<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[MMM-TweetsByTimelineOrList] Awaiting Update... then black screen]]></title><description><![CDATA[<p dir="auto">I just installed the module, and using with config below.<br />
It shows “Awaiting Update…” when I raunch MagicMirror, then fede out in 5-10 sec.<br />
I see only black screen after that. Does someone help me?</p>
<p dir="auto">I tried regenerate API keys, add or remove some options, try with other screenName I saw on other topics.<br />
No error logs on console. Still no luck.</p>
<p dir="auto"><img src="/assets/uploads/files/1610493009296-c3ca45b5-837c-4ec5-92ae-d2a04db6a4db-image.png" alt="c3ca45b5-837c-4ec5-92ae-d2a04db6a4db-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/14424/mmm-tweetsbytimelineorlist-awaiting-update-then-black-screen</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 22:00:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14424.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Jan 2021 23:07:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [MMM-TweetsByTimelineOrList] Awaiting Update... then black screen on Thu, 21 Jan 2021 16:40:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ike-9" aria-label="Profile: ike-9">@<bdi>ike-9</bdi></a> - I had assumed that you used pm2 to start the Magic Mirror process. My bad. That’s an installation thing, so no need to introduce something new.</p>
<p dir="auto">Hmm. Nothing in the logs, nothing in the console? That is bizarre. Let me fire this up and see if I can’t get it to work.</p>
]]></description><link>https://forum.magicmirror.builders/post/87623</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87623</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Thu, 21 Jan 2021 16:40:52 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-TweetsByTimelineOrList] Awaiting Update... then black screen on Fri, 15 Jan 2021 20:44:07 GMT]]></title><description><![CDATA[<p dir="auto">I tried check logs but as far as I see there’s nothing indicate what I missed.<br />
Also, pm2 commands somehow didn’t work on my environment. Do I need to do something before execute?</p>
]]></description><link>https://forum.magicmirror.builders/post/87255</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87255</guid><dc:creator><![CDATA[ike-9]]></dc:creator><pubDate>Fri, 15 Jan 2021 20:44:07 GMT</pubDate></item><item><title><![CDATA[Reply to [MMM-TweetsByTimelineOrList] Awaiting Update... then black screen on Wed, 13 Jan 2021 03:55:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ike-9" aria-label="Profile: ike-9">@<bdi>ike-9</bdi></a> - Have you checked the logs?</p>
<p dir="auto">From an SSH terminal connected to your mirror, enter <code>pm2 log 0</code> and it should list the latest log entries for you. Look for any line that reads ERROR.</p>
<p dir="auto">Presumably, the module will tell you when something goes wrong.</p>
]]></description><link>https://forum.magicmirror.builders/post/87146</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87146</guid><dc:creator><![CDATA[bhepler]]></dc:creator><pubDate>Wed, 13 Jan 2021 03:55:24 GMT</pubDate></item></channel></rss>
