<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Default Clock Module showing wrong Sunrise/Sunset Time]]></title><description><![CDATA[<p dir="auto">It is currently showing that the sun will rise at 10:19am and set at 8:30pm. I have set the timezone with “America/Toronto”. When it should be ~7:20am, 5:45pm.</p>
<p dir="auto">I have seen some other modules so I might just disable and use those.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14618/default-clock-module-showing-wrong-sunrise-sunset-time</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 06:32:11 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14618.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Feb 2021 20:38:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Default Clock Module showing wrong Sunrise/Sunset Time on Sun, 14 Feb 2021 01:05:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Helps to read sometimes. Thank you.</p>
]]></description><link>https://forum.magicmirror.builders/post/88442</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88442</guid><dc:creator><![CDATA[jamaces]]></dc:creator><pubDate>Sun, 14 Feb 2021 01:05:29 GMT</pubDate></item><item><title><![CDATA[Reply to Default Clock Module showing wrong Sunrise/Sunset Time on Sun, 14 Feb 2021 00:18:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jamaces" aria-label="Profile: jamaces">@<bdi>jamaces</bdi></a> did u specify the lat/lng config parms for the clock. to tell it where u are.located?</p>
<p dir="auto"><a href="https://docs.magicmirror.builders/modules/clock.html#configuration-options" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/modules/clock.html#configuration-options</a></p>
]]></description><link>https://forum.magicmirror.builders/post/88437</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88437</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 14 Feb 2021 00:18:43 GMT</pubDate></item></channel></rss>
