<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Dual Assistant Alexa / Google Assistant]]></title><description><![CDATA[<p dir="auto">Hi guys !</p>
<p dir="auto">I’m now able to inform you that my MMM-Alexa module is under coding (and working)<br />
The result is actually not to bad ;)</p>
<p dir="auto">You can run now MMM-GoogleAssistant and MMM-Alexa in the same time :)</p>
<p dir="auto">Two keywords are register:</p>
<ul>
<li>Jarvis: launch GoogleAssistant</li>
<li>Alexa: launch Alexa</li>
</ul>
<p dir="auto">i will inform you later ;)</p>
<p dir="auto">See You</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/topic/14455/dual-assistant-alexa-google-assistant</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 04:00:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14455.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 17 Jan 2021 23:53:16 GMT</pubDate><ttl>60</ttl></channel></rss>
