<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there a module that lets you toggle other modules on&#x2F;off depending on certain conditions or a timer?]]></title><description><![CDATA[<p dir="auto">Hehey,<br />
New here and just set up a mirrorless  version. I would like to have a slide show using images from google photos/drive/blabla and, either depending on which image it is (if (image==“bg_weather.jpg”…), turn on/off modules, or, use some slide show module for 1 loop, and then 10 sec where the slideshow module is off and instead are showing time and weather on some custom background. Pref. fading the modules on/off.</p>
<p dir="auto">So the end result in either solution would be no modules showing and only image 1 for 10 sec, image 2 for 10 sec, image 3 for 10 sec … and then 10 sec with no image/custom bg and time and weather module showing. And then back to no modules showing and looping through the images again. New here, so perhaps there already is a solution/module…activator(?) out there, but I just haven’t found it yet.</p>
<p dir="auto">Cheers!</p>
]]></description><link>https://forum.magicmirror.builders/topic/14600/is-there-a-module-that-lets-you-toggle-other-modules-on-off-depending-on-certain-conditions-or-a-timer</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 13:46:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14600.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Feb 2021 15:17:51 GMT</pubDate><ttl>60</ttl></channel></rss>
