<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[.&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">when I  try to start mm she give me this error msg</p>
<p dir="auto">can anyone help me please !</p>
<p dir="auto"><img src="/assets/uploads/files/1614691120092-f860d263-f976-40d4-82e3-f9ffeaf6bab5-image.png" alt="f860d263-f976-40d4-82e3-f9ffeaf6bab5-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/14726/node_modules-bin-electron-js-electron-js-problem</link><generator>RSS for Node</generator><lastBuildDate>Wed, 13 May 2026 21:35:59 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14726.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Mar 2021 13:22:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 20:04:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> for some reason the electron installer (not our code) has decided this is a 32 bit machine. and there is no 32bit electron available for intel.</p>
<p dir="auto">I think I will open an issue over there.<br />
my previous install worked fine…</p>
]]></description><link>https://forum.magicmirror.builders/post/89079</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89079</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 20:04:23 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 19:01:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/89074">./node_modules/.bin/electron js / electron.js Problem</a>:</p>
<p dir="auto">weir</p>
<p dir="auto">Hello,</p>
<p dir="auto">it’s work, thank you for your support can you please explain to me what was the isssue.</p>
]]></description><link>https://forum.magicmirror.builders/post/89077</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89077</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 19:01:10 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 16:37:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> ok, remove the MM folder and redo the install script…   should set it up properly now…</p>
<p dir="auto">for some reason the electron test for this OS returns 32 bit, but the OS says 64…<br />
weird…</p>
]]></description><link>https://forum.magicmirror.builders/post/89074</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89074</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 16:37:53 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 16:31:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/89071">./node_modules/.bin/electron js / electron.js Problem</a>:</p>
<p dir="auto">I am fixing install and run scripts…<br />
testing now…</p>
<p dir="auto">thanx i wait four your order to test the script …</p>
]]></description><link>https://forum.magicmirror.builders/post/89072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89072</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 16:31:29 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 16:18:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> should be able to… please wait, I am fixing install and run scripts…<br />
testing now…</p>
]]></description><link>https://forum.magicmirror.builders/post/89071</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89071</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 16:18:53 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 16:18:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for your support</p>
<p dir="auto">can i  install mm on debian 64 bit ?</p>
]]></description><link>https://forum.magicmirror.builders/post/89070</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89070</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 16:18:08 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 15:16:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> on my install I see these messages</p>
<pre><code>Official Linux/ia32 support is deprecated.
For more info: https://electronjs.org/blog/linux-32bit-support
]]></description><link>https://forum.magicmirror.builders/post/89069</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89069</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 15:16:37 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 14:50:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">yes i’m using graphical desktop</p>
]]></description><link>https://forum.magicmirror.builders/post/89068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89068</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:50:03 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 14:47:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> hm… you are running the graphical desktop, right?  you must for electron to run</p>
<p dir="auto">if u are running cli mode, then no graphics…</p>
<p dir="auto">only asking cause its not complaining and failing to install…</p>
<p dir="auto">i will recheck on my system as soon as I can … got a big copy going on and am short of disk space at the moment…</p>
]]></description><link>https://forum.magicmirror.builders/post/89067</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89067</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:47:19 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 14:44:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">they give the same result ,</p>
<p dir="auto">pi@raspberry:~/MagicMirror $ npm install electron</p>
<p dir="auto">up to date, audited 1112 packages in 6s</p>
<p dir="auto">88 packages are looking for funding<br />
run <code>npm fund</code> for details</p>
<p dir="auto">5 vulnerabilities (4 low, 1 moderate)</p>
<p dir="auto">To address all issues (including breaking changes), run:<br />
npm audit fix --force</p>
<p dir="auto">Run <code>npm audit</code> for details.<br />
pi@raspberry:~/MagicMirror $ npm start</p>
<p dir="auto">magicmirror@2.14.0 start<br />
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
<p dir="auto">sh: 1: ./node_modules/.bin/electron: not found<br />
![alt text](image url)</p>
]]></description><link>https://forum.magicmirror.builders/post/89066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89066</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:44:36 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 14:37:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> wow… not even a complaint…</p>
<p dir="auto">ok, try this</p>
<p dir="auto">npm install electron</p>
<p dir="auto">you’ll get the latest, but it should work…</p>
]]></description><link>https://forum.magicmirror.builders/post/89065</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89065</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:37:54 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 14:32:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/89063">./node_modules/.bin/electron js / electron.js Problem</a>:</p>
<p dir="auto">npm install electron@8.5.3</p>
<p dir="auto">Below you find the result</p>
<p dir="auto">pi@raspberry:~/MagicMirror $ npm install electron@8.5.3<br />
npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see <a href="https://github.com/request/request/issues/3142" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/request/request/issues/3142</a><br />
npm WARN deprecated urix@0.1.0: Please see <a href="https://github.com/lydell/urix#deprecated" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/lydell/urix#deprecated</a><br />
npm WARN deprecated resolve-url@0.2.1: <a href="https://github.com/lydell/resolve-url#deprecated" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/lydell/resolve-url#deprecated</a><br />
npm WARN deprecated @babel/polyfill@7.12.1: 🚨 This package has been deprecated in favor of separate inclusion of a polyfill and regenerator-runtime (when needed). See the @babel/polyfill docs (<a href="https://babeljs.io/docs/en/babel-polyfill" target="_blank" rel="noopener noreferrer nofollow ugc">https://babeljs.io/docs/en/babel-polyfill</a>) for more information.<br />
npm WARN deprecated gitlab@10.2.1: The gitlab package has found a new home in the @gitbeaker organization. For the latest gitlab node library, check out @gitbeaker/node. A full list of the features can be found here: <a href="https://github.com/jdalrymple/gitbeaker#readme" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/jdalrymple/gitbeaker#readme</a><br />
npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next<br />
npm WARN deprecated core-js@2.6.12: core-js@&lt;3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.</p>
<p dir="auto">added 813 packages, and audited 1112 packages in 20s</p>
pi@raspberry:~/MagicMirror $</p>
]]></description><link>https://forum.magicmirror.builders/post/89064</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89064</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:32:58 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 14:26:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> weird…</p>
<p dir="auto">can you do and show output of</p>
<pre><code>cd ~/MagicMirror
]]></description><link>https://forum.magicmirror.builders/post/89063</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89063</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:26:05 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 14:20:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  thanx for your response</p>
<p dir="auto">install starting  - Tue Mar  2 04:00:50 HST 2021<br />
installing on x86_64 processor system<br />
the os is Distributor ID: Debian Description: Debian GNU/Linux 10 (buster) Release: 10 Codename: buster<br />
[96mUpdating packages …[90m<br />
Get:1 <a href="http://security.debian.org" target="_blank" rel="noopener noreferrer nofollow ugc">http://security.debian.org</a> buster/updates InRelease [65.4 kB] Hit:2 <a href="http://ftp.debian.org/debian" target="_blank" rel="noopener noreferrer nofollow ugc">http://ftp.debian.org/debian</a> buster InRelease Hit:3 <a href="http://archive.raspberrypi.org/debian" target="_blank" rel="noopener noreferrer nofollow ugc">http://archive.raspberrypi.org/debian</a> buster InRelease Get:4 <a href="http://packages.microsoft.com/repos/code" target="_blank" rel="noopener noreferrer nofollow ugc">http://packages.microsoft.com/repos/code</a> stable InRelease [10.4 kB] Get:5 <a href="http://ftp.debian.org/debian" target="_blank" rel="noopener noreferrer nofollow ugc">http://ftp.debian.org/debian</a> buster-updates InRelease [51.9 kB] Hit:6 <a href="https://deb.nodesource.com/node_11.x" target="_blank" rel="noopener noreferrer nofollow ugc">https://deb.nodesource.com/node_11.x</a> buster InRelease Get:7 <a href="http://packages.microsoft.com/repos/code" target="_blank" rel="noopener noreferrer nofollow ugc">http://packages.microsoft.com/repos/code</a> stable/main arm64 Packages [16.0 kB] Get:8 <a href="http://packages.microsoft.com/repos/code" target="_blank" rel="noopener noreferrer nofollow ugc">http://packages.microsoft.com/repos/code</a> stable/main armhf Packages [15.8 kB] Get:9 <a href="http://packages.microsoft.com/repos/code" target="_blank" rel="noopener noreferrer nofollow ugc">http://packages.microsoft.com/repos/code</a> stable/main amd64 Packages [15.4 kB] Fetched 175 kB in 2s (72.7 kB/s) Reading package lists…<br />
apt-get update  completed ok<br />
apt-get upgrade  started<br />
apt upgrade result =rc=0 Reading package lists…<br />
Building dependency tree…<br />
Reading state information…<br />
Calculating upgrade…<br />
The following packages have been kept back:<br />
linux-headers-amd64:amd64 linux-image-amd64:amd64<br />
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.<br />
[96mInstalling helper tools …[90m<br />
build-essential is already the newest version (12.6).<br />
curl is already the newest version (7.64.0-4+deb10u1).<br />
git is already the newest version (1:2.20.1-2+deb10u3).<br />
unzip is already the newest version (6.0-23+deb10u2).<br />
wget is already the newest version (1.20.1-1.1).<br />
wget set to manually installed.<br />
[96mCheck current Node installation …[0m<br />
[0mNode currently installed. Checking version number.<br />
[0mMinimum Node version: [1mv10.1.0[0m<br />
[0mInstalled Node version: [1mv10.24.0[0m<br />
[92mNo Node.js upgrade necessary.[0m<br />
[96mCheck current NPM installation …[0m<br />
[0mNPM currently installed. Checking version number.<br />
[0mMinimum npm version: [1mV6.0.0[0m<br />
[0mInstalled npm version: [1mV7.6.0[0m<br />
[92mNo npm upgrade necessary.[0m<br />
[96mCloning MagicMirror …[90m<br />
[92mCloning MagicMirror Done![90m<br />
package.json update for x86 fontface completed ok<br />
[96mInstalling dependencies …[90m<br />
[92mDependencies installation Done![90m<br />
setting up initial config.js<br />
[96mCheck plymouth installation …[0m<br />
[90mSplashscreen: Checking themes directory.[0m<br />
[90mSplashscreen: Create theme directory if not exists.[0m<br />
[92mSplashscreen: Changed theme to MagicMirror successfully.[0m<br />
install and setup pm2<br />
pm2 not installed, installing<br />
pm2 install result npm WARN deprecated debug@4.1.1: Debug versions &gt;=3.2.0 &lt;3.2.7 || &gt;=4 &lt;4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (<a href="https://github.com/visionmedia/debug/issues/797" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/visionmedia/debug/issues/797</a>) npm WARN deprecated debug@4.1.1: Debug versions &gt;=3.2.0 &lt;3.2.7 || &gt;=4 &lt;4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (<a href="https://github.com/visionmedia/debug/issues/797" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/visionmedia/debug/issues/797</a>) added 201 packages, and audited 202 packages in 19s 9 packages are looking for funding run <code>npm fund</code> for details found 0 vulnerabilities<br />
get the pm2 platform specific startup command<br />
startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi</p>
<pre><code>                    -------------
<p dir="auto"><strong>/\\\\\\_</strong><em>/\\</em><em><strong><strong><strong><strong><strong>/\\</strong></strong>/\\\\_</strong></strong><br />
_/\/////////\_/\\\</strong></em><em><strong><strong>/\\\</strong>/\///////\_</strong><br />
<em>/\_</em></em><em><em><strong>/\_/\//\_</strong></em>/\//\_///</em><em><em><strong><em>//\_</em><br />
_/\\\\\\/</strong>/\\///\/\/</em>/\_</em><strong><em><em><strong><em><strong>/\/</strong></em><br />
<em>/\/////////</em></strong></em>/\_</em>///\/</strong><em>/\_</em><strong><strong><strong>/\//_____<br />
<em>/\_</em></strong></strong></strong><strong><em><strong>/\_</strong></em>///</strong><em><strong>/\_____/\//</strong></em>_____<br />
<em>/\_</em><em><strong><strong><strong><strong><strong>/\_</strong></strong></strong></strong></strong></em><em>/\_</em><em>/\/</em>__________<br />
<em>/\_</em><em><strong><strong><strong><strong><strong>/\_</strong></strong></strong></strong></strong></em><em>/\_</em>/\\\\\\\_<br />
_///<strong><strong><strong><strong><strong><strong><strong>///</strong></strong></strong></strong></strong></strong></strong>///<strong>///////////////</strong></p>
<pre><code>                      Runtime Edition
    PM2 is a Production Process Manager for Node.js applications
                 with a built-in Load Balancer.
            Start and Daemonize any application:
            $ pm2 start app.js
            Load Balance 4 instances of api.js:
            $ pm2 start api.js -i 4
            Monitor in production:
            $ pm2 monitor
            Make pm2 auto-boot at server restart:
            $ pm2 startup
            To go further checkout:
            http://pm2.io/
<p dir="auto">[PM2] Init System found: systemd<br />
Platform systemd<br />
Template<br />
[Unit]<br />
Description=PM2 process manager<br />
Documentation=<a href="https://pm2.keymetrics.io/" target="_blank" rel="noopener noreferrer nofollow ugc">https://pm2.keymetrics.io/</a><br />
After=network.target</p>
<p dir="auto">[Service]<br />
Type=forking<br />
User=pi<br />
LimitNOFILE=infinity<br />
LimitNPROC=infinity<br />
LimitCORE=infinity<br />
Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin<br />
Environment=PM2_HOME=/home/pi/.pm2<br />
PIDFile=/home/pi/.pm2/pm2.pid<br />
Restart=on-failure</p>
<p dir="auto">ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect<br />
ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all<br />
ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill</p>
<p dir="auto">[Install]<br />
WantedBy=multi-user.target</p>
<p dir="auto">Target path<br />
/etc/systemd/system/pm2-pi.service<br />
Command list<br />
[ ‘systemctl enable pm2-pi’ ]<br />
[PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service<br />
[PM2] Making script booting at startup…<br />
</p><div class="plugin-markdown"><input type="checkbox" />Executing: systemctl enable pm2-pi…</div><br />
[PM2] [v] Command successfully executed.<br />
±--------------------------------------+<br />
[PM2] Freeze a process list on reboot via:<br />
$ pm2 save<p></p>
<p dir="auto">[PM2] Remove init script via:<br />
$ pm2 unstartup systemd<br />
pm2 startup command done<br />
configure the pm2 config file for MagicMirror<br />
start MagicMirror via pm2 now<br />
save MagicMirror pm2 config now<br />
stop MagicMirror via pm2 now<br />
disable screensaver via gsettings was true and uint32 300<br />
disable screensaver via lightdm.conf<br />
disable screensaver via lxsession<br />
[92mWe’re ready! Run [1m[97mpm2 start MagicMirror[0m[92m from the ~/MagicMirror directory to start your MagicMirror.[0m<br />
install completed - Tue Mar  2 04:04:51 HST 2021</p>
]]></description><link>https://forum.magicmirror.builders/post/89062</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89062</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:20:09 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 14:11:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> can u post ~/install.log<br />
or send to my email, sdetweil  at gmail</p>
]]></description><link>https://forum.magicmirror.builders/post/89061</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89061</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:11:24 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 14:10:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  thanks for responding</p>
<p dir="auto">I try with your scrip they give the same error</p>
<p dir="auto"><img src="/assets/uploads/files/1614694205920-44438cdb-08a0-4ef7-b041-9f27a041eff7-image.png" alt="44438cdb-08a0-4ef7-b041-9f27a041eff7-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/89060</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89060</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 14:10:07 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 13:59:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> interesting…</p>
<p dir="auto">still suggest using my script…</p>
]]></description><link>https://forum.magicmirror.builders/post/89059</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89059</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 13:59:34 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 13:49:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  thanks for your response again</p>
<p dir="auto">uname -m  give me this result x86_64</p>
<p dir="auto"><img src="/assets/uploads/files/1614692857360-29f87250-a425-48eb-a5e4-0dea1465a8ff-image.png" alt="29f87250-a425-48eb-a5e4-0dea1465a8ff-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/89057</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89057</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 13:49:15 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 13:47:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/89055">./node_modules/.bin/electron js / electron.js Problem</a>:</p>
<p dir="auto">unamed -m</p>
]]></description><link>https://forum.magicmirror.builders/post/89056</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89056</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 13:47:10 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 13:40:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> what processor is this on?  I just fixed the install script for 32bit systems</p>
<p dir="auto">unamed -m<br />
output is i686</p>
]]></description><link>https://forum.magicmirror.builders/post/89055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89055</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 13:40:00 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 13:35:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for your response</p>
<p dir="auto">it’s raspberry pi Desktop Version</p>
]]></description><link>https://forum.magicmirror.builders/post/89054</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89054</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Tue, 02 Mar 2021 13:35:12 GMT</pubDate></item><item><title><![CDATA[Reply to .&#x2F;node_modules&#x2F;.bin&#x2F;electron js &#x2F; electron.js Problem on Tue, 02 Mar 2021 13:28:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> is this a pi0?</p>
<p dir="auto">if so, remove the mm folder and use my script to do the install, see here</p>
<p dir="auto"><a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/89053</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89053</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Mar 2021 13:28:08 GMT</pubDate></item></channel></rss>
