<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My 24” MagicFamilyMirror]]></title><description><![CDATA[<p dir="auto">First of all - thank you to everyone who created and contributed to this project and to this forum and the various support threads on GitHub. I have a long standing hit-or-miss result when I dabble with this kind of stuff. MagicMirror has been a solid HIT! I found everything so well documented that most of the common issues I ran into had been discussed and solved before.</p>
<p dir="auto">I’ve got two SD cards runnable. I did the first setup over the holidays and stuck with the basics. Time, weather for my location, compliments (that’s a nice touch - I really like that part of this project). I was able to set up several of our local news RSS feeds (only to find out that they all really have the same headlines so I cut back how many feeds I was pulling from). I couldn’t resist the Dad Jokes module and have had many good chuckles thanks to that one already.</p>
<p dir="auto">I then made a second SD, starting from scratch rather than cloning the first…good opportunity to learn deeper. Once I had it at par with the first I proceeded to get MMM-Face-Reco-DNN functioning, identifying four of us in this household and adjusting the mirror accordingly.</p>
<p dir="auto">I’ve JUST got my shop tidied enough that I can get my table saw out to make the frame for the screen and mirror so will post photos of that process. The glass measures about 18” x 25” (vertical) and I used one way mirror film direct from the Amazon with pretty decent success. The cost of the glass and film was less that $30 combined. A true mirror would have cost me $130 locally.</p>
<p dir="auto">I found the screen through Kijiji - a 24” Samsung T240. It wasn’t until I got home that I discovered it was a hybrid HDTV/Display. That’s not ideal actually. It means more weight to the build because of all the TV related stuff. However it may prove valuable down the road in terms of added functionality I may get from having a reversion tuner built into the screen. We’ll see about that. One day. One other downside is the lack of a power brick. This weight again is built into the screen. And it also means a pretty thick cord going up the wall to the mirror. But not deal breakers. I’m super pumped to hang this up and enjoy it.</p>
<p dir="auto">So thanks again for all the help you all didn’t even know you were providing me. I look forward to making more and more of this Magic Mirror. Pics to follow (once I learn more about how this forum works).</p>
]]></description><link>https://forum.magicmirror.builders/topic/14408/my-24-magicfamilymirror</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 23:36:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14408.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Jan 2021 01:44:10 GMT</pubDate><ttl>60</ttl></channel></rss>
