<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Chromecast]]></title><description><![CDATA[<p dir="auto">Hi My Chromecast module is no longer working. It used to.</p>
<p dir="auto">Now i can not see the mirror as an option, please advise</p>
<p dir="auto">config file</p>
<pre><code>/*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
var config = {
  address: "localhost",
  electronOptions: {
    webPreferences: {
      webviewTag: true
  port: 8080,
	{ disabled: false,
  module: 'MMM-NewPIR',
  position: 'bottom_right',
  configDeepMerge: true,
      	screen: {
        delay: 5 * 60 * 1000,
	displayLastPresence: false,
	ecoMode: false,
	displayStyle: "Bar"
      pir: {
        gpio: 4
        module: 'MMM-pages',
                rotationTime: 30 *1000,
		modules:["MMM-Globe",["compliments"],
			["MMM-Globe","MMM-DailyPower",],
			["MMM-Globe","MMM-quote-of-the-day"],
			["MMM-Globe","calendar",'currentweather'],
			["MMM-Globe","calendar",'weatherforecast'],
			["MMM-Globe","MMM-UKNationalRail","MMM-MyCommute",],
			["MMM-Globe",'MMM-Recipe'],
			["MMM-Globe","MMM-weatherforecast"]
                fixed: ["MMM-GoogleAssistant","MMM-Assistant2Display","MMM-ModuleScheduler","clock", "alerts","MMM-NewPIR","MMM-Screencast"],
                hiddenPages: {
                    "screenSaver": [ "clock", "MMM-SomeBackgroundImageModule" ],
                    "admin": [ "MMM-Tools"],
    module: 'MMM-quote-of-the-day',
    position: 'bottom_bar',
             language: "en",
		updateInterval: "1d"   // See below for configurable options
		module: "MMM-Screencast",
		position: 'bottom_right', // This position is for a hidden &lt;div /&gt; and not the screencast window
			position: 'center',
			height: 300,
			width: 500,
  useHttps: false,
  httpsPrivateKey: '',
  httpsCertificate: '',
  logLevel: [
    'INFO',
    'LOG',
    'WARN',
    'ERROR'
<p dir="auto">console log</p>
<pre><code>
loader.js:176 Load script: modules/MMM-Screencast//MMM-Screencast.js
module.js:509 Check MagicMirror version for module 'MMM-Screencast' - Minimum version:  2.1.0 - Current version: 2.14.0
module.js:517 Module registered: MMM-Screencast
loader.js:148 Bootstrapping module: MMM-Screencast
loader.js:153 Scripts loaded for: MMM-Screencast
loader.js:155 Styles loaded for: MMM-Screencast
loader.js:157 Translations loaded for: MMM-Screencast
MMM-Screencast.js:15 Starting module: MMM-Screencast
MMM-quote-of-the-day.js:135 [MMM-quote-of-the-day] received a module notification: MMM-Screencast:START-DIAL from sender: MMM-Screencast
module.js:206 MMM-Screencast is resumed.
module.js:199 MMM-Screencast is suspended.
<p dir="auto">PM2 Logs</p>
<pre><code>[TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
/home/pi/.pm2/pm2.log last 15 lines:
PM2        | 2021-01-31T11:41:49: PM2 log: App [mm:0] online
PM2        | 2021-01-31T12:05:17: PM2 log: Stopping app:mm id:0
PM2        | 2021-01-31T12:05:17: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
PM2        | 2021-01-31T12:05:17: PM2 log: pid=16926 msg=process killed
PM2        | 2021-01-31T12:05:17: PM2 log: App [mm:0] starting in -fork mode-
PM2        | 2021-01-31T12:05:17: PM2 log: App [mm:0] online
PM2        | 2021-01-31T12:05:34: PM2 log: Stopping app:mm id:0
PM2        | 2021-01-31T12:05:35: PM2 log: pid=25612 msg=failed to kill - retrying in 100ms
PM2        | 2021-01-31T12:05:35: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
PM2        | 2021-01-31T12:05:35: PM2 log: pid=25612 msg=process killed
PM2        | 2021-01-31T12:05:35: PM2 log: App [mm:0] starting in -fork mode-
PM2        | 2021-01-31T12:05:35: PM2 log: App [mm:0] online
PM2        | 2021-01-31T12:17:27: PM2 log: App [mm:0] exited with code [0] via signal [SIGINT]
PM2        | 2021-01-31T12:17:27: PM2 log: App [mm:0] starting in -fork mode-
PM2        | 2021-01-31T12:17:27: PM2 log: App [mm:0] online
/home/pi/.pm2/logs/mm-error.log last 15 lines:
0|mm       |     at Socket.&lt;anonymous&gt; (/home/pi/MagicMirror/js/node_helper.js:112:11)
0|mm       |     at Socket.emit (events.js:210:5)
0|mm       |     at Socket.onevent (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:253:20)
0|mm       |     at Socket.socket.onevent (/home/pi/MagicMirror/js/node_helper.js:105:13)
0|mm       |     at Socket._onpacket (/home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:216:22)
0|mm       |     at /home/pi/MagicMirror/node_modules/socket.io/dist/client.js:205:28
0|mm       |     at processTicksAndRejections (internal/process/task_queues.js:75:11) {
0|mm       |   code: 'EADDRINUSE',
0|mm       |   errno: 'EADDRINUSE',
0|mm       |   syscall: 'listen',
0|mm       |   address: '::',
0|mm       |   port: 8569
0|mm       | }
0|mm       | [31.01.2021 12:17.41.300] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|mm       | [31.01.2021 12:17.41.301] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
/home/pi/.pm2/logs/mm-out.log last 15 lines:
0|mm       |       upgradeOrConnect: false,
0|mm       |       parser: null,
0|mm       |       maxHeadersCount: null,
0|mm       |       _redirectable: [Circular],
0|mm       |       [Symbol(kNeedDrain)]: false,
0|mm       |       [Symbol(isCorked)]: false,
0|mm       |       [Symbol(kOutHeaders)]: [Object: null prototype]
0|mm       |     },
0|mm       |     _currentUrl: 'https://www.poemist.com/api/v1/randompoems'
0|mm       |   },
0|mm       |   response: undefined,
0|mm       |   isAxiosError: true,
0|mm       |   toJSON: [Function: toJSON]
0|mm       | }
0|mm       | [31.01.2021 12:23.45.920] [LOG]   there was most likely an error fetching poems from https://www.poemist.com/api/v1/randompoems, waiting 5 mins before trying again
]]></description><link>https://forum.magicmirror.builders/topic/14552/mmm-chromecast</link><generator>RSS for Node</generator><lastBuildDate>Thu, 13 Aug 2026 00:10:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14552.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 31 Jan 2021 12:30:18 GMT</pubDate><ttl>60</ttl></channel></rss>
