<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-BMW-OW]]></title><description><![CDATA[<p dir="auto">Can someone explain how to change the units in the BMW-OW weather module to imperial? Also, how can I add color as shown in the example? My module shows only white and I don’t see any configuration changes. Many thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14466/mmm-bmw-ow</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 21:13:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14466.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Jan 2021 00:59:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-BMW-OW on Tue, 19 Jan 2021 03:15:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmnewby" aria-label="Profile: MMNewby">@<bdi>MMNewby</bdi></a></p>
<p dir="auto">They are, by default, imperial units. I don’t even recall if metric is an option. I’d have to look. Is your config ‘units’ set to imperial?</p>
<p dir="auto">There are several css options included and accessed via config options. Color can always be modified through your custom.css file.</p>
<p dir="auto">I’m very busy at the moment with another module and it’s late. See what you can do and post again if you need help</p>
]]></description><link>https://forum.magicmirror.builders/post/87490</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87490</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Tue, 19 Jan 2021 03:15:44 GMT</pubDate></item></channel></rss>
