<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The screen starts to flickering every 10 seconds every time i use this modules]]></title><description><![CDATA[<p dir="auto">[config.js es bellow]<br />
Im working with this 3rd party modules: MMM-Spotify, MMM-GmailFeed, MMM-Screencast, MMM-MotionDetector. I must say that i also configure the auto start magic mirror.<br />
Ive tried to put those modules together like three times and every time ive got the same error, my screen starts to blink every 10 seconds approximately (but once i have restarted the raspberry pi 4).<br />
At first i thought that it might be the screen but then ive tried with others and stays the same.<br />
The last time ive tried to go and install just one module at a time and wait for it to fail (this time I got to install and use in the config file this modules: MMM-Spotify, MMM-MotionDetector (i must say that i also do not install the auto starting magic mirror thing)), and in that way try to identify the module that its causing the mal functioning, but then i realize that i can ask you guys cause if it fails i will have to install every this again.<br />
I have suspicions about the auto starting magic mirror cause this starts to fail when i restart the raspberry pi 4.<br />
I also must say that everything works fine, its just the screen issue.<br />
Some passwords and id have been erased.</p>
 * By Michael Teeuw https://michaelteeuw.nl
 * MIT Licensed.
var config = {
 address: "localhost",  // Address to listen on, can be:
 port: 8080,
 basePath: "/",  // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
 ipWhitelist: [],  // Set [] to allow all IP addresses
 useHttps: false,   // Support HTTPS or not, default "false" will use HTTP
 httpsPrivateKey: "",  // HTTPS private key path, only require when useHttps is true
 httpsCertificate: "",  // HTTPS Certificate path, only require when useHttps is true
 language: "es",
 timeFormat: 24,
 units: "metric",
   module: "MMM-Spotify",
   position: "top_bar",
     debug: false,
   module: "alert",
   module: "updatenotification",
   position: "top_bar"
   module: "clock",
    displaySeconds: false,
     module: 'MMM-GmailFeed',
     position: 'top_left',
   username: '',
   password: '',
   updateInterval: 30000,
   maxEmails: 5,
   maxSubjectLength: 20,
   maxFromLength: 10,
   playSound: true,
   autoHide: true,
   displayMode: "table",
   username: '',
   password: '',
   maxEmails: 5,
   maxFromLength: 10,
   playSound: true,
   autoHide: true,
     module: "currentweather",
   locationID: "3868121", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
   appid: ""
     module: "weatherforecast",
     header: "Pronóstico del clima",
   appid: ""
     module: "newsfeed",
     position: "bottom_bar",    // This can be any of the regions. Best results in center regions.
   // The config property is optional.
   // If no config is set, an example calendar is shown.
   feeds: [
     title: "Internacional",
     url: "https://www.elmostrador.cl/noticias/mundo/feed/",
     title: "Chile",
     url: "https://www.elmostrador.cl/destacado/feed/",
     title: "Ciencia",
     url: "https://www.investigacionyciencia.es/rss/noticias",
     title: "Tecnología",
     url: "https://es.digitaltrends.com/noticias/feed/",
    showSourceTitle: true,
    showPublishDate: true,
    broadcastNewsFeeds: true,
    broadcastNewsUpdates: true,
    showDescription: true,
    updateInterval: 15000
      module: 'MMM-Screencast',
      position: 'lower_third', // This position is for a hidden &lt;div /&gt; and not the screencast window
    position: 'middle',
    height: 1050,
    width: 1280,
     module: "MMM-MotionDetector",
     //position: "lower_third", // Optional. This can be any of the regions. Displays debug informations.
    timeout: "60000",
]]></description><link>https://forum.magicmirror.builders/topic/14498/the-screen-starts-to-flickering-every-10-seconds-every-time-i-use-this-modules</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Apr 2026 23:51:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14498.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Jan 2021 14:40:19 GMT</pubDate><ttl>60</ttl></channel></rss>
