<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Overflow with calendar?]]></title><description><![CDATA[<p dir="auto">I have this calendar of my high school with all my assignments. I wanted to add this to my mirror, but I got an error.</p>
<pre><code>bytesParsed: 8281,
  code: 'HPE_HEADER_OVERFLOW',
  reason: 'Header overflow'
<p dir="auto">Any help?<br />
Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/14257/overflow-with-calendar</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 05:52:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14257.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 Dec 2020 13:15:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Overflow with calendar? on Wed, 23 Dec 2020 14:30:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/avanloo01" aria-label="Profile: avanloo01">@<bdi>avanloo01</bdi></a> awesome…  I will close the issue i opened…</p>
]]></description><link>https://forum.magicmirror.builders/post/86092</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86092</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 23 Dec 2020 14:30:47 GMT</pubDate></item><item><title><![CDATA[Reply to Overflow with calendar? on Wed, 23 Dec 2020 14:30:14 GMT]]></title><description><![CDATA[<p dir="auto">Yes, it did.</p>
]]></description><link>https://forum.magicmirror.builders/post/86091</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86091</guid><dc:creator><![CDATA[avanloo01]]></dc:creator><pubDate>Wed, 23 Dec 2020 14:30:14 GMT</pubDate></item><item><title><![CDATA[Reply to Overflow with calendar? on Mon, 21 Dec 2020 13:28:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/avanloo01" aria-label="Profile: avanloo01">@<bdi>avanloo01</bdi></a> did it work? I’m guessing so</p>
]]></description><link>https://forum.magicmirror.builders/post/85980</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85980</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Dec 2020 13:28:00 GMT</pubDate></item><item><title><![CDATA[Reply to Overflow with calendar? on Sun, 20 Dec 2020 16:14:14 GMT]]></title><description><![CDATA[<p dir="auto">Thank you so much!</p>
]]></description><link>https://forum.magicmirror.builders/post/85927</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85927</guid><dc:creator><![CDATA[avanloo01]]></dc:creator><pubDate>Sun, 20 Dec 2020 16:14:14 GMT</pubDate></item><item><title><![CDATA[Reply to Overflow with calendar? on Sun, 20 Dec 2020 13:02:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/avanloo01" aria-label="Profile: avanloo01">@<bdi>avanloo01</bdi></a> here is a workaround…</p>
<p dir="auto">do</p>
<pre><code>export NODE_OPTIONS=--max-http-header-size=10000
<p dir="auto">then</p>
<pre><code>npm start
<p dir="auto">if you use pm2 to launch MM, then add that line to the script that is launched by pm2<br />
(typically  MagicMirror/installers/mm.sh)</p>
]]></description><link>https://forum.magicmirror.builders/post/85916</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85916</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Dec 2020 13:02:53 GMT</pubDate></item><item><title><![CDATA[Reply to Overflow with calendar? on Sat, 19 Dec 2020 14:46:30 GMT]]></title><description><![CDATA[<p dir="auto">we worked offline, and there was a security fix to reduce the header buffer size from 80,000 to 8,000 bytes.<br />
the server is sending a misformatted message with the calendar results</p>
<p dir="auto">the workarounds for this issue do not work<br />
<a href="https://github.com/nodejs/node/issues/24692" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/nodejs/node/issues/24692</a></p>
]]></description><link>https://forum.magicmirror.builders/post/85865</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85865</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 19 Dec 2020 14:46:30 GMT</pubDate></item><item><title><![CDATA[Reply to Overflow with calendar? on Sat, 19 Dec 2020 13:36:56 GMT]]></title><description><![CDATA[<p dir="auto">I sent you a message.</p>
]]></description><link>https://forum.magicmirror.builders/post/85864</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85864</guid><dc:creator><![CDATA[avanloo01]]></dc:creator><pubDate>Sat, 19 Dec 2020 13:36:56 GMT</pubDate></item><item><title><![CDATA[Reply to Overflow with calendar? on Sat, 19 Dec 2020 13:30:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/avanloo01" aria-label="Profile: avanloo01">@<bdi>avanloo01</bdi></a> sure, just start a chat with me, click the bubble to the left, and then click chat</p>
]]></description><link>https://forum.magicmirror.builders/post/85863</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85863</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 19 Dec 2020 13:30:42 GMT</pubDate></item><item><title><![CDATA[Reply to Overflow with calendar? on Sat, 19 Dec 2020 13:29:25 GMT]]></title><description><![CDATA[<p dir="auto">Can I do this in like a private message or something, because I don’t know if I can just post the link on the internet.</p>
]]></description><link>https://forum.magicmirror.builders/post/85862</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85862</guid><dc:creator><![CDATA[avanloo01]]></dc:creator><pubDate>Sat, 19 Dec 2020 13:29:25 GMT</pubDate></item><item><title><![CDATA[Reply to Overflow with calendar? on Sat, 19 Dec 2020 13:26:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/avanloo01" aria-label="Profile: avanloo01">@<bdi>avanloo01</bdi></a> eh?   show me the config?</p>
]]></description><link>https://forum.magicmirror.builders/post/85861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/85861</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 19 Dec 2020 13:26:33 GMT</pubDate></item></channel></rss>
