<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[In which operating system it work]]></title><description><![CDATA[<p dir="auto">hello all i am beginner of mm. i am not getting in which software it work i.e. windows / lenux.<br />
Thankyou in Advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/1469/in-which-operating-system-it-work</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 17:17:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1469.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Jan 2017 10:15:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to In which operating system it work on Sat, 21 Jan 2017 16:19:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/acrylicmfg" aria-label="Profile: acrylicmfg">@<bdi>acrylicmfg</bdi></a> I don’t mind you asking around, after a few post it seems that you don’t have that background that other forum people have. <a href="https://www.youtube.com/results?search_query=install+raspbian+on+raspberry" target="_blank" rel="noopener noreferrer nofollow ugc">My answer would be that a video would be a good guide for you, try youtube</a></p>
]]></description><link>https://forum.magicmirror.builders/post/11886</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11886</guid><dc:creator><![CDATA[PindaPower]]></dc:creator><pubDate>Sat, 21 Jan 2017 16:19:04 GMT</pubDate></item><item><title><![CDATA[Reply to In which operating system it work on Sat, 21 Jan 2017 14:31:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/acrylicmfg" aria-label="Profile: acrylicmfg">@<bdi>acrylicmfg</bdi></a> the img file is there, it’s as it should be. Unzip the img file to wherever you like and then follow this guide :</p>
<p dir="auto"><a href="https://www.raspberrypi.org/documentation/installation/installing-images/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/documentation/installation/installing-images/</a></p>
]]></description><link>https://forum.magicmirror.builders/post/11868</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11868</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Sat, 21 Jan 2017 14:31:04 GMT</pubDate></item><item><title><![CDATA[Reply to In which operating system it work on Sat, 21 Jan 2017 11:41:37 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/uploads/files/1484998841417-untitled.jpg" alt="0_1484998838499_Untitled.jpg" class=" img-fluid img-markdown" /><br />
iAM GETTING THIS EARROR BY DOWNLOAD THE EXTRACT.</p>
]]></description><link>https://forum.magicmirror.builders/post/11842</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11842</guid><dc:creator><![CDATA[acrylicmfg]]></dc:creator><pubDate>Sat, 21 Jan 2017 11:41:37 GMT</pubDate></item><item><title><![CDATA[Reply to In which operating system it work on Fri, 20 Jan 2017 12:14:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/acrylicmfg" aria-label="Profile: acrylicmfg">@<bdi>acrylicmfg</bdi></a></p>
<p dir="auto"><a href="https://www.raspberrypi.org/downloads/raspbian/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.org/downloads/raspbian/</a></p>
<p dir="auto">Choose raspbian lite, follow the instruction on how to install it to the SD card.</p>
<p dir="auto">Then you go to : <a href="https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MichMich/MagicMirror/wiki/Jessie-Lite-Installation-Guide</a></p>
<p dir="auto">And follow that guide to install the mirror and adjust your raspberry pi to the default mirror setttings.</p>
]]></description><link>https://forum.magicmirror.builders/post/11740</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11740</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Fri, 20 Jan 2017 12:14:14 GMT</pubDate></item><item><title><![CDATA[Reply to In which operating system it work on Fri, 20 Jan 2017 11:26:39 GMT]]></title><description><![CDATA[<p dir="auto">Dear PindaPower ,</p>
<pre><code>     Thank you for helping me i tried to download zip file.
<p dir="auto">The zip files but after downloading- astrict the file- it show emty folder if you can upload a file on net and sent me desire link. so i can down load from that.<br />
Thankyou</p>
]]></description><link>https://forum.magicmirror.builders/post/11734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11734</guid><dc:creator><![CDATA[acrylicmfg]]></dc:creator><pubDate>Fri, 20 Jan 2017 11:26:39 GMT</pubDate></item><item><title><![CDATA[Reply to In which operating system it work on Fri, 20 Jan 2017 10:58:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pindapower" aria-label="Profile: PindaPower">@<bdi>PindaPower</bdi></a> <img src="/uploads/files/1484909874653-pi-3.jpg" alt="0_1484909870970_Pi 3 .jpg" class=" img-fluid img-markdown" /><br />
which one<br />
Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/post/11731</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11731</guid><dc:creator><![CDATA[acrylicmfg]]></dc:creator><pubDate>Fri, 20 Jan 2017 10:58:17 GMT</pubDate></item><item><title><![CDATA[Reply to In which operating system it work on Fri, 20 Jan 2017 10:41:50 GMT]]></title><description><![CDATA[<p dir="auto">If you use a Raspberry Pi then the OS is (most off the time) Raspbian and that is a Linux base system. As an application MM run’s on it.</p>
]]></description><link>https://forum.magicmirror.builders/post/11730</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/11730</guid><dc:creator><![CDATA[PindaPower]]></dc:creator><pubDate>Fri, 20 Jan 2017 10:41:50 GMT</pubDate></item></channel></rss>
