<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Freeze of the MagicMirror after few seconds]]></title><description><![CDATA[<p dir="auto">Hello :)</p>
<p dir="auto">Im just installing a MagicMirror and I meet an issue.<br />
All was working fine since a couple of days but since today, my MagicMirror freeze after less than a minute ON.<br />
I can do what I want on the RPI, it’s still reachable. But my screen is frozen (clock, calendar,… they are all stopped)</p>
<p dir="auto">If I open a browser window, like http://RPI_ip:8080, I will have the screen with all the modules working and here also after few seconds it freeze.<br />
If I open another tab it will work for some seconds, …<br />
So the RPI is not frozen, only my screen!</p>
<p dir="auto">The only way is to reboot the RPI but the screen freeze once again after few seconds.</p>
<p dir="auto">Thinking it’s because of some modules, I delete some and also put on <strong>//</strong> the ones I’m using, on the config file. Trying to work on minimal module config with only clock and calendar for example… but still the same.</p>
<p dir="auto"><strong>More info :</strong></p>
<ul>
<li>RPI3 b with official RPI power adaptateur(2,5A)</li>
<li>Magicmirror OS installed</li>
<li><em>Installed Modules :</em><br />
default;  MMM-EasyBack;  MMM-Traffic;  MMM-VigilanceMeteoFrance;  next-train-transilien;  node_modules;  package.json;  package-lock.json</li>
</ul>
<p dir="auto"><strong>pi@magicmirroros:~ $ free -m</strong><br />
total        used        free      shared  buff/cache   available<br />
Mem:            925         307         272          20         345         550<br />
Swap:          1023           0        1023</p>
<p dir="auto"><strong>pi@magicmirroros:~ $ top</strong></p>
<p dir="auto">top - 13:33:50 up 7 min,  2 users,  load average: 1.14, 0.97, 0.49<br />
Tasks: 127 total,   2 running, 125 sleeping,   0 stopped,   0 zombie<br />
%Cpu(s): 25.2 us,  0.2 sy,  0.0 ni, 74.6 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st<br />
MiB Mem :    925.6 total,    216.8 free,    276.8 used,    432.0 buff/cache<br />
MiB Swap:    100.0 total,     95.2 free,      4.8 used.    571.2 avail Mem</p>
<p dir="auto">PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND<br />
1073 pi        20   0  296732  90036  68688 R <strong>101.0</strong>   9.5   5:45.40 <strong>electron</strong><br />
1108 pi        20   0   12236   4124   3344 S   0.7   0.4   0:00.06 sshd<br />
1166 pi        20   0   10312   2972   2444 R   0.7   0.3   0:00.06 top<br />
1148 root      20   0       0      0      0 I   0.3   0.0   0:00.02 kworker/2:1-events</p>
<p dir="auto">Do you have any advice ?<br />
Thanks ;)</p>
]]></description><link>https://forum.magicmirror.builders/topic/14596/freeze-of-the-magicmirror-after-few-seconds</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 04:21:43 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14596.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 10 Feb 2021 14:44:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Freeze of the MagicMirror after few seconds on Thu, 11 Feb 2021 17:30:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alexhoud" aria-label="Profile: alexhoud">@<bdi>alexhoud</bdi></a><br />
Do you have some special config for Compliment module as morning: “…”?</p>
]]></description><link>https://forum.magicmirror.builders/post/88337</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88337</guid><dc:creator><![CDATA[comopat]]></dc:creator><pubDate>Thu, 11 Feb 2021 17:30:43 GMT</pubDate></item><item><title><![CDATA[Reply to Freeze of the MagicMirror after few seconds on Thu, 11 Feb 2021 14:17:23 GMT]]></title><description><![CDATA[<p dir="auto">Can be closed! I find by my own :)<br />
Too many lines with // in my config file… make the MagicMirror freezing…<br />
Removing all the // at the beginning of all the module I don’t want and replace it by :<br />
disabled: true,</p>
<p dir="auto">Bye</p>
]]></description><link>https://forum.magicmirror.builders/post/88329</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88329</guid><dc:creator><![CDATA[alexhoud]]></dc:creator><pubDate>Thu, 11 Feb 2021 14:17:23 GMT</pubDate></item></channel></rss>
