<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MplayerRadio - No sound]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I’ve installed MMM-MplayerRadio module. The module appears in the mirror but I cannot hear the radio.<br />
I did use the autoplay option to launch it at the beginning.<br />
The module seems to be working because :</p>
<ol>
<li>I can see the notification in the log : MMM-MplayerRadio: Received notification RADIO_PLAY.</li>
<li>the square icon appears in the control section<br />
But no sound… (even if sound is working properly for other modules like GoogleAssistant)</li>
</ol>
<p dir="auto">Any idea on the origin of the problem ? …or on where I can find a log that provides me more detailed info to troubleshoot ?</p>
<p dir="auto">Note : mplayer is intalled and works properly on a test file<br />
Thank you</p>
]]></description><link>https://forum.magicmirror.builders/topic/14549/mmm-mplayerradio-no-sound</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 21:17:49 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14549.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Jan 2021 21:25:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MplayerRadio - No sound on Sat, 30 Jan 2021 23:00:47 GMT]]></title><description><![CDATA[<p dir="auto">I confirm that your workaround worked fine.<br />
customCommand: “/usr/bin/cvlc”,<br />
customCommandArgs: [“###URL###”],</p>
<p dir="auto">Thanks !</p>
]]></description><link>https://forum.magicmirror.builders/post/88013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88013</guid><dc:creator><![CDATA[totofar]]></dc:creator><pubDate>Sat, 30 Jan 2021 23:00:47 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MplayerRadio - No sound on Sat, 30 Jan 2021 22:42:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Thank you very much for your prompt answer.<br />
I had not seen this post. I’ll test this solution right away.<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/88012</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88012</guid><dc:creator><![CDATA[totofar]]></dc:creator><pubDate>Sat, 30 Jan 2021 22:42:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MplayerRadio - No sound on Sat, 30 Jan 2021 21:41:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/totofar" aria-label="Profile: totofar">@<bdi>totofar</bdi></a> Hi, there is already a issue open (<a href="https://github.com/Tom-Hirschberger/MMM-MplayerRadio/issues/7" target="_blank" rel="noopener noreferrer nofollow ugc">see here</a>) for this problem. I searched for a solution but three other guys and me could not find the reason. My current suggestion is to install vlc and use the custom command option to specify it as the player. The only disadvantage is that there is no stream info provided.</p>
]]></description><link>https://forum.magicmirror.builders/post/88010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88010</guid><dc:creator><![CDATA[wishmaster270]]></dc:creator><pubDate>Sat, 30 Jan 2021 21:41:14 GMT</pubDate></item></channel></rss>
