<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can't install MMM-Navigate]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Im trying to install the MMM-Navigate module made by <a class="plugin-mentions-user plugin-mentions-a" href="/user/axled" aria-label="Profile: AxLed">@<bdi>AxLed</bdi></a>.<br />
When running</p>
<pre><code>npm install
<p dir="auto">following message return:</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm install
&gt; MagicMirror-Module-Navigate@1.4.0 install /home/pi/MagicMirror/modules/MMM-Navigate
&gt; electron-rebuild
/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/fs-extra/lib/mkdirs/make-dir.js:85
      } catch {
SyntaxError: Unexpected token {
    at new Script (vm.js:51:7)
    at createScript (vm.js:136:10)
    at Object.runInThisContext (vm.js:197:10)
    at Module._compile (internal/modules/cjs/loader.js:618:28)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
    at Module.load (internal/modules/cjs/loader.js:566:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
    at Function.Module._load (internal/modules/cjs/loader.js:498:3)
    at Module.require (internal/modules/cjs/loader.js:598:17)
    at require (internal/modules/cjs/helpers.js:11:18)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! MagicMirror-Module-Navigate@1.4.0 install: `electron-rebuild`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the MagicMirror-Module-Navigate@1.4.0 install script.
npm ERR!     /home/pi/.npm/_logs/2021-01-03T17_47_54_887Z-debug.log
<p dir="auto">When i start the MagicMirror following error in in console:</p>
<pre><code>[03.01.2021 18:56.24.542] [LOG]   Module helper loaded: MMM-Page-Selector
[03.01.2021 18:56.24.602] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 59. This version of Node.js requires
NODE_MODULE_VERSION 76. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
[03.01.2021 18:56.24.622] [ERROR] App threw an error during load
[03.01.2021 18:56.24.626] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
    at process.func [as dlopen] (electron/js2c/asar.js:140:31)
    at Object.Module._extensions..node (internal/modules/cjs/loader.js:1016:18)
    at Object.func [as .node] (electron/js2c/asar.js:140:31)
    at Module.load (internal/modules/cjs/loader.js:816:32)
    at Module._load (internal/modules/cjs/loader.js:728:14)
    at Function.Module._load (electron/js2c/asar.js:748:26)
    at Module.require (internal/modules/cjs/loader.js:853:19)
    at require (internal/modules/cjs/helpers.js:74:18)
    at bindings (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/bindings/bindings.js:112:48)
    at /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31
[03.01.2021 18:56.24.630] [ERROR] Whoops! There was an uncaught exception...
[03.01.2021 18:56.24.638] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
<p dir="auto">Can someone imagine whats the problem?</p>
<p dir="auto">Thanks in advance :)</p>
]]></description><link>https://forum.magicmirror.builders/topic/14360/can-t-install-mmm-navigate</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 12:14:06 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14360.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 03 Jan 2021 17:58:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can't install MMM-Navigate on Sun, 21 Mar 2021 20:57:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matze86" aria-label="Profile: matze86">@<bdi>matze86</bdi></a> do this</p>
<p dir="auto">from the MMM-Navigate folder</p>
<pre><code>npm rebuild epoll --update-binary
<p dir="auto">worked for me</p>
<p dir="auto">note that this compiled version won’t work if you use electron now…</p>
]]></description><link>https://forum.magicmirror.builders/post/89700</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89700</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 21 Mar 2021 20:57:01 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Fri, 19 Mar 2021 22:26:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">now i reinstalled raspberry os and still got the same error…</p>
<pre><code>[19.03.2021 23:16.00.366] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
NODE_MODULE_VERSION 76. This version of Node.js requires
NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
[19.03.2021 23:16.00.367] [LOG]   Loading module helpers ...
[19.03.2021 23:16.00.368] [LOG]   No helper found for module: alert.
[19.03.2021 23:16.00.368] [LOG]   Initializing new module helper ...
[19.03.2021 23:16.00.369] [LOG]   Module helper loaded: updatenotification
[19.03.2021 23:16.00.370] [LOG]   No helper found for module: clock.
[19.03.2021 23:16.00.374] [ERROR] Whoops! There was an uncaught exception...
[19.03.2021 23:16.00.378] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
    at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
    at Module.load (internal/modules/cjs/loader.js:653:32)
    at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    at Module.require (internal/modules/cjs/loader.js:692:17)
    at require (internal/modules/cjs/helpers.js:25:18)
    at module.exports._ (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:7:31)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/epoll.js:15:3)
    at Module._compile (internal/modules/cjs/loader.js:778:30)
[19.03.2021 23:16.00.379] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[19.03.2021 23:16.00.380] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
]]></description><link>https://forum.magicmirror.builders/post/89685</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89685</guid><dc:creator><![CDATA[matze86]]></dc:creator><pubDate>Fri, 19 Mar 2021 22:26:01 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Wed, 17 Mar 2021 21:16:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matze86" aria-label="Profile: matze86">@<bdi>matze86</bdi></a> sorry. no idea from here.i had a similar problem in one of my modules.<br />
I rewrote part of it to eliminate the troublesome library</p>
]]></description><link>https://forum.magicmirror.builders/post/89609</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89609</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 17 Mar 2021 21:16:20 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Wed, 17 Mar 2021 21:07:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">npm rebuild failed:</p>
<pre><code>pi@raspberrypi:~/MagicMirror/modules/MMM-Navigate $ npm rebuild
npm ERR! code 1
npm ERR! path /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll
npm ERR! command failed
npm ERR! command sh -c node-gyp rebuild
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@7.1.2
npm ERR! gyp info using node@14.16.0 | linux | arm
npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
npm ERR! gyp info spawn /usr/bin/python3
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args   'binding.gyp',
npm ERR! gyp info spawn args   '-f',
npm ERR! gyp info spawn args   'make',
npm ERR! gyp info spawn args   '-I',
npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/config.gypi',
npm ERR! gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args   '/home/pi/.cache/node-gyp/14.16.0/include/node/common.gypi',
npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
npm ERR! gyp info spawn args   '-Dvisibility=default',
npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/pi/.cache/node-gyp/14.16.0',
npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp',
npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/pi/.cache/node-gyp/14.16.0/&lt;(target_arch)/node.lib',
npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll',
npm ERR! gyp info spawn args   '-Dnode_engine=v8',
npm ERR! gyp info spawn args   '--depth=.',
npm ERR! gyp info spawn args   '--no-parallel',
npm ERR! gyp info spawn args   '--generator-output',
npm ERR! gyp info spawn args   'build',
npm ERR! gyp info spawn args   '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: You must run `node-gyp configure` first!
npm ERR! gyp ERR! stack     at ReadFileContext.&lt;anonymous&gt; (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/node-gyp/lib/build.js:43:20)
npm ERR! gyp ERR! stack     at ReadFileContext.callback (/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/graceful-fs/graceful-fs.js:123:16)
npm ERR! gyp ERR! stack     at FSReqCallback.readFileAfterOpen [as oncomplete] (fs.js:273:13)
npm ERR! gyp ERR! System Linux 5.10.11-v7l+
npm ERR! gyp ERR! command "/usr/local/bin/node" "/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/.bin/node-gyp" "rebuild"
npm ERR! gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll
npm ERR! gyp ERR! node -v v14.16.0
npm ERR! gyp ERR! node-gyp -v v7.1.2
npm ERR! gyp ERR! not ok
npm ERR!     /home/pi/.npm/_logs/2021-03-17T21_03_25_216Z-debug.log
<p dir="auto">i tried with npm install (a second time), but this doesn’t change anything</p>
]]></description><link>https://forum.magicmirror.builders/post/89607</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89607</guid><dc:creator><![CDATA[matze86]]></dc:creator><pubDate>Wed, 17 Mar 2021 21:07:40 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Wed, 17 Mar 2021 20:15:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/matze86" aria-label="Profile: matze86">@<bdi>matze86</bdi></a> right. the library epoll is compiled for electron, but not just node. (server mode)</p>
<p dir="auto">per the messages, I would try npm rebuild</p>
]]></description><link>https://forum.magicmirror.builders/post/89605</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89605</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 17 Mar 2021 20:15:32 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Wed, 17 Mar 2021 19:25:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I tried to start my Mirror in server mode and than i got this error:</p>
<pre><code>[17.03.2021 20:17.36.506] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
NODE_MODULE_VERSION 83. Please try re-compiling or re-installing
[17.03.2021 20:17.36.508] [LOG]   Loading module helpers ...
[17.03.2021 20:17.36.509] [LOG]   No helper found for module: alert.
[17.03.2021 20:17.36.510] [LOG]   Initializing new module helper ...
[17.03.2021 20:17.36.510] [LOG]   Module helper loaded: updatenotification
[17.03.2021 20:17.36.511] [LOG]   No helper found for module: clock.
[17.03.2021 20:17.36.517] [ERROR] Whoops! There was an uncaught exception...
[17.03.2021 20:17.36.522] [ERROR] Error: The module '/home/pi/MagicMirror/modules/MMM-Navigate/node_modules/epoll/build/Release/epoll.node'
    at Object.Module._extensions..node (internal/modules/cjs/loader.js:1122:18)
    at Module.load (internal/modules/cjs/loader.js:928:32)
    at Function.Module._load (internal/modules/cjs/loader.js:769:14)
    at Module.require (internal/modules/cjs/loader.js:952:19)
    at require (internal/modules/cjs/helpers.js:88:18)
    at Module._compile (internal/modules/cjs/loader.js:1063:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
[17.03.2021 20:17.36.525] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
[17.03.2021 20:17.36.526] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
<p dir="auto">in “non-server-mode” it works very well.</p>
<p dir="auto">i reinstalled  the module , npm, node.js, electron,  but it still doesn’t work</p>
<p dir="auto">Any idea?</p>
]]></description><link>https://forum.magicmirror.builders/post/89603</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89603</guid><dc:creator><![CDATA[matze86]]></dc:creator><pubDate>Wed, 17 Mar 2021 19:25:08 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Mon, 04 Jan 2021 18:24:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/keineahnung123" aria-label="Profile: keineAhnung123">@<bdi>keineAhnung123</bdi></a> cause we haven’t tested  w those levels yet</p>
]]></description><link>https://forum.magicmirror.builders/post/86727</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86727</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 04 Jan 2021 18:24:02 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Mon, 04 Jan 2021 18:18:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thank you, that worked.<br />
Is there a reason why 10.23 and not the newest 14.15.3 or 15.0?</p>
]]></description><link>https://forum.magicmirror.builders/post/86725</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86725</guid><dc:creator><![CDATA[keineAhnung123]]></dc:creator><pubDate>Mon, 04 Jan 2021 18:18:53 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Mon, 04 Jan 2021 17:57:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/keineahnung123" aria-label="Profile: keineAhnung123">@<bdi>keineAhnung123</bdi></a> install nvm, and then use nvm to install node 10.23</p>
<p dir="auto"><a href="https://www.sitepoint.com/quick-tip-multiple-versions-node-nvm/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.sitepoint.com/quick-tip-multiple-versions-node-nvm/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/86724</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86724</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 04 Jan 2021 17:57:30 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Mon, 04 Jan 2021 17:49:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>sudo apt remove nodejs
sudo apt install nodejs
<p dir="auto">still Version 9.11.2 :(</p>
]]></description><link>https://forum.magicmirror.builders/post/86723</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86723</guid><dc:creator><![CDATA[keineAhnung123]]></dc:creator><pubDate>Mon, 04 Jan 2021 17:49:08 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Mon, 04 Jan 2021 17:41:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>pi@raspberrypi:~ $ node -v
v9.11.2
pi@raspberrypi:~ $ npm -v
6.14.10
<p dir="auto">node seems to be outdated?<br />
I will try to update it</p>
]]></description><link>https://forum.magicmirror.builders/post/86722</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86722</guid><dc:creator><![CDATA[keineAhnung123]]></dc:creator><pubDate>Mon, 04 Jan 2021 17:41:29 GMT</pubDate></item><item><title><![CDATA[Reply to Can't install MMM-Navigate on Sun, 03 Jan 2021 18:03:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/keineahnung123" aria-label="Profile: keineAhnung123">@<bdi>keineAhnung123</bdi></a> show results of</p>
<p dir="auto">node -v<br />
npm -v</p>
]]></description><link>https://forum.magicmirror.builders/post/86668</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/86668</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 03 Jan 2021 18:03:45 GMT</pubDate></item></channel></rss>
