<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM Docker with MMM-Todoist & MMM-Admin-Interface]]></title><description><![CDATA[<p dir="auto">Hello All,<br />
i’m running MM in docker and trying to use MMM-Todoist &amp; MMM-Admin-Interface, I’ve done git clone and npm install in the docker but i still can not use it any one know why ?</p>
<p dir="auto">I also get a lot of errors ;</p>
<p dir="auto">Manual Install: <img src="/assets/uploads/files/1610628119737-screenshot-2021-01-14-at-12.37.02.png" alt="Screenshot 2021-01-14 at 12.37.02.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Docker Install: <img src="/assets/uploads/files/1610628127060-screenshot-2021-01-14-at-12.41.06.png" alt="Screenshot 2021-01-14 at 12.41.06.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/14433/mm-docker-with-mmm-todoist-mmm-admin-interface</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 18:08:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14433.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Jan 2021 12:35:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM Docker with MMM-Todoist & MMM-Admin-Interface on Fri, 15 Jan 2021 12:15:18 GMT]]></title><description><![CDATA[<p dir="auto">fixed by accident i put it under magic mirror &gt; modules &gt; default, moved it under magic mirror &gt; modules now works</p>
]]></description><link>https://forum.magicmirror.builders/post/87231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87231</guid><dc:creator><![CDATA[irontamoor]]></dc:creator><pubDate>Fri, 15 Jan 2021 12:15:18 GMT</pubDate></item><item><title><![CDATA[Reply to MM Docker with MMM-Todoist & MMM-Admin-Interface on Fri, 15 Jan 2021 00:20:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a></p>
<p dir="auto">Thank you for responding,</p>
<pre><code>which hardware? Pi, Linux VM?
<p dir="auto">VM I used ubuntu server 20.0.4 and rancher os</p>
<pre><code>which docker image?
<p dir="auto">bastilimbach/docker-magicmirror</p>
<pre><code>how did you start the image?
<p dir="auto">Docker start magic_mirror</p>
<pre><code>how did you install the module(s)? Did you the installation from within the running container?
<p dir="auto">Outside of docker using git clone</p>
<pre><code>MagicMirror version?
<p dir="auto">Latest docker image</p>
<p dir="auto"><a href="https://github.com/bastilimbach/docker-magicmirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/bastilimbach/docker-magicmirror</a></p>
]]></description><link>https://forum.magicmirror.builders/post/87215</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87215</guid><dc:creator><![CDATA[irontamoor]]></dc:creator><pubDate>Fri, 15 Jan 2021 00:20:49 GMT</pubDate></item><item><title><![CDATA[Reply to MM Docker with MMM-Todoist & MMM-Admin-Interface on Fri, 15 Jan 2021 00:16:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashishtank" aria-label="Profile: ashishtank">@<bdi>ashishtank</bdi></a> said in <a href="/post/87201">MM Docker with MMM-Todoist &amp; MMM-Admin-Interface</a>:</p>
<p dir="auto">Did you do npm install for this modules in docker ? I think you need that for external modules in docker.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashishtank" aria-label="Profile: ashishtank">@<bdi>ashishtank</bdi></a> thank you for responding, I did the following; docker exec magic_mirror /bin/sh<br />
cd to modules (Todoist) npm install (like it says to)</p>
<p dir="auto">Is this correct? Or do I have to do it out of docker?</p>
]]></description><link>https://forum.magicmirror.builders/post/87214</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87214</guid><dc:creator><![CDATA[irontamoor]]></dc:creator><pubDate>Fri, 15 Jan 2021 00:16:03 GMT</pubDate></item><item><title><![CDATA[Reply to MM Docker with MMM-Todoist & MMM-Admin-Interface on Thu, 14 Jan 2021 18:52:47 GMT]]></title><description><![CDATA[<p dir="auto">tested this (in severonly mode, not on a pi) with MMM-Todoist and it works.</p>
<p dir="auto">We need more info about your setup:</p>
<ul>
<li>which hardware? Pi, Linux VM?</li>
<li>which docker image?</li>
<li>how did you start the image?</li>
<li>how did you install the module(s)? Did you the installation from within the running container?</li>
<li>MagicMirror version?</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/87206</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87206</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Thu, 14 Jan 2021 18:52:47 GMT</pubDate></item><item><title><![CDATA[Reply to MM Docker with MMM-Todoist & MMM-Admin-Interface on Thu, 14 Jan 2021 16:18:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/irontamoor" aria-label="Profile: irontamoor">@<bdi>irontamoor</bdi></a> The error suggests that instead of .css or .js file it is responding with html (could be 404 or other error details). Go to network tab and filter with mmm-todo and check the response from server.</p>
]]></description><link>https://forum.magicmirror.builders/post/87201</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87201</guid><dc:creator><![CDATA[ashishtank]]></dc:creator><pubDate>Thu, 14 Jan 2021 16:18:21 GMT</pubDate></item></channel></rss>
