<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Covid-19 sparkline]]></title><description><![CDATA[<p dir="auto">Hello everyone.<br />
I’m a user of the</p>
<p dir="auto">I have one issue.<br />
MMM-covid19-sparkline app from <a class="plugin-mentions-user plugin-mentions-a" href="/user/skelliam" aria-label="Profile: skelliam">@<bdi>skelliam</bdi></a><br />
Now I see in de dev-tool the next issue.</p>
<pre><code>DevTools failed to parse SourceMap: http://localhost:8080/modules/MMM-COVID19-SPARKLINE/lib/highcharts.js.map
Is showing up on the DevTools. log
<p dir="auto">So ken someone tell mee what its meen and how to remove the failer.</p>
<p dir="auto">Thanks for the help.</p>
<pre><code>		{
		module: 'MMM-COVID19-SPARKLINE',
		position: "bottom_left",
		config : {
			worldStats: false,
			sparklines: true,
			sparklineWidth: 100,
			sparklineHeight: 55,
			sparklineDays: 50,
			sparklineDeltavsDaily: true,
			sortby: "confirmed",
			columns: ["confirmed", "deaths", "recovered"],
			countries: ["Netherlands", "Germany", "Belgium"],
			updateInterval: 1000 * 60 * 60 * 8,  //8 hours
			infoRowClass: "medium",
			headerRowClass: "small",
			fadeSpeed: 1000,
			showDelta: true,
			showDeltaPlotNDays: 7,
			sparklineDeathScale: -4,
			showDelimiter: true
]]></description><link>https://forum.magicmirror.builders/topic/14472/covid-19-sparkline</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 18:35:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14472.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Jan 2021 18:42:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Covid-19 sparkline on Thu, 21 Jan 2021 18:13:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashishtank" aria-label="Profile: ashishtank">@<bdi>ashishtank</bdi></a></p>
<pre><code>[21.01.2021 19:10.37.452] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently "false".  It will change to be "true" in Electron 9.  For more information please check https://github.com/electron/electron/issues/18397
[21.01.2021 19:10.39.835] [ERROR] (node:3443) [DEP0066] DeprecationWarning: OutgoingMessage.prototype._headers is deprecated
<p dir="auto">Is this the same what I can ignore???</p>
]]></description><link>https://forum.magicmirror.builders/post/87628</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87628</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Thu, 21 Jan 2021 18:13:37 GMT</pubDate></item><item><title><![CDATA[Reply to Covid-19 sparkline on Wed, 20 Jan 2021 19:53:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> you can ignore this warning.</p>
]]></description><link>https://forum.magicmirror.builders/post/87590</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87590</guid><dc:creator><![CDATA[ashishtank]]></dc:creator><pubDate>Wed, 20 Jan 2021 19:53:53 GMT</pubDate></item><item><title><![CDATA[Reply to Covid-19 sparkline on Wed, 20 Jan 2021 19:52:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashishtank" aria-label="Profile: ashishtank">@<bdi>ashishtank</bdi></a> I have nou manecht to get the failed going away by updating the Higharts.js.</p>
<p dir="auto">But now I got a nieuw think whit the police. The Electric police.</p>
<pre><code>security-warnings.ts:182
Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
    Policy set or a policy with "unsafe-eval" enabled. This exposes users of
    this app to unnecessary security risks.
For more information and help, consult
https://electronjs.org/docs/tutorial/security.
This warning will not show up
once the app is packaged.
]]></description><link>https://forum.magicmirror.builders/post/87589</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87589</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Wed, 20 Jan 2021 19:52:51 GMT</pubDate></item><item><title><![CDATA[Reply to Covid-19 sparkline on Tue, 19 Jan 2021 19:32:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ashishtank" aria-label="Profile: ashishtank">@<bdi>ashishtank</bdi></a><br />
Yes the module Is look to seem working oke.<br />
I only saw the yellow exclamation mark. and I like to have a smoothie log.</p>
]]></description><link>https://forum.magicmirror.builders/post/87532</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87532</guid><dc:creator><![CDATA[JerryP]]></dc:creator><pubDate>Tue, 19 Jan 2021 19:32:22 GMT</pubDate></item><item><title><![CDATA[Reply to Covid-19 sparkline on Tue, 19 Jan 2021 19:29:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jerryp" aria-label="Profile: JerryP">@<bdi>JerryP</bdi></a> this is not failure it is warning that highcharts.js.map file not found. Is there any other error ? is module working ?</p>
]]></description><link>https://forum.magicmirror.builders/post/87530</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87530</guid><dc:creator><![CDATA[ashishtank]]></dc:creator><pubDate>Tue, 19 Jan 2021 19:29:14 GMT</pubDate></item></channel></rss>
