<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After update, nothing happens.]]></title><description><![CDATA[<p dir="auto">I noticed that <em>updatenotification</em> hadn’t notified me of any updates for ages, so I got MM to do updates with the usual  <code>git pull &amp;&amp; npm install</code>.</p>
<p dir="auto">PM2 start MM, and nothing happens.<br />
Rebooted Pi, still nothing.<br />
CPU sits at 25/26%, but no MM, just the Pi desktop.</p>
<p dir="auto">Any ideas, please?<br />
Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14342/after-update-nothing-happens</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 09:11:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14342.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 01 Jan 2021 12:52:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After update, nothing happens. on Mon, 01 Feb 2021 15:16:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: richard238">@<bdi>richard238</bdi></a> outside modules have certainly changed since then. base is once every 90 days</p>
]]></description><link>https://forum.magicmirror.builders/post/88061</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88061</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Feb 2021 15:16:57 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Mon, 01 Feb 2021 09:48:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/86585">After update, nothing happens.</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> updatenotification  will continue to advise things that have changed…</p>
<p dir="auto">A month on, and I’ve not had any update prompts, is that correct?<br />
Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/88056</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88056</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Mon, 01 Feb 2021 09:48:26 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 15:37:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> my pleasure.</p>
]]></description><link>https://forum.magicmirror.builders/post/86598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86598</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Jan 2021 15:37:33 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 15:36:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">We found a bug and a fix. And it was all done in a day or so! :)</p>
<p dir="auto">Looks like a great result all round then where we’ve all learned something.</p>
<p dir="auto">Thank you for your help.<br />
Richard.</p>
]]></description><link>https://forum.magicmirror.builders/post/86597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86597</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Sat, 02 Jan 2021 15:36:19 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 15:35:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> i will update my scripts to check and advise.</p>
<p dir="auto">but my scripts are optional. I doubt the base will check. technically only supports pi3 and 4, but I try to make it to run anywhere</p>
]]></description><link>https://forum.magicmirror.builders/post/86596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86596</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Jan 2021 15:35:59 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 15:31:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/86591">After update, nothing happens.</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> just FYI  we were able to reproduce your problem on Jessie. So os upgrade, or downgrade electron were the only options</p>
<p dir="auto">Does that mean a change to the documentation, or have the install/update script(s) check for OS level before proceeding?  (Or both, of course.)<br />
There must be many, many MM installs out there running on old OSs.</p>
]]></description><link>https://forum.magicmirror.builders/post/86595</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86595</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Sat, 02 Jan 2021 15:31:13 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 15:30:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> use pm2, u should have been prompted during my scripted install.</p>
<p dir="auto">but use the fixuppm2 instructions here, last entry on the page</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/86594</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86594</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Jan 2021 15:30:36 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 15:28:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/86590">After update, nothing happens.</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> all of the messages are normal.<br />
maybe u started w pm2 before</p>
<p dir="auto">Rebooted, no change.  Not a worry, just curious.<br />
How though do I get MM to auto start at boot?</p>
]]></description><link>https://forum.magicmirror.builders/post/86593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86593</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Sat, 02 Jan 2021 15:28:38 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 15:06:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> just FYI  we were able to reproduce your problem on Jessie. So os upgrade, or downgrade electron were the only options</p>
]]></description><link>https://forum.magicmirror.builders/post/86591</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86591</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Jan 2021 15:06:44 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 15:05:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> all of the messages are normal.<br />
]]></description><link>https://forum.magicmirror.builders/post/86590</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86590</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Jan 2021 15:05:16 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 15:02:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>rue" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
[02.01.2021 14:46.31.149] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
[02.01.2021 14:46.31.360] [LOG]   Create new calendar fetcher for url: https://calendar.google.com/calendar/##################################### Interval: 300000
[02.01.2021 14:46.31.366] [LOG]   Create new news fetcher for url: http://feeds.reuters.com/reuters/UKTopNews - Interval: 120000
[02.01.2021 14:46.31.437] [LOG]   Create new news fetcher for url: http://feeds.skynews.com/feeds/rss/world.xml - Interval: 120000
[02.01.2021 14:46.31.447] [INFO]  Checking git for module: MMM-doomsDay
[02.01.2021 14:46.31.455] [INFO]  Checking git for module: MMM-MysqlQuery
[02.01.2021 14:46.32.473] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
[02.01.2021 14:46.33.722] [INFO]  Calendar-Fetcher: Broadcasting 4 events.
[02.01.2021 14:46.35.400] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
[02.01.2021 14:48.32.644] [INFO]  Newsfeed-Fetcher: Broadcasting 10 items.
<pre><code>ipWhitelist: [],
	//ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120",],
	language: 'en',
	timeFormat: 24,
<p dir="auto">I guess changing it to logLevel: []    ?</p>
]]></description><link>https://forum.magicmirror.builders/post/86589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86589</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Sat, 02 Jan 2021 15:02:08 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 14:58:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> notice its logLevel, second l is capital</p>
]]></description><link>https://forum.magicmirror.builders/post/86588</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86588</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Jan 2021 14:58:42 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 14:57:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> can u show me some of the messages?</p>
]]></description><link>https://forum.magicmirror.builders/post/86587</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86587</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Jan 2021 14:57:26 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 14:57:50 GMT]]></title><description><![CDATA[<p dir="auto">I copied my config.js into the new install, and deleted all the old commented-out module junk I was no longer using.<br />
Added the 'loglevel: [… ’ line, doesn’t yet seem to have made any difference. Reboot required perhaps?</p>
<p dir="auto">2.14?   Package.Json = “version” : “2.14.0”</p>
<p dir="auto">Electron is 8.5</p>
<pre><code>pi@magicmirror:~/MagicMirror $ grep version node_modules/electron/package.json
  "version": "8.5.5"
]]></description><link>https://forum.magicmirror.builders/post/86586</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86586</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Sat, 02 Jan 2021 14:57:50 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 14:44:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> updatenotification  will continue to advise things that have changed…</p>
<p dir="auto">are u at 2.14 w 8.5 electron?</p>
]]></description><link>https://forum.magicmirror.builders/post/86585</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86585</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Jan 2021 14:44:00 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 14:42:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> edit the config.js, there us a new logLevel setting, make sure debug is not included</p>
]]></description><link>https://forum.magicmirror.builders/post/86584</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86584</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Jan 2021 14:42:24 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 14:31:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> said in <a href="/post/86578">After update, nothing happens.</a>:</p>
<p dir="auto">Old MM FTPd to NAS.<br />
Installing new OS now, on a different SD card so I can go back if absolutely necessary.<br />
My plan is to build a new MM as the old one had a lot of clutter - old unused modules etc.<br />
Taking the opportunity for a fresh start. I’ll let you know how it goes…</p>
<p dir="auto">14:24<br />
All done.<br />
MM back just as it was with custom CSS, but this time using only the modules installed that I actually need.<br />
MM accessible from any LAN attached device as I don’t have it setup as a mirror anywhere.<br />
The terminal window is showing a constatnt log of what’s happening. Is that correct - I don’t remember it from MM_OLD?</p>
<p dir="auto">And will the <em>update notification</em> module do anything now, or do I need to do anything?</p>
]]></description><link>https://forum.magicmirror.builders/post/86582</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86582</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Sat, 02 Jan 2021 14:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Sat, 02 Jan 2021 12:57:09 GMT]]></title><description><![CDATA[<p dir="auto">Old MM FTPd to NAS.<br />
]]></description><link>https://forum.magicmirror.builders/post/86578</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86578</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Sat, 02 Jan 2021 12:57:09 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Fri, 01 Jan 2021 19:24:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a></p>
<p dir="auto">copy your MagicMirror  folder to save it somewhere<br />
u can zip it to to save space</p>
<p dir="auto">install buster on your sd card<br />
run the installer to get things setup<br />
restore you MM zip file<br />
erase the node_modules folder<br />
npm install  (this should put on the newer electron)<br />
npm start</p>
]]></description><link>https://forum.magicmirror.builders/post/86539</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86539</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Jan 2021 19:24:27 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Fri, 01 Jan 2021 19:10:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/86532">After update, nothing happens.</a>:</p>
<p dir="auto">npm install electron@6.1.12</p>
<p dir="auto">Sam, you’re a genius!</p>
<p dir="auto">That’s fixed it.<br />
This will only happen again in the not too distant future I’m sure, so would I be better off installing a newer OS?<br />
And then how do I recreate my MM on said new OS?</p>
<p dir="auto">I’m going to logoff for now, thanks again for your help today.<br />
More tomorrow I’m sure.<br />
Kind regards,<br />
Richard.</p>
]]></description><link>https://forum.magicmirror.builders/post/86537</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86537</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Fri, 01 Jan 2021 19:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Fri, 01 Jan 2021 18:28:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/richard238" aria-label="Profile: Richard238">@<bdi>Richard238</bdi></a> ok, thx. problem is new electron won’t run on Jessie anymore…</p>
<p dir="auto">I don’t know if this will work.</p>
<p dir="auto">from. the old mm folder</p>
<p dir="auto">rm -rf node_modules/electron<br />
npm install electron@6.1.12<br />
then npm start</p>
]]></description><link>https://forum.magicmirror.builders/post/86532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86532</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Jan 2021 18:28:53 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Fri, 01 Jan 2021 18:15:02 GMT]]></title><description><![CDATA[<p dir="auto">pi@pi_mirror:~ $ lsb_release -a<br />
No LSB modules are available.<br />
Distributor ID:	Raspbian<br />
Description:	Raspbian GNU/Linux 8.0 (jessie)<br />
Release:	8.0<br />
Codename:	jessie<br />
pi@pi_mirror:~ $</p>
]]></description><link>https://forum.magicmirror.builders/post/86529</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86529</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Fri, 01 Jan 2021 18:15:02 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Fri, 01 Jan 2021 18:25:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> one more diag command</p>
<p dir="auto">lsb_release -a</p>
]]></description><link>https://forum.magicmirror.builders/post/86528</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86528</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Jan 2021 18:25:34 GMT</pubDate></item><item><title><![CDATA[Reply to After update, nothing happens. on Fri, 01 Jan 2021 16:03:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/86520">After update, nothing happens.</a>:</p>
<p dir="auto">grep version node_modules/electron/package.json</p>
<p dir="auto">pi@pi_mirror:~/MagicMirror__RL1 $ grep version node_modules/electron/package.json<br />
“type”: “version”,<br />
“version”: “8.5.3”<br />
pi@pi_mirror:~/MagicMirror__RL1 $</p>
]]></description><link>https://forum.magicmirror.builders/post/86521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86521</guid><dc:creator><![CDATA[Richard238]]></dc:creator><pubDate>Fri, 01 Jan 2021 16:03:24 GMT</pubDate></item></channel></rss>
