<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[apperance]]></title><description><![CDATA[<p dir="auto">Hello,<br />
happy new year and thanks a lot for the module! But the apperance is not, what I exspected:</p>
<p dir="auto"><img src="/assets/uploads/files/1609680633013-mygarbage.jpg" alt="mygarbage.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Region is “bottom_center”, it doesn’t change when I change to another bottom region or when I use a shorter date-format.</p>
<p dir="auto">Any suggestions are welcome!</p>
]]></description><link>https://forum.magicmirror.builders/topic/14359/apperance</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 07:39:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14359.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 Jan 2021 13:34:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to apperance on Sun, 03 Jan 2021 14:00:41 GMT]]></title><description><![CDATA[<p dir="auto">Some of the modules you need to customize things like width and or height in the custom.css file to override the default css settings for that module.<br />
Using the Developer Tools in the view option can help to visualize where the problem or fix may be.</p>
]]></description><link>https://forum.magicmirror.builders/post/86646</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86646</guid><dc:creator><![CDATA[ankonaskiff17]]></dc:creator><pubDate>Sun, 03 Jan 2021 14:00:41 GMT</pubDate></item></channel></rss>
