<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with repeating events in default calendar module]]></title><description><![CDATA[<p dir="auto">I use a shared public iCal calendar. Clean calendar. I added one repeating event. The event is repeating weekly. All upcoming weekly events are displayed correctly i.e. everything works OK.</p>
<p dir="auto">After that I modify the event and add location to it. However, I add the location only to one event which occurs this week. In other words I do not add location to all upcoming events. Then I check my MM screen but I can see only this week’s event. All other upcoming events are missing. Pretty nasty issue because I use a lot these kind events.</p>
<p dir="auto">Test calendar: webcal://p45-calendars.icloud.com/published/2/9NMoDydK3OPAUr3LwVn-4lYXlbvKSAkUJKjkMFuLfFK1LI9ytVYOEtDTR6Aj3L4cd3XJ0-gN__8QuYuBJYTMVzJtadvDWifojHo81l5VpO0</p>
<p dir="auto">If you need help for testing please ask.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1430/problem-with-repeating-events-in-default-calendar-module</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 08:35:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1430.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Jan 2017 17:11:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with repeating events in default calendar module on Mon, 18 Dec 2017 19:30:33 GMT]]></title><description><![CDATA[<p dir="auto">Did anyone get a resolution to this? I am having the same issue, I have a repeating calendar event that shows up fine, but when I change one item in the series it does not show up.</p>
]]></description><link>https://forum.magicmirror.builders/post/32458</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32458</guid><dc:creator><![CDATA[jasondreher]]></dc:creator><pubDate>Mon, 18 Dec 2017 19:30:33 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with repeating events in default calendar module on Mon, 05 Jun 2017 14:19:48 GMT]]></title><description><![CDATA[<p dir="auto">Any luck with this bug?</p>
]]></description><link>https://forum.magicmirror.builders/post/22366</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/22366</guid><dc:creator><![CDATA[nhl]]></dc:creator><pubDate>Mon, 05 Jun 2017 14:19:48 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with repeating events in default calendar module on Fri, 31 Mar 2017 13:54:12 GMT]]></title><description><![CDATA[<p dir="auto">Anyone have a solution to this, I have the same issue. A monthly repeating event will not show on my calendar module. I see a function named “displayRepeatingCountTitle” but I cant seem to figure out what this does, or if it is at all related.</p>
]]></description><link>https://forum.magicmirror.builders/post/18563</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/18563</guid><dc:creator><![CDATA[jasondreher]]></dc:creator><pubDate>Fri, 31 Mar 2017 13:54:12 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with repeating events in default calendar module on Sun, 05 Feb 2017 08:46:59 GMT]]></title><description><![CDATA[<p dir="auto">I also have problems with the default calendar module and repeating or recurring events. Especially when editing a specific event that is part of a repeating event.<br />
I deleted one episode of a series of events. My Google calendar (app on phone) no longer shows the event, but my Mirror still shows the event. I have tried a restart and a reboot, but the calendar module persists in showing the event.<br />
I have modified yet one other episode of a different series (changed the duration). Again Google calendar on Phone shows updated results, the mirror persists in showing the none-updated version.</p>
<p dir="auto">This is annoying as I am using the Mirror as a family board, it has all the musical classes, sports trainings, chores-schedules etc. on it. These are of course recurring events, but some of them also tend to be edited to fit that week’s specific schedule.<br />
It feels to me that the default calendar module has a problem with handling exceptions to recurring events.</p>
<p dir="auto">Any ideas / solutions?</p>
]]></description><link>https://forum.magicmirror.builders/post/13658</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/13658</guid><dc:creator><![CDATA[Hein-Jan]]></dc:creator><pubDate>Sun, 05 Feb 2017 08:46:59 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with repeating events in default calendar module on Mon, 16 Jan 2017 20:43:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/villevirtanen" aria-label="Profile: villevirtanen">@<bdi>villevirtanen</bdi></a></p>
<p dir="auto">:-( same issue…</p>
]]></description><link>https://forum.magicmirror.builders/post/11310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11310</guid><dc:creator><![CDATA[lolobyte]]></dc:creator><pubDate>Mon, 16 Jan 2017 20:43:09 GMT</pubDate></item></channel></rss>
