<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[First time install]]></title><description><![CDATA[<p dir="auto">I’m following the first time manual install guide here</p>
<p dir="auto"><a href="https://docs.magicmirror.builders/getting-started/installation.html" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/getting-started/installation.html</a></p>
<p dir="auto">So I’ve installed raspberry pi os. (it doesn’t say this on the guide… But I assume that’s how I get terminal up and running?</p>
<p dir="auto">I’ve then followed the steps… When I input npm install… I get an error saying -bash: npm: command not found…</p>
<p dir="auto">Can you help?</p>
]]></description><link>https://forum.magicmirror.builders/topic/14413/first-time-install</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 10:37:15 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14413.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 11 Jan 2021 11:45:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to First time install on Mon, 11 Jan 2021 16:19:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thank you. I’ve got the mirror up and running… working on adding some modules now.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://forum.magicmirror.builders/post/87083</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87083</guid><dc:creator><![CDATA[jste84]]></dc:creator><pubDate>Mon, 11 Jan 2021 16:19:57 GMT</pubDate></item><item><title><![CDATA[Reply to First time install on Mon, 11 Jan 2021 15:13:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jste84" aria-label="Profile: jste84">@<bdi>jste84</bdi></a> in my scripts is fixuppm2,</p>
<p dir="auto">run that</p>
]]></description><link>https://forum.magicmirror.builders/post/87079</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87079</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 Jan 2021 15:13:53 GMT</pubDate></item><item><title><![CDATA[Reply to First time install on Mon, 11 Jan 2021 15:07:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> so worst luck…</p>
<p dir="auto">I got to the end of your install and my power went out.</p>
<p dir="auto">I’d just selected yes to boot to the mirror and I think pm2?</p>
<p dir="auto">Was that the end of your script and is there a way for me to go back to run that install…</p>
]]></description><link>https://forum.magicmirror.builders/post/87077</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87077</guid><dc:creator><![CDATA[jste84]]></dc:creator><pubDate>Mon, 11 Jan 2021 15:07:38 GMT</pubDate></item><item><title><![CDATA[Reply to First time install on Mon, 11 Jan 2021 12:42:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jste84" aria-label="Profile: jste84">@<bdi>jste84</bdi></a> rename the magicmirror  folder to something else. then run my script<br />
see here<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">npm isn’t installed all the time. u did use the desktop pi os, yes?</p>
]]></description><link>https://forum.magicmirror.builders/post/87070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87070</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 11 Jan 2021 12:42:08 GMT</pubDate></item><item><title><![CDATA[Reply to First time install on Mon, 11 Jan 2021 12:33:03 GMT]]></title><description><![CDATA[<p dir="auto">Fresh install of buster on what hardware?</p>
]]></description><link>https://forum.magicmirror.builders/post/87069</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87069</guid><dc:creator><![CDATA[swvalenti]]></dc:creator><pubDate>Mon, 11 Jan 2021 12:33:03 GMT</pubDate></item><item><title><![CDATA[Reply to First time install on Mon, 11 Jan 2021 12:12:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> it tells me MagicMirror already exists…</p>
<p dir="auto">I can change directory to it… But npm install fails</p>
]]></description><link>https://forum.magicmirror.builders/post/87068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87068</guid><dc:creator><![CDATA[jste84]]></dc:creator><pubDate>Mon, 11 Jan 2021 12:12:36 GMT</pubDate></item><item><title><![CDATA[Reply to First time install on Mon, 11 Jan 2021 12:06:10 GMT]]></title><description><![CDATA[<p dir="auto">in the terminal .<br />
cd …<br />
cd …<br />
git clone <a href="https://github.com/MichMich/MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror</a><br />
cd MagicMirror/<br />
npm install</p>
<p dir="auto">is that going oke???</p>
]]></description><link>https://forum.magicmirror.builders/post/87067</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87067</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Mon, 11 Jan 2021 12:06:10 GMT</pubDate></item><item><title><![CDATA[Reply to First time install on Mon, 11 Jan 2021 12:00:11 GMT]]></title><description><![CDATA[<p dir="auto">I just don’t understand why this isn’t working…</p>
<p dir="auto">Frustration 😓</p>
]]></description><link>https://forum.magicmirror.builders/post/87066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87066</guid><dc:creator><![CDATA[jste84]]></dc:creator><pubDate>Mon, 11 Jan 2021 12:00:11 GMT</pubDate></item></channel></rss>
