<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mycovid19 graph doesn't show on webpage through Dataplicity]]></title><description><![CDATA[<p dir="auto">The graph works and shows fine on the monitor, which is connected directly to my RPI, but does not show on my Dataplicity webpage. The only thing there is, is the “<code>MyCovid19 Loading data for chart "Cases"</code>”. Everything else works fine.<br />
From my dataplicity webpage:<br />
<img src="/assets/uploads/files/1611565877204-15676a6d-607d-49dc-b204-e9a1a646fddd-image.png" alt="15676a6d-607d-49dc-b204-e9a1a646fddd-image.png" class=" img-fluid img-markdown" /><br />
From VNC Viewer:<br />
<img src="/assets/uploads/files/1611565849099-e66bf05c-a96f-4044-a928-580d3088395c-image.png" alt="e66bf05c-a96f-4044-a928-580d3088395c-image.png" class=" img-fluid img-markdown" /><br />
I’m lost, and do not know what to do to fix it</p>
]]></description><link>https://forum.magicmirror.builders/topic/14502/mycovid19-graph-doesn-t-show-on-webpage-through-dataplicity</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 23:50:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14502.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 25 Jan 2021 09:17:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mycovid19 graph doesn't show on webpage through Dataplicity on Tue, 26 Jan 2021 12:06:34 GMT]]></title><description><![CDATA[<p dir="auto">Never mind.<br />
Found out, that I had to do <code>startDate: "10/28/2020",</code></p>
]]></description><link>https://forum.magicmirror.builders/post/87827</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87827</guid><dc:creator><![CDATA[Blauenfeldt]]></dc:creator><pubDate>Tue, 26 Jan 2021 12:06:34 GMT</pubDate></item><item><title><![CDATA[Reply to Mycovid19 graph doesn't show on webpage through Dataplicity on Tue, 26 Jan 2021 12:03:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Dataplicity is a “device forwarding” program. I install their program on the pi, then it is forwarded to their service. I can then go to their website, and remote control it via shell. I also get a link (<a href="http://something.dataplicity.io" target="_blank" rel="noopener noreferrer nofollow ugc">something.dataplicity.io</a>), where I can see the what it shows. For me, it’s basically port forwarding with remote shell, and I get to use letters instead of ip address.</p>
<p dir="auto">Found out it took long time for it to load, but i works now, kinda. I found out, that with the “startDate” added, i won’t load at all, even local.<br />
It won’t load with:<br />
<code>startDate: 10/28/2020,</code><br />
But will, but with wrong start date with:<br />
<code>StartDate: 10/28/2020,</code><br />
Jan 28 is the first day it shows.</p>
]]></description><link>https://forum.magicmirror.builders/post/87826</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87826</guid><dc:creator><![CDATA[Blauenfeldt]]></dc:creator><pubDate>Tue, 26 Jan 2021 12:03:13 GMT</pubDate></item><item><title><![CDATA[Reply to Mycovid19 graph doesn't show on webpage through Dataplicity on Mon, 25 Jan 2021 14:28:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blauenfeldt" aria-label="Profile: Blauenfeldt">@<bdi>Blauenfeldt</bdi></a>  the charting tool is drawing directly to the glass</p>
]]></description><link>https://forum.magicmirror.builders/post/87789</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87789</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 Jan 2021 14:28:58 GMT</pubDate></item><item><title><![CDATA[Reply to Mycovid19 graph doesn't show on webpage through Dataplicity on Mon, 25 Jan 2021 13:55:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blauenfeldt" aria-label="Profile: Blauenfeldt">@<bdi>Blauenfeldt</bdi></a> what is a dataplicity web page?</p>
]]></description><link>https://forum.magicmirror.builders/post/87788</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/87788</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 25 Jan 2021 13:55:15 GMT</pubDate></item></channel></rss>
