<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-aviationwx (Aviation weather)]]></title><description><![CDATA[<p dir="auto">This module displays METAR data (weather reporting information normally used for aviation purposes) and, where available, FAA delay data for airports in the continental United States.</p>
<p dir="auto">This is my first MM module (and first GitHub repo for that matter), so feedback and improvements are welcome!</p>
<p dir="auto"><img src="/uploads/files/1484596380894-preview.png" alt="0_1484596380090_preview.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/1436/mmm-aviationwx-aviation-weather</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 01:26:20 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1436.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Jan 2017 19:54:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Thu, 23 Mar 2023 12:35:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hawkeyepilot69" aria-label="Profile: hawkeyepilot69">@<bdi>hawkeyepilot69</bdi></a> I have u a link to the instructions on how to deal w that problem.</p>
<p dir="auto">as there are multiple libraries that cause the problem, I am trying to teach you how to find the problem by yourself and how to fix it.</p>
<p dir="auto">vs just giving u the answer and having you come back for the next same failure</p>
]]></description><link>https://forum.magicmirror.builders/post/108357</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108357</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 23 Mar 2023 12:35:42 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Wed, 22 Mar 2023 19:57:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Like I had said, im very new to this and dont know how to do that.</p>
]]></description><link>https://forum.magicmirror.builders/post/108355</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108355</guid><dc:creator><![CDATA[hawkeyepilot69]]></dc:creator><pubDate>Wed, 22 Mar 2023 19:57:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Mon, 20 Mar 2023 01:58:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hawkeyepilot69" aria-label="Profile: hawkeyepilot69">@<bdi>hawkeyepilot69</bdi></a> Mykle1 is not available currently.</p>
<p dir="auto">did u add the missing library like I advised?</p>
]]></description><link>https://forum.magicmirror.builders/post/108283</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108283</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 20 Mar 2023 01:58:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Sun, 19 Mar 2023 22:18:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> is this module no longer working?</p>
]]></description><link>https://forum.magicmirror.builders/post/108279</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/108279</guid><dc:creator><![CDATA[hawkeyepilot69]]></dc:creator><pubDate>Sun, 19 Mar 2023 22:18:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Sun, 10 Dec 2017 22:06:12 GMT]]></title><description><![CDATA[<p dir="auto">Please move all further inquiries regarding MMM-PilotWX to this topic:</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/topic/5686/mmm-pilotwx">https://forum.magicmirror.builders/topic/5686/mmm-pilotwx</a></p>
]]></description><link>https://forum.magicmirror.builders/post/32165</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32165</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 10 Dec 2017 22:06:12 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Sat, 09 Dec 2017 03:20:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/320fan" aria-label="Profile: 320fan">@<bdi>320fan</bdi></a></p>
<p dir="auto">Wind speed now displays as such:<br />
<code>310/4KT</code></p>
<p dir="auto">Pressure added to static view and formatted for both views as such:<br />
<code>29.91Hg</code></p>
<p dir="auto">Config option added for time format, Zulu or Local in both views:<br />
<code>time: "Zulu",</code> = (19:10Z)<br />
<code>time: "Local",</code> = (14:10)</p>
<p dir="auto"><a href="https://github.com/mykle1/MMM-PilotWX" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/mykle1/MMM-PilotWX</a></p>
<p dir="auto"><code>git pull</code> in your PilotWX directory for update or install as usual.</p>
]]></description><link>https://forum.magicmirror.builders/post/32123</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32123</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 09 Dec 2017 03:20:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Fri, 08 Dec 2017 11:49:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Okay, no problem. Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/32105</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32105</guid><dc:creator><![CDATA[320fan]]></dc:creator><pubDate>Fri, 08 Dec 2017 11:49:50 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Fri, 08 Dec 2017 11:48:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/320fan" aria-label="Profile: 320fan">@<bdi>320fan</bdi></a></p>
<p dir="auto">Good morning</p>
<p dir="auto">29.91Hg . Ok, I can work on that later. I’m getting ready for my work day right now</p>
]]></description><link>https://forum.magicmirror.builders/post/32104</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32104</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 08 Dec 2017 11:48:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Fri, 08 Dec 2017 11:46:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Hi again.</p>
<p dir="auto">Yea, 29.91Hg.</p>
]]></description><link>https://forum.magicmirror.builders/post/32103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32103</guid><dc:creator><![CDATA[320fan]]></dc:creator><pubDate>Fri, 08 Dec 2017 11:46:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Fri, 08 Dec 2017 11:43:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/320fan" aria-label="Profile: 320fan">@<bdi>320fan</bdi></a> said in <a href="/post/32100">MMM-aviationwx (Aviation weather)</a>:</p>
<p dir="auto">altim_in_hg 29.911417/altim_in_hg</p>
<p dir="auto">Forgot I rounded this. My bad. So this should be</p>
<p dir="auto"><code>29.91/hg</code> ?</p>
]]></description><link>https://forum.magicmirror.builders/post/32102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32102</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 08 Dec 2017 11:43:38 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Fri, 08 Dec 2017 08:38:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> said in <a href="/post/32093">MMM-aviationwx (Aviation weather)</a>:</p>
<p dir="auto">pressure must be like xx.xx (not like xx as it is)</p>
<p dir="auto">Tell that to the API. That’s the data being given. I just display it.</p>
<p dir="auto">For example:</p>
<p dir="auto"><a href="https://aviationweather.gov/adds/dataserver_current/httpparam?dataSource=metars&amp;requestType=retrieve&amp;format=xml&amp;stationString=UUDD&amp;hoursBeforeNow=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://aviationweather.gov/adds/dataserver_current/httpparam?dataSource=metars&amp;requestType=retrieve&amp;format=xml&amp;stationString=UUDD&amp;hoursBeforeNow=1</a></p>
<pre><code>altim_in_hg 29.911417/altim_in_hg
<p dir="auto">I think that this API converts pressure in hPa from raw_data (like Q1013) into hg by simply dividing by coefficient.</p>
]]></description><link>https://forum.magicmirror.builders/post/32100</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32100</guid><dc:creator><![CDATA[320fan]]></dc:creator><pubDate>Fri, 08 Dec 2017 08:38:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Fri, 08 Dec 2017 01:59:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/320fan" aria-label="Profile: 320fan">@<bdi>320fan</bdi></a> said in <a href="/post/32073">MMM-aviationwx (Aviation weather)</a>:</p>
<p dir="auto">No possibility to set custom number of airports for the “Static” view</p>
<p dir="auto">Yes, at the moment you MUST use 8. However, another user has graciously asked if he could modify some things and issue a PR that I will merge into the module. That is one of the changes.</p>
<p dir="auto">My next proposal is to remove line “Station Conditions” for the Static view.</p>
<p dir="auto">You mean the headers, “Station” and “Conditions”? Add this to your custom.css file and it will remove both</p>
<pre><code>.MMM-PilotWX .station {
  display: none;
<p dir="auto">And this to change to any color for rotating</p>
<pre><code>.MMM-PilotWX .bottom_bar {
  color: yellow;
<p dir="auto">Is it possible to use a same font/font size, like for standart modules (like "calendars, “weather”, etc.</p>
<p dir="auto">Use css to customize to your liking</p>
<p dir="auto">Alignment will always be an issue because the module is not set in a table. I did mention above that I am not capable of using tables yet. SO, for the time being, left regions will be better suited to the module</p>
<p dir="auto">Taking specific portions of the raw_text for display is beyond me.</p>
]]></description><link>https://forum.magicmirror.builders/post/32093</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32093</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 08 Dec 2017 01:59:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Thu, 07 Dec 2017 16:45:40 GMT]]></title><description><![CDATA[<ul>
<li>one moew issue:<br />
<img src="/assets/uploads/files/1512664940379-5.png" alt="0_1512664940182_5.png" class=" img-fluid img-markdown" /></li>
</ul>
<p dir="auto">Datas from: <a href="https://aviationweather.gov/adds/dataserver_current/httpparam?dataSource=metars&amp;requestType=retrieve&amp;format=xml&amp;stationString=UUDD&amp;hoursBeforeNow=1" target="_blank" rel="noopener noreferrer nofollow ugc">https://aviationweather.gov/adds/dataserver_current/httpparam?dataSource=metars&amp;requestType=retrieve&amp;format=xml&amp;stationString=UUDD&amp;hoursBeforeNow=1</a></p>
<pre><code>raw_text
UUDD 071630Z 34005MPS 9999 BKN022 M04/M08 Q1009 R88/520295 NOSIG
/raw_text
sky_condition sky_cover="BKN" cloud_base_ft_agl="2200"
<p dir="auto">It must be <strong>BKN022</strong>, not <strong>BKN2200</strong>.</p>
]]></description><link>https://forum.magicmirror.builders/post/32077</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32077</guid><dc:creator><![CDATA[320fan]]></dc:creator><pubDate>Thu, 07 Dec 2017 16:45:40 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Thu, 07 Dec 2017 14:04:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Hi again.</p>
<p dir="auto">As I can see you continue to improve your mode - thats fine, thanks. Now I’ve some time for tests of this updated module. My points are:</p>
<ol>
<li>No possibility to set custom number of airports for the “Static” view: for example, line like:</li>
</ol>
<pre><code>ICAO: "UUDD,UUWW,UUEE,UUOO,UWKD,URMT,ULLI,UWWW",  // separated by comma only
<p dir="auto">works fine (8 ICAO codes), but when I’m decrease/increase number of ICAO codes it doesn’t work: “Loading PilotWX…” and thats all.</p>
<ol start="2">
<li>
<p dir="auto">My next proposal is to remove line “Station Conditions” for the Static view. It’s a little bit pointless ;)</p>
</li>
<li>
<p dir="auto">For the “Rotating” view: the whole text alltime yellow. How I can change that?<br />
<img src="/assets/uploads/files/1512652922637-1.jpg" alt="0_1512652922149_1.jpg" class=" img-fluid img-markdown" /></p>
</li>
</ol>
<p dir="auto">3.1) For the “Rotating” view: pressure must be like xx.xx (not like xx as it is). In aircraft you must use all four digits for all the time. But for me - pressure in hectopascals (like 1019, without digits after comma) better in any case. Hovewer, in any case 1 hg = 33.863886666667 hPa. hg used for US airports at all the time, for EU/RU airports - hectopascals are the standard.<br />
3.2) And the last one regarding pressure - it’s nice to have it for a “Standard” view too - it’s a really important information.</p>
<ol start="4">
<li>
<p dir="auto">About time, which I can observe in the end of the line (tt:tt): I would ask you to display a UTC (Zulu) time, not a local time. So, thats the standard of METAR/TAF ;) In that case you display it like (ttttZ) or (tt:ttZ), and Zulu will be a remider for that.</p>
</li>
<li>
<p dir="auto">Thanks for visibility in KM, thats very usefull. And to have a same view - please, change speed in knots as “KT”, not a “kt”.</p>
</li>
<li>
<p dir="auto">For the “Loading PilotWX…” message - I would like to propose next code:</p>
</li>
</ol>
<pre><code>        if (!this.loaded) {
            wrapper.classList.add("wrapper");
//            wrapper.innerHTML = "Loading PilotWX . .";
//            wrapper.className = "bright light small";
              wrapper.innerHTML = (this.loaded) ? this.translate("EMPTY") : this.translate("LOADING");
              wrapper.className = "small dimmed";
            return wrapper;
<p dir="auto">In that case this module will take into account locale settings for correct displaying of “Loading” message.</p>
<ol start="7">
<li>In case of no cloudbase layer classification (like "BKN/OVC/etc.) you may see a OVX text:<br />
<img src="/assets/uploads/files/1512653902047-2.jpg" alt="0_1512653901717_2.jpg" class=" img-fluid img-markdown" /><br />
Thats not correct; the reply from server in that case is:  sky_condition sky_cover=“OVX” cloud_base_ft_agl=“0”</li>
</ol>
<p dir="auto">The right way - to display data directly from a  string, as example:<br />
raw_text&gt; URMT 071330Z 32006MPS 0650 0550NE R25/0800N +SHSN <strong>VV002</strong> M01/M01 Q1010 R25/290255 NOSIG RMK <strong>QBB080</strong> OBST OBSC QFE719 raw_text&gt;</p>
<ul>
<li>VV002 means vertical visibility in hundred of feets or QBB080 means vertical visibility in meters (this code not applicable for all airports).</li>
</ul>
<ol start="8">
<li>And if case of aligment to the right:</li>
</ol>
<pre><code>               {
                        module: 'MMM-PilotWX',
                        header: 'Aviation weather',
                        position: 'bottom_right',
                        disabled: false,
<p dir="auto">the whole layout is shifted to the right; Is it possible to align/to stretch all elements like for the “Weather forecast” plugin?</p>
<p dir="auto"><img src="/assets/uploads/files/1512655064218-4.jpg" alt="0_1512655063824_4.jpg" class=" img-fluid img-markdown" /></p>
<ol start="9">
<li>Is it possible to use a same font/font size, like for standart modules (like "calendars, “weather”, etc.) to keep a same view for the whole mirror? It’s not a big deal, but in that case we can make a mirror looks more “arranged”.</li>
</ol>
<p dir="auto">And last, but do not least: <a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a>, thanks again for your job.</p>
]]></description><link>https://forum.magicmirror.builders/post/32073</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/32073</guid><dc:creator><![CDATA[320fan]]></dc:creator><pubDate>Thu, 07 Dec 2017 14:04:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Mon, 04 Dec 2017 02:42:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Why Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/31916</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31916</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 04 Dec 2017 02:42:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Mon, 04 Dec 2017 03:14:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> said in <a href="/post/31912">MMM-aviationwx (Aviation weather)</a>:</p>
<p dir="auto">Can you do that?  Thanks!  LOL</p>
<p dir="auto">I can, but I didn’t. ;-)</p>
<p dir="auto">However, I did make a config option for Kilometers if you would rather that than Statute Miles for Visibility. :-)</p>
<p dir="auto">So, for those interested, you can do another <code>git pull</code> in the MMM-PilotWX directory to update or download and install as usual.<br />
<p dir="auto"><img src="/assets/uploads/files/1512356888690-3.png" alt="0_1512356887035_3.PNG" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1512356895287-4.png" alt="0_1512356894566_4.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">I don’t know what the standard for this type of display is but it seems to me that 260/6kt is easily readable, whereas 3KM for visibility is not. Would not 3/km be better? Or is that not what you pilots are used to? Please clarify. Thanks. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/31915</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31915</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 04 Dec 2017 03:14:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Mon, 04 Dec 2017 00:56:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> IN PURPLE?  BUT just on Fridays and Wednesdays…the other days I want it blue.  Well unless the wind is blowing from the west then I need it hot pink or orange…no wait orange is for the days it’s blowing from the east at 2.2mph…</p>
]]></description><link>https://forum.magicmirror.builders/post/31912</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31912</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 04 Dec 2017 00:56:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Mon, 04 Dec 2017 00:45:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> said in <a href="/post/31910">MMM-aviationwx (Aviation weather)</a>:</p>
<p dir="auto">Can it do this?  ¿</p>
<p dir="auto"><strong>HAHA</strong> :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/31911</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31911</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 04 Dec 2017 00:45:57 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Mon, 04 Dec 2017 00:45:18 GMT]]></title><description><![CDATA[<p dir="auto">Can it do this?  ¿</p>
]]></description><link>https://forum.magicmirror.builders/post/31910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31910</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Mon, 04 Dec 2017 00:45:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Mon, 04 Dec 2017 00:36:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xt16johnny" aria-label="Profile: XT16Johnny">@<bdi>XT16Johnny</bdi></a></p>
<p dir="auto">I wouldn’t have a clue what a Statue Mile looks like out of the window!</p>
<p dir="auto"><img src="/assets/uploads/files/1512347801947-1.png" alt="0_1512347800710_1.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/31909</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31909</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 04 Dec 2017 00:36:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Mon, 04 Dec 2017 00:16:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xt16johnny" aria-label="Profile: XT16Johnny">@<bdi>XT16Johnny</bdi></a></p>
<p dir="auto">Just in case others want the @ symbol as a separator between wind speed and direction I made it a config option.</p>
<pre><code>sym: "@",  // or sym: "/",
<p dir="auto">Result:</p>
<p dir="auto"><img src="/assets/uploads/files/1512346381234-1.png" alt="0_1512346379177_1.PNG" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1512346389489-2.png" alt="0_1512346388412_2.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">So, for those interested, you can do a <code>git pull</code> in the MMM-PilotWX directory to update or download and install as usual.<br />
]]></description><link>https://forum.magicmirror.builders/post/31908</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31908</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Mon, 04 Dec 2017 00:16:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Sun, 03 Dec 2017 23:10:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xt16johnny" aria-label="Profile: XT16Johnny">@<bdi>XT16Johnny</bdi></a> said in <a href="/post/31904">MMM-aviationwx (Aviation weather)</a>:</p>
<p dir="auto">@mkyle1 - Great job on the module, it looks superb. I’ll be adding it to my mirror very soon.</p>
<p dir="auto">Thanks, I appreciate that. I did it as a request from a user so forgive my lack of aviation understanding.</p>
<p dir="auto">Typically winds reported at xxx degrees at yy kts and shorthand would be 260/05 rather than @.</p>
<p dir="auto">That’s easy enough to fix. I’ll take care of that. Maybe even as soon as tonight.</p>
<p dir="auto">As far as the Statute Mile/KM situation is concerned. The API only provides Statute Mile (SM) in the data. I didn’t do any conversions because I was going to move to another API that provided both, making it easier to give you a config option and a whole lot less coding for me. However, I will look at it again and see what it involves. Worst case scenario you’d have to wait for my moving to the other API but I can’t tell you when that would be. :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/31906</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31906</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 03 Dec 2017 23:10:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Sun, 03 Dec 2017 22:22:04 GMT]]></title><description><![CDATA[<p dir="auto">@mkyle1 - Great job on the module, it looks superb. I’ll be adding it to my mirror very soon.</p>
<p dir="auto">I understand you’re working on this on your own time, just a couple of config options for you if you’re in the mood to do anything more with the module ;-)</p>
<ul>
<li>Most of Eur runs on KM for the viz. I wouldn’t have a clue what a Statue Mile looks like out of the window!</li>
<li>Typically winds reported at xxx degrees at yy kts and shorthand would be 260/05 rather than @.</li>
</ul>
<p dir="auto">I would be happy enough to change this on my mirror but a config option would be (far) too advanced for me to try and implement!</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stephenmelody" aria-label="Profile: stephenmelody">@<bdi>stephenmelody</bdi></a> - Ref the crashing:<br />
First thing I’d do is check the power supply, RPi are really picky!<br />
Check out the command ‘dmesg’ - very insightful for tracking down issues as it is timestamped. This will clear on reboot so it’d need to be checked before the crash.</p>
<p dir="auto">If this is fruitless,</p>
<ul>
<li>/var/log/messages</li>
<li>/var/log/syslog</li>
<li>/var/log/kern.log</li>
</ul>
<p dir="auto">Cheers lads,</p>
<p dir="auto">Johnny</p>
]]></description><link>https://forum.magicmirror.builders/post/31904</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31904</guid><dc:creator><![CDATA[XT16Johnny]]></dc:creator><pubDate>Sun, 03 Dec 2017 22:22:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-aviationwx (Aviation weather) on Thu, 30 Nov 2017 21:44:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stephenmelody" aria-label="Profile: stephenmelody">@<bdi>stephenmelody</bdi></a> said in <a href="/post/31790">MMM-aviationwx (Aviation weather)</a>:</p>
<p dir="auto">If you have any hints of where I could start, please let me know… I don’t fancy rebuilding it from scratch… :(</p>
<p dir="auto">Well, 2.0 amps minimum on the power supply although I think 2.5 is optimum.</p>
<p dir="auto">Hints? Well, suggestion.</p>
<p dir="auto">Disable all but the default modules and run that for a day and see what happens. If all is well then introduce one at a time and test again. See how that goes for starters</p>
]]></description><link>https://forum.magicmirror.builders/post/31802</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/31802</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 30 Nov 2017 21:44:23 GMT</pubDate></item></channel></rss>
