<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-SytemStat does not work :(]]></title><description><![CDATA[<p dir="auto">Hi there, I am new to the RaspberryPi and MM but I like MM very much. Hence I added and module and modified the sttings of the basic modules.</p>
<p dir="auto">I am running MMM-EasyBack additionaly. Now I tried to install the SystemStat. I like this module very much but it doesn´t load. I did everything according to the setup instruction. As dependency I found “async”. I have no idea whether I have to install async or whether this is part of the system. I am using a PI4B and the current version of the OS. Help would be very appreciated…</p>
]]></description><link>https://forum.magicmirror.builders/topic/14649/mmm-sytemstat-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 01:19:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14649.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Feb 2021 08:07:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-SytemStat does not work :( on Mon, 01 Mar 2021 14:21:02 GMT]]></title><description><![CDATA[<p dir="auto">after re-installing it works like it should (-:</p>
]]></description><link>https://forum.magicmirror.builders/post/89029</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89029</guid><dc:creator><![CDATA[JoeyK]]></dc:creator><pubDate>Mon, 01 Mar 2021 14:21:02 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-SytemStat does not work :( on Thu, 18 Feb 2021 13:43:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joeyk" aria-label="Profile: joeyk">@<bdi>joeyk</bdi></a></p>
<p dir="auto">The module readMe should explain how to install any dependencies, if any</p>
]]></description><link>https://forum.magicmirror.builders/post/88603</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/88603</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Thu, 18 Feb 2021 13:43:35 GMT</pubDate></item></channel></rss>
