<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-google assistant black screen.]]></title><description><![CDATA[<p dir="auto">Hello, I would like to use the google assistant on my Magic Mirror. I installed the module, logged in to googel and updated the config file.</p>
<p dir="auto">if I restart now the magic mirror comes simply only a black screen without error message. If the code is removed from the config then the magic mirror works normally again.</p>
<p dir="auto">If someone could help me with my problem I would be very happy.</p>
<p dir="auto">Greeting Volker.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14489/mmm-google-assistant-black-screen</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 22:56:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14489.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Jan 2021 14:35:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-google assistant black screen. on Thu, 28 Jan 2021 16:55:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathieu" aria-label="Profile: Mathieu">@<bdi>Mathieu</bdi></a> Stop ;-)</p>
]]></description><link>https://forum.magicmirror.builders/post/87939</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87939</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Thu, 28 Jan 2021 16:55:07 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Thu, 28 Jan 2021 10:02:22 GMT]]></title><description><![CDATA[<p dir="auto">It’s Ok …   work after clean install…</p>
<p dir="auto">But how you stop Youtube Vidéos where is the command…?</p>
<p dir="auto">Thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/87930</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87930</guid><dc:creator><![CDATA[Mathieu]]></dc:creator><pubDate>Thu, 28 Jan 2021 10:02:22 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Tue, 26 Jan 2021 20:47:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: Egnos">@<bdi>Egnos</bdi></a> Thank You.    Merci.  Gracias<br />
I try this evening.</p>
]]></description><link>https://forum.magicmirror.builders/post/87846</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87846</guid><dc:creator><![CDATA[Mathieu]]></dc:creator><pubDate>Tue, 26 Jan 2021 20:47:24 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Mon, 25 Jan 2021 21:15:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathieu" aria-label="Profile: Mathieu">@<bdi>Mathieu</bdi></a> meanwhile it would be better if you read the guideon github for <a href="https://github.com/bugsounet/MMM-GoogleAssistant/wiki" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-GoogleAssistant</a> and <a href="https://github.com/bugsounet/MMM-Assistant2Display/wiki" target="_blank" rel="noopener noreferrer nofollow ugc">MMM-Assistant2Display</a></p>
<p dir="auto">Then I would try this config:</p>
<pre><code>{
		  module: "MMM-GoogleAssistant",
		  position: "fullscreen_above",
			assistantConfig: {
				lang: "fr-FR",
				latitude: 44.6503800,
				longitude: -0.35508007.558791,
			responseConfig: {
			  useScreenOutput: true,
			  screenOutputCSS: "screen_output.css",
			  screenOutputTimer: 5000,
			  screenRotate: false,
			  activateDelay: 250,
			  useAudioOutput: true,
			  useChime: true,
			  newChime: false,
			  useNative: true,
			  playProgram: "mpg321"
			A2DServer: {
			  useA2D: true,
			  stopCommand: "stop",
			  useYouTube: true,
			  youtubeCommand: "youtube",
			  displayResponse: true
			micConfig: {
			  recorder: "arecord",
			  device: "plughw:2"
			snowboy: {
				Sensitivity: 0.7,
				Model: "jarvis"
		  module: "MMM-Assistant2Display",
		  position: "bottom_right",
			debug:false,
			useYoutube: true,
				cast: {
					useCast: true,
					castName: "MagicMirror",
					port: 8569
				volume: {
					  useVolume: true,
					  volumePreset: "ALSA_HDMI",
					  myScript: null
				links: 	{
						useLinks: true,
						scrollActivate: true
<p dir="auto">after activating GA with “Jarvis” remember to say “YouTube …” and the name of the video …</p>
]]></description><link>https://forum.magicmirror.builders/post/87806</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87806</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Mon, 25 Jan 2021 21:15:54 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Mon, 25 Jan 2021 18:30:19 GMT]]></title><description><![CDATA[<p dir="auto">I just posted about issues I’m having with this module after update</p>
<p dir="auto">I tried a fresh install but sadly I’m not having any luck with it</p>
<p dir="auto">Wish I hadn’t updated :(</p>
]]></description><link>https://forum.magicmirror.builders/post/87800</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87800</guid><dc:creator><![CDATA[jste84]]></dc:creator><pubDate>Mon, 25 Jan 2021 18:30:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Mon, 25 Jan 2021 18:09:55 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1611598194108-capture-d-%C3%A9cran-2021-01-25-%C3%A0-19.09.30.png" alt="Capture d’écran 2021-01-25 à 19.09.30.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1611598152985-capture-d-%C3%A9cran-2021-01-25-%C3%A0-19.08.41.png" alt="Capture d’écran 2021-01-25 à 19.08.41.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1611598090050-capture-d-%C3%A9cran-2021-01-25-%C3%A0-19.07.39.png" alt="Capture d’écran 2021-01-25 à 19.07.39.png" class=" img-fluid img-markdown" /> <img src="/assets/uploads/files/1611598025259-capture-d-%C3%A9cran-2021-01-25-%C3%A0-19.05.42.png" alt="Capture d’écran 2021-01-25 à 19.05.42.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/87799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87799</guid><dc:creator><![CDATA[Mathieu]]></dc:creator><pubDate>Mon, 25 Jan 2021 18:09:55 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Mon, 25 Jan 2021 10:50:53 GMT]]></title><description><![CDATA[<p dir="auto">Thank you I will post my config here this evening.</p>
<p dir="auto">And it’s the same for link internet… it’s doesn’t work. Thank you. and I try post a screen shot.</p>
<p dir="auto">Merci.</p>
]]></description><link>https://forum.magicmirror.builders/post/87782</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87782</guid><dc:creator><![CDATA[Mathieu]]></dc:creator><pubDate>Mon, 25 Jan 2021 10:50:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Sun, 24 Jan 2021 21:08:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathieu" aria-label="Profile: Mathieu">@<bdi>Mathieu</bdi></a> good job!<br />
Post your config please (if I’m not mistaken some YouTube videos covered by copyright, due to Google policies, are no longer visible using GA…)</p>
]]></description><link>https://forum.magicmirror.builders/post/87752</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87752</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Sun, 24 Jan 2021 21:08:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Sun, 24 Jan 2021 17:06:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/egnos" aria-label="Profile: Egnos">@<bdi>Egnos</bdi></a> it’s ok after clean install thank you … but … I am also having an issue with youtube it is not working. I used different commands but it is not showing youtube videos. I already changed all the false to true as per the video my GA is working but youTube still not working.</p>
]]></description><link>https://forum.magicmirror.builders/post/87730</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87730</guid><dc:creator><![CDATA[Mathieu]]></dc:creator><pubDate>Sun, 24 Jan 2021 17:06:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Sat, 23 Jan 2021 23:43:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mathieu" aria-label="Profile: Mathieu">@<bdi>Mathieu</bdi></a><br />
It seems you can’t find some “Error: Cannot find module” files, in particular some components of “snowboy”.<br />
I advise you to uninstall and clean install by carefully following this <a href="https://github.com/bugsounet/MMM-GoogleAssistant/wiki/Installation" target="_blank" rel="noopener noreferrer nofollow ugc">guide</a> .</p>
<p dir="auto">Unfortunately the user <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> is no longer part of the forum and without him it will be very difficult to get information on this module … :-(</p>
]]></description><link>https://forum.magicmirror.builders/post/87700</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87700</guid><dc:creator><![CDATA[Egnos]]></dc:creator><pubDate>Sat, 23 Jan 2021 23:43:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-google assistant black screen. on Fri, 22 Jan 2021 14:42:22 GMT]]></title><description><![CDATA[<p dir="auto">My log …  thank’s</p>
<p dir="auto">magicmirror@2.14.0 start /home/pi/MagicMirror<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js “dev”</p>
<p dir="auto">[22.01.2021 15:41.18.655] [LOG]   Starting MagicMirror: v2.14.0<br />
[22.01.2021 15:41.18.666] [LOG]   Loading config …<br />
[22.01.2021 15:41.18.686] [LOG]   Loading module helpers …<br />
[22.01.2021 15:41.18.691] [LOG]   No helper found for module: alert.<br />
[22.01.2021 15:41.18.996] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.18.998] [LOG]   Module helper loaded: updatenotification<br />
[22.01.2021 15:41.19.001] [LOG]   No helper found for module: clock.<br />
[22.01.2021 15:41.19.803] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.19.806] [LOG]   Module helper loaded: calendar<br />
[22.01.2021 15:41.19.813] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.19.816] [LOG]   Module helper loaded: MMM-DHT22<br />
[22.01.2021 15:41.19.819] [LOG]   No helper found for module: compliments.<br />
[22.01.2021 15:41.19.824] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.19.825] [LOG]   Module helper loaded: MMM-Lunartic<br />
[22.01.2021 15:41.19.827] [LOG]   No helper found for module: MMM-WeatherOrNot.<br />
[22.01.2021 15:41.19.888] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.19.889] [LOG]   Module helper loaded: newsfeed<br />
[22.01.2021 15:41.21.095] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>/snowboy/lib/node/binding/Release/electron-v8.5-linux-arm/snowboy.node’<br />
Require stack:</p>
<ul>
<li>/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>/snowboy/lib/node/index.js</li>
<li>/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>/snowboy/index.js</li>
<li>/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js</li>
<li>/home/pi/MagicMirror/js/app.js</li>
<li>/home/pi/MagicMirror/js/electron.js</li>
<li>/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js</li>
<li></li>
</ul>
<p dir="auto">[22.01.2021 15:41.21.098] [LOG]   Loading module helpers …<br />
[22.01.2021 15:41.21.101] [LOG]   No helper found for module: alert.<br />
[22.01.2021 15:41.21.104] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.21.106] [LOG]   Module helper loaded: updatenotification<br />
[22.01.2021 15:41.21.109] [LOG]   No helper found for module: clock.<br />
[22.01.2021 15:41.21.112] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.21.114] [LOG]   Module helper loaded: calendar<br />
[22.01.2021 15:41.21.116] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.21.117] [LOG]   Module helper loaded: MMM-DHT22<br />
[22.01.2021 15:41.21.120] [LOG]   No helper found for module: compliments.<br />
[22.01.2021 15:41.21.122] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.21.123] [LOG]   Module helper loaded: MMM-Lunartic<br />
[22.01.2021 15:41.21.124] [LOG]   No helper found for module: MMM-WeatherOrNot.<br />
[22.01.2021 15:41.21.126] [LOG]   Initializing new module helper …<br />
[22.01.2021 15:41.21.127] [LOG]   Module helper loaded: newsfeed<br />
[22.01.2021 15:41.21.141] [ERROR] App threw an error during load<br />
[22.01.2021 15:41.21.155] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>/snowboy/lib/node/binding/Release/electron-v8.5-linux-arm/snowboy.node’<br />
Require stack:</p>
<ul>
<li>at Module._resolveFilename (internal/modules/cjs/loader.js:798:15)<br />
at Function…/lib/common/reset-search-paths.ts.Module._resolveFilename (electron/js2c/browser_init.js:7718:16)<br />
at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)<br />
at Module._load (internal/modules/cjs/loader.js:691:27)<br />
at Function.Module._load (electron/js2c/asar.js:748:26)<br />
at Module.require (internal/modules/cjs/loader.js:853:19)<br />
at require (internal/modules/cjs/helpers.js:74:18)<br />
at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>/snowboy/lib/node/index.js:8:29)<br />
at Module._compile (internal/modules/cjs/loader.js:968:30)<br />
at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10)<br />
[22.01.2021 15:41.21.158] [ERROR] Whoops! There was an uncaught exception…<br />
[22.01.2021 15:41.21.170] [ERROR] Error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>/snowboy/lib/node/binding/Release/electron-v8.5-linux-arm/snowboy.node’<br />
Require stack:</li>
at Object.Module._extensions…js (internal/modules/cjs/loader.js:986:10) {<br />
code: ‘MODULE_NOT_FOUND’,<br />
requireStack: [<br />
‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>/snowboy/lib/node/index.js’,<br />
‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/<a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>/snowboy/index.js’,<br />
‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js’,<br />
‘/home/pi/MagicMirror/js/app.js’,<br />
‘/home/pi/MagicMirror/js/electron.js’,<br />
‘/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js’,<br />
undefined<br />
]<br />
}<br />
[22.01.2021 15:41.21.178] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?<br />
[22.01.2021 15:41.21.180] [ERROR] If you think this really is an issue, please open an issue on GitHub: <a href="https://github.com/MichMich/MagicMirror/issues" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/issues</a><br />
[22.01.2021 15:41.21.636] [LOG]   Launching application.<br />
[22.01.2021 15:41.21.703] [WARN]  (electron) The default value of app.allowRendererProcessReuse is deprecated, it is currently “false”.  It will change to be “true” in Electron 9.  For more information please check <a href="https://github.com/electron/electron/issues/18397" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/electron/electron/issues/18397</a></li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/87659</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87659</guid><dc:creator><![CDATA[Mathieu]]></dc:creator><pubDate>Fri, 22 Jan 2021 14:42:22 GMT</pubDate></item></channel></rss>
