<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-iFrame-Ping  - revisited]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I’m streaming video/music from a web but, for some reason, the audio doesn’t go through on a P0 it does on a P4 using the same config, however,</p>
<p dir="auto">Youtube and audio tests pass on both pies.</p>
<p dir="auto">Is there any reason for that?<br />
TIA</p>
]]></description><link>https://forum.magicmirror.builders/topic/14639/mmm-iframe-ping-revisited</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 21:12:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14639.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 16 Feb 2021 19:44:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-iFrame-Ping  - revisited on Wed, 17 Feb 2021 13:43:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ebolisa" aria-label="Profile: ebolisa">@<bdi>ebolisa</bdi></a> pi 0 is tough to of a lot different things at once</p>
]]></description><link>https://forum.magicmirror.builders/post/88575</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88575</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 17 Feb 2021 13:43:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-iFrame-Ping  - revisited on Wed, 17 Feb 2021 13:40:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> making progress by tweaking a bit the line shown above to</p>
<pre><code>chromium-browser --autoplay-policy=no-user-gesture-required --noerrdialogs --incognito --kiosk -start_maximized  --disable-features=AudioServiceSandbox --disable-infobars --app=...
<p dir="auto">However, streaming video on a P0 is not the best way to go so, I decided to just stream audio with this link <a href="http://stream-uk1.radioparadise.com/mp3-192" target="_blank" rel="noopener noreferrer nofollow ugc">http://stream-uk1.radioparadise.com/mp3-192</a>. It’s much easer on buffering ;)</p>
]]></description><link>https://forum.magicmirror.builders/post/88574</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88574</guid><dc:creator><![CDATA[ebolisa]]></dc:creator><pubDate>Wed, 17 Feb 2021 13:40:14 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-iFrame-Ping  - revisited on Wed, 17 Feb 2021 13:37:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kamischami" aria-label="Profile: kamischami">@<bdi>kamischami</bdi></a> according to this,</p>
<p dir="auto"><a href="https://peter.sh/experiments/chromium-command-line-switches/" target="_blank" rel="noopener noreferrer nofollow ugc">https://peter.sh/experiments/chromium-command-line-switches/</a></p>
<p dir="auto">the</p>
<p dir="auto">–mute-audio</p>
<p dir="auto">parm should mute any audio</p>
]]></description><link>https://forum.magicmirror.builders/post/88573</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88573</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 17 Feb 2021 13:37:53 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-iFrame-Ping  - revisited on Wed, 17 Feb 2021 08:06:35 GMT]]></title><description><![CDATA[<p dir="auto">I also stream YouTube videos but I don’t !!! want to hear any sound. Does the module regularly play no sound?</p>
]]></description><link>https://forum.magicmirror.builders/post/88566</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88566</guid><dc:creator><![CDATA[KamiSchami]]></dc:creator><pubDate>Wed, 17 Feb 2021 08:06:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-iFrame-Ping  - revisited on Tue, 16 Feb 2021 22:07:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ebolisa" aria-label="Profile: ebolisa">@<bdi>ebolisa</bdi></a> correct.</p>
<p dir="auto">the second way probably fails because u are on an ssh session, and need to define the DISPLAY to use</p>
<p dir="auto">export DISPLAY=:0</p>
]]></description><link>https://forum.magicmirror.builders/post/88560</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88560</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Feb 2021 22:07:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-iFrame-Ping  - revisited on Tue, 16 Feb 2021 21:25:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> you mean in line 78?</p>
<pre><code>chromium-browser -noerrdialogs -kiosk -start_maximized  --disable-features=AudioServiceSandbox --disable-infobars --app=...
<p dir="auto">the other way I get an error:</p>
<pre><code>pi@magicmirror:~/MagicMirror $ chromium-browser --disable-features=AudioServiceSandbox
[1974:1974:0216/221501.872136:ERROR:browser_main_loop.cc(1432)] Unable to open X display.
]]></description><link>https://forum.magicmirror.builders/post/88554</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88554</guid><dc:creator><![CDATA[ebolisa]]></dc:creator><pubDate>Tue, 16 Feb 2021 21:25:04 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-iFrame-Ping  - revisited on Tue, 16 Feb 2021 20:03:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ebolisa" aria-label="Profile: ebolisa">@<bdi>ebolisa</bdi></a> on a pi0  you are running chromium-browser, on a pi4, u are using electron js browser</p>
<p dir="auto">i suspect u have to do some setup on chromium</p>
<p dir="auto">see the 4th post here<br />
<a href="https://www.raspberrypi.org/forums/viewtopic.php?t=291066" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/forums/viewtopic.php?t=291066</a></p>
<p dir="auto">add the parm to the invocation of chromium in ~/MagicMirror/run-start.sh</p>
]]></description><link>https://forum.magicmirror.builders/post/88553</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88553</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 16 Feb 2021 20:03:02 GMT</pubDate></item></channel></rss>
