<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[One calendar wont load]]></title><description><![CDATA[<p dir="auto">Hi!<br />
I have problem with one of my calendars that wont show events. The problem started when updating to v2.13.0 and the calendar module caused the mirror to only show a blank screen. I solved it by outcomment the module and haven’t had time to dig into it for months until now.<br />
The problem back then I think was that I had changed the calendar names, so the url’s were wrong, so now I have solved it to show two calendars, but cannot see the last calendar’s event. I have tripple checked the ical-address, so that’s not the problem now. I have also gone through this link: <a href="https://github.com/MichMich/MagicMirror/issues/839" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues/839</a> and tried to see if I got the same problem by run <code>npm start dev</code> but I wont get the same error message. This is my error message:</p>
<pre><code>&gt; magicmirror@2.13.0 start /home/pi/MagicMirror
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
/home/pi/MagicMirror/node_modules/electron/dist/electron: /lib/arm-linux-gnueabihf/libdbus-1.so.3: no version information available (required by /home/pi/MagicMirror/node_modules/electron/dist/electron)
[2020-12-30 22:08:23.415] [LOG]    Starting MagicMirror: v2.13.0
[2020-12-30 22:08:23.433] [LOG]    Loading config ...
[2020-12-30 22:08:23.447] [LOG]    Loading module helpers ...
[2020-12-30 22:08:23.451] [LOG]    No helper found for module: alert.
[2020-12-30 22:08:23.556] [LOG]    Initializing new module helper ...
[2020-12-30 22:08:23.558] [LOG]    Module helper loaded: updatenotification
[2020-12-30 22:08:23.564] [LOG]    Initializing new module helper ...
[2020-12-30 22:08:23.567] [LOG]    Module helper loaded: mmm-systemtemperature
[2020-12-30 22:08:23.570] [LOG]    No helper found for module: clock.
[2020-12-30 22:08:24.566] [LOG]    Initializing new module helper ...
[2020-12-30 22:08:24.569] [LOG]    Module helper loaded: calendar
[2020-12-30 22:08:24.677] [LOG]    Initializing new module helper ...
[2020-12-30 22:08:24.678] [LOG]    Module helper loaded: MMM-YrThen
[2020-12-30 22:08:25.787] [LOG]    Initializing new module helper ...
[2020-12-30 22:08:25.789] [LOG]    Module helper loaded: mmm-weatherchart
[2020-12-30 22:08:25.844] [LOG]    Initializing new module helper ...
[2020-12-30 22:08:25.845] [LOG]    Module helper loaded: newsfeed
[2020-12-30 22:08:25.846] [LOG]    All module helpers loaded.
[2020-12-30 22:08:26.086] [LOG]    Starting server on port 8080 ...
[2020-12-30 22:08:26.114] [LOG]    Server started ...
[2020-12-30 22:08:26.116] [LOG]    Connecting socket for: updatenotification
[2020-12-30 22:08:26.118] [LOG]    Connecting socket for: mmm-systemtemperature
[2020-12-30 22:08:26.119] [LOG]    Starting node helper: mmm-systemtemperature
[2020-12-30 22:08:26.120] [LOG]    Connecting socket for: calendar
[2020-12-30 22:08:26.121] [LOG]    Starting node helper for: calendar
[2020-12-30 22:08:26.122] [LOG]    Connecting socket for: MMM-YrThen
[2020-12-30 22:08:26.124] [LOG]    MMM-YrThen 12/30/2020 10:08:26 PM: Starting helper for MMM-YrThen
[2020-12-30 22:08:26.125] [LOG]    Connecting socket for: mmm-weatherchart
[2020-12-30 22:08:26.126] [LOG]    Starting node helper: mmm-weatherchart
[2020-12-30 22:08:26.129] [LOG]    Connecting socket for: newsfeed
[2020-12-30 22:08:26.131] [LOG]    Starting node helper for: newsfeed
[2020-12-30 22:08:26.133] [LOG]    Sockets connected &amp; modules started ...
Fontconfig warning: "/etc/fonts/fonts.conf", line 86: unknown element "blank"
[2020-12-30 22:08:26.336] [ERROR]  Whoops! There was an uncaught exception...
[2020-12-30 22:08:26.341] [ERROR]  Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
    at Server.setupListenHandle [as _listen2] (net.js:1226:14)
    at listenInCluster (net.js:1274:12)
    at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
    at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
  code: 'EADDRINUSE',
  errno: 'EADDRINUSE',
  syscall: 'listen',
  address: '127.0.0.1',
  port: 8080
[2020-12-30 22:08:26.363] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[2020-12-30 22:08:26.366] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
[2020-12-30 22:08:26.380] [LOG]    Launching application.
<p dir="auto">I have also checked the <code>ical.js</code> solution, but I don’t know how to solve it, because I only have a folder with that name and cannot create a file.<br />
I don’t have a lot of programming knowledges so please kind answers :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/14322/one-calendar-wont-load</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 07:37:25 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14322.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Dec 2020 21:28:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to One calendar wont load on Wed, 30 Dec 2020 22:48:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kvicksson" aria-label="Profile: kvicksson">@<bdi>kvicksson</bdi></a> that code will be in the new release on Friday, 1/1</p>
]]></description><link>https://forum.magicmirror.builders/post/86399</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86399</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 30 Dec 2020 22:48:12 GMT</pubDate></item><item><title><![CDATA[Reply to One calendar wont load on Wed, 30 Dec 2020 22:47:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kvicksson" aria-label="Profile: kvicksson">@<bdi>kvicksson</bdi></a> if u download the ics file, put the url in a browser on your pc, and can send me the file<br />
I will look at it…</p>
<p dir="auto">my email in the same user-defined as here at Gmail.</p>
<p dir="auto">its a text file, so u can edit /cleanse it if u need to</p>
<p dir="auto">that error happened in the 1st fix for Microsoft timezone names.  I never thought  the lookup i built would fail…  oops…</p>
]]></description><link>https://forum.magicmirror.builders/post/86398</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86398</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 30 Dec 2020 22:47:42 GMT</pubDate></item><item><title><![CDATA[Reply to One calendar wont load on Wed, 30 Dec 2020 22:18:34 GMT]]></title><description><![CDATA[<p dir="auto">Update: solved the problem by using your solution here: <a href="https://forum.magicmirror.builders/topic/13770/2-13-calendar-fix-for-office-365-users">https://forum.magicmirror.builders/topic/13770/2-13-calendar-fix-for-office-365-users</a> but I don’t have a Office 365-account.<br />
Thanks for the solution!!</p>
]]></description><link>https://forum.magicmirror.builders/post/86396</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86396</guid><dc:creator><![CDATA[kvicksson]]></dc:creator><pubDate>Wed, 30 Dec 2020 22:18:34 GMT</pubDate></item><item><title><![CDATA[Reply to One calendar wont load on Wed, 30 Dec 2020 21:55:53 GMT]]></title><description><![CDATA[<p dir="auto">Ok, so maybe I had something running in the background that I couldn’t see. When I ran <code>npm start dev</code> I got this error instead:</p>
<pre><code>[2020-12-30 22:53:03.906] [ERROR]  Whoops! There was an uncaught exception...
[2020-12-30 22:53:03.908] [ERROR]  TypeError: Cannot read property 'iana' of undefined
    at getIanaTZFromMS (/home/pi/MagicMirror/node_modules/node-ical/ical.js:108:30)
    at /home/pi/MagicMirror/node_modules/node-ical/ical.js:175:23
    at Object.DTSTART (/home/pi/MagicMirror/node_modules/node-ical/ical.js:457:32)
    at Object.handleObject (/home/pi/MagicMirror/node_modules/node-ical/ical.js:483:39)
    at Object.parseLines (/home/pi/MagicMirror/node_modules/node-ical/ical.js:534:18)
    at Object.parseICS (/home/pi/MagicMirror/node_modules/node-ical/ical.js:590:18)
    at Object.sync.parseICS (/home/pi/MagicMirror/node_modules/node-ical/node-ical.js:190:15)
    at Object.autodetect.parseICS (/home/pi/MagicMirror/node_modules/node-ical/node-ical.js:221:17)
    at Request._callback (/home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:79:22)
    at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:185:22)
]]></description><link>https://forum.magicmirror.builders/post/86394</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86394</guid><dc:creator><![CDATA[kvicksson]]></dc:creator><pubDate>Wed, 30 Dec 2020 21:55:53 GMT</pubDate></item><item><title><![CDATA[Reply to One calendar wont load on Wed, 30 Dec 2020 21:44:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks! but it only seems like I have one instance running because now nothing is running.</p>
]]></description><link>https://forum.magicmirror.builders/post/86393</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86393</guid><dc:creator><![CDATA[kvicksson]]></dc:creator><pubDate>Wed, 30 Dec 2020 21:44:49 GMT</pubDate></item><item><title><![CDATA[Reply to One calendar wont load on Wed, 30 Dec 2020 21:32:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kvicksson" aria-label="Profile: kvicksson">@<bdi>kvicksson</bdi></a> u have another mm running already.</p>
<p dir="auto">pm2 stop 0</p>
]]></description><link>https://forum.magicmirror.builders/post/86392</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86392</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 30 Dec 2020 21:32:13 GMT</pubDate></item></channel></rss>
