checking my measuring of the monitor the first time. I’m now kind of stumped on how and if I could a frame work into these dimensions since the monitor’s bezzles sticks out on the sides of the glass. The actual panel itself fully fits into the mirror. Am I just out of luck?
Any ideas would be greatly appreciated!
@el69909 usually u will remove the bezel to get the monitor against the glass
So this little silver part in the corners is what’s making this wider than what I had anticipated, from checking looks like either way I won’t be able to shave off any length as it’s part of the entire screen
https://imgur.com/a/dVAOlOi
@el69909 yeh, that’s the frame. not gonna be able to remove that
So, build your “box” to cover the edges of the monitor and the first 1/4" of the glass edges. Problem solved.
Get some sort of small quarter round type molding or use router and cut slot in frame pieces.
I’ve found that chair rail molding is a good source for easy decorative front facing. It takes a stain well and the pattern is good for hiding nail heads and other imperfections.
