<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Manual Installation Trouble]]></title><description><![CDATA[<p dir="auto">Manual Installation Trouble Error</p>
]]></description><link>https://forum.magicmirror.builders/topic/14451/manual-installation-trouble</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 08:32:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14451.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Jan 2021 20:48:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 22:45:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brendan_c23" aria-label="Profile: brendan_c23">@<bdi>brendan_c23</bdi></a> Below are pm2 commands help. If you want to stop the mirror then use <code>pm2 stop 0</code> or <code>pm2 stop MagicMirror</code><br />
refer : <a href="https://pm2.keymetrics.io/docs/usage/quick-start/" target="_blank" rel="noopener noreferrer nofollow ugc">https://pm2.keymetrics.io/docs/usage/quick-start/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/87296</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87296</guid><dc:creator><![CDATA[ashishtank]]></dc:creator><pubDate>Sat, 16 Jan 2021 22:45:49 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 21:43:36 GMT]]></title><description><![CDATA[<p dir="auto">Thank you I hit Y, but how can I reverse it? I want to start installing modules but the mirror screen keeps running</p>
]]></description><link>https://forum.magicmirror.builders/post/87292</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87292</guid><dc:creator><![CDATA[brendan_c23]]></dc:creator><pubDate>Sat, 16 Jan 2021 21:43:36 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 21:13:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brendan_c23" aria-label="Profile: brendan_c23">@<bdi>brendan_c23</bdi></a> it’s part of the install, u will be prompted. also see rest of the scripts</p>
]]></description><link>https://forum.magicmirror.builders/post/87291</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87291</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 16 Jan 2021 21:13:08 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 21:11:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you. Can you link me to PM2 installation</p>
]]></description><link>https://forum.magicmirror.builders/post/87290</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87290</guid><dc:creator><![CDATA[brendan_c23]]></dc:creator><pubDate>Sat, 16 Jan 2021 21:11:53 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 21:01:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brendan_c23" aria-label="Profile: brendan_c23">@<bdi>brendan_c23</bdi></a> I gave u the command</p>
]]></description><link>https://forum.magicmirror.builders/post/87288</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87288</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 16 Jan 2021 21:01:32 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 21:00:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Delete MM folder? How do I do that<br />
And I think so but not totally sure</p>
]]></description><link>https://forum.magicmirror.builders/post/87287</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87287</guid><dc:creator><![CDATA[brendan_c23]]></dc:creator><pubDate>Sat, 16 Jan 2021 21:00:19 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 20:59:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brendan_c23" aria-label="Profile: brendan_c23">@<bdi>brendan_c23</bdi></a> u need to delete the mm folder</p>
<p dir="auto">rm -rf ~/MagicMirror</p>
<p dir="auto">then use the one line for install</p>
]]></description><link>https://forum.magicmirror.builders/post/87286</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87286</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 16 Jan 2021 20:59:19 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 20:58:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Do I need to clear all of the previous downloads/code or am I good to just copy + paste that line  below everything?</p>
]]></description><link>https://forum.magicmirror.builders/post/87285</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87285</guid><dc:creator><![CDATA[brendan_c23]]></dc:creator><pubDate>Sat, 16 Jan 2021 20:58:11 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 20:58:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brendan_c23" aria-label="Profile: brendan_c23">@<bdi>brendan_c23</bdi></a> use my script. delete  the mm folder and run my script</p>
<p dir="auto">u are running the desktop version of pi os  yes? u must</p>
]]></description><link>https://forum.magicmirror.builders/post/87284</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87284</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 16 Jan 2021 20:58:05 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 20:53:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brendan_c23" aria-label="Profile: brendan_c23">@<bdi>brendan_c23</bdi></a> I am attempting to install the latest Node.js version using the code provided on the manual installation page of this website. I copy and pasted each line one by one as directed. When I got to the “npm run start” line, I am hit with these lines:</p>
<p dir="auto">pi@raspberrypi:~/MagicMirror $ npm run start</p>
<p dir="auto">magicmirror@2.14.0 start /home/pi/MagicMirror<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">/home/pi/MagicMirror/node_modules/electron/index.js:14<br />
throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)<br />
^</p>
<p dir="auto">Error: Electron failed to install correctly, please delete node_modules/electron and try installing again<br />
at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:14:11)<br />
at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:18:18)<br />
at Module._compile (internal/modules/cjs/loader.js:778:30)<br />
at Object.Module._extensions…js (internal/modules/cjs/loader.js:789:10)<br />
at Module.load (internal/modules/cjs/loader.js:653:32)<br />
at tryModuleLoad (internal/modules/cjs/loader.js:593:12)<br />
at Function.Module._load (internal/modules/cjs/loader.js:585:3)<br />
at Module.require (internal/modules/cjs/loader.js:692:17)<br />
at require (internal/modules/cjs/helpers.js:25:18)<br />
at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)<br />
npm ERR! code ELIFECYCLE<br />
npm ERR! errno 1<br />
npm ERR! magicmirror@2.14.0 start: <code>DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js</code><br />
npm ERR! Exit status 1<br />
npm ERR!<br />
npm ERR! Failed at the magicmirror@2.14.0 start script.<br />
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.</p>
<p dir="auto">npm ERR! A complete log of this run can be found in:<br />
npm ERR!     /home/pi/.npm/_logs/2021-01-16T20_10_19_289Z-debug.log</p>
<p dir="auto">I am not sure where to go from here. Any guidance/help would be greatly appreciated. I am using a 2Gb raspberry Pi 4. I have a very limited background in coding, but I notice it is telling me to delete the node_modules/electron and try installing again, any guidance on how to go about doing that would be appreciated.</p>
<p dir="auto">Thanks you guys</p>
]]></description><link>https://forum.magicmirror.builders/post/87282</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87282</guid><dc:creator><![CDATA[brendan_c23]]></dc:creator><pubDate>Sat, 16 Jan 2021 20:53:47 GMT</pubDate></item><item><title><![CDATA[Reply to Manual Installation Trouble on Sat, 16 Jan 2021 20:52:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brendan_c23" aria-label="Profile: brendan_c23">@<bdi>brendan_c23</bdi></a> use my install script<br />
see <a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/87281</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87281</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 16 Jan 2021 20:52:48 GMT</pubDate></item></channel></rss>
