<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rpi3 &amp; 7&quot; pi touchscreen - MM not displaying]]></title><description><![CDATA[<p dir="auto">Greetings!<br />
I’ve tried multiple times with the same issue. My MM isn’t displaying on the 7" Pi touchscreen. Presumably it wants to display on the HDMI.<br />
When the pi boots I see the raspbian boot sequence on the touchscreen.</p>
<p dir="auto">Connected to Pi via ssh.<br />
Installed MM2 via script ‘bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh</a>)”’</p>
<p dir="auto">PM2 confirms a successful start of MM2. Nothing on the 7" touchscreen. Why would this be the case?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14274/rpi3-7-pi-touchscreen-mm-not-displaying</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 00:22:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14274.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Dec 2020 04:04:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rpi3 &amp; 7&quot; pi touchscreen - MM not displaying on Tue, 22 Dec 2020 04:47:07 GMT]]></title><description><![CDATA[<p dir="auto">thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/86018</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86018</guid><dc:creator><![CDATA[kindsouls]]></dc:creator><pubDate>Tue, 22 Dec 2020 04:47:07 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 &amp; 7&quot; pi touchscreen - MM not displaying on Tue, 22 Dec 2020 04:46:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kindsouls" aria-label="Profile: kindsouls">@<bdi>kindsouls</bdi></a> gotta have the desktop version…<br />
browser requires graphics</p>
]]></description><link>https://forum.magicmirror.builders/post/86017</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86017</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 22 Dec 2020 04:46:43 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 &amp; 7&quot; pi touchscreen - MM not displaying on Tue, 22 Dec 2020 04:45:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/86011">Rpi3 &amp; 7" pi touchscreen - MM not displaying</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kindsouls" aria-label="Profile: kindsouls">@<bdi>kindsouls</bdi></a> as I said, never seen one… others have done it…</p>
<p dir="auto">do u seen the pi desktop after boot?</p>
<p dir="auto">Raspbian lite, so no desktop, but I do see the<br />
“raspberrypi login:”<br />
after boot.  I could hook up a keyboard and type on the screen I’m certain.<br />
I can also do things that effect the display in realtime, such as:</p>
<p dir="auto">sudo sh -c “echo 80 &gt; /sys/class/backlight/rpi_backlight/brightness”</p>
]]></description><link>https://forum.magicmirror.builders/post/86014</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86014</guid><dc:creator><![CDATA[kindsouls]]></dc:creator><pubDate>Tue, 22 Dec 2020 04:45:44 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 &amp; 7&quot; pi touchscreen - MM not displaying on Tue, 22 Dec 2020 04:41:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kindsouls" aria-label="Profile: kindsouls">@<bdi>kindsouls</bdi></a> as I said, never seen one… others have done it…</p>
]]></description><link>https://forum.magicmirror.builders/post/86011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86011</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 22 Dec 2020 04:41:32 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 &amp; 7&quot; pi touchscreen - MM not displaying on Tue, 22 Dec 2020 04:35:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/86007">Rpi3 &amp; 7" pi touchscreen - MM not displaying</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kindsouls" aria-label="Profile: kindsouls">@<bdi>kindsouls</bdi></a> the 7 in is not DISPLAY:0</p>
<p dir="auto">I have never seen or used one,  so I don’t know what its display number is.</p>
<p dir="auto">change it in installers/mm.sh</p>
<p dir="auto">I thought so too, but then I ran tvservice:</p>
<p dir="auto">pi@raspberrypi:~ $ tvservice -l<br />
2 attached device(s), display ID’s are :<br />
Display Number 0, type Main LCD<br />
Display Number 2, type HDMI 0</p>
]]></description><link>https://forum.magicmirror.builders/post/86008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86008</guid><dc:creator><![CDATA[kindsouls]]></dc:creator><pubDate>Tue, 22 Dec 2020 04:35:40 GMT</pubDate></item><item><title><![CDATA[Reply to Rpi3 &amp; 7&quot; pi touchscreen - MM not displaying on Tue, 22 Dec 2020 04:26:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kindsouls" aria-label="Profile: kindsouls">@<bdi>kindsouls</bdi></a> the 7 in is not DISPLAY:0</p>
]]></description><link>https://forum.magicmirror.builders/post/86007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86007</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 22 Dec 2020 04:26:18 GMT</pubDate></item></channel></rss>
