<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-assistant2display youtube video]]></title><description><![CDATA[<p dir="auto">Hello, I have a problem with MMM-assistant2display after the voice command they don’t display video.</p>
<p dir="auto"><img src="/assets/uploads/files/1614953539271-d374bc26-3ab4-47ac-802b-37239ed788c2-image.png" alt="d374bc26-3ab4-47ac-802b-37239ed788c2-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/14742/mmm-assistant2display-youtube-video</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 18:22:14 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14742.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Mar 2021 14:15:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-assistant2display youtube video on Fri, 05 Mar 2021 19:31:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I just reinstall Assistant2display</p>
]]></description><link>https://forum.magicmirror.builders/post/89167</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89167</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Fri, 05 Mar 2021 19:31:33 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-assistant2display youtube video on Fri, 05 Mar 2021 19:28:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> awesome. did u do anything different?</p>
]]></description><link>https://forum.magicmirror.builders/post/89166</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89166</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Mar 2021 19:28:06 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-assistant2display youtube video on Fri, 05 Mar 2021 19:12:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hello SAM thanks for your response I just reinstall the module it’s work</p>
]]></description><link>https://forum.magicmirror.builders/post/89165</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89165</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Fri, 05 Mar 2021 19:12:09 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-assistant2display youtube video on Fri, 05 Mar 2021 16:49:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a> no, sorry, no idea how the module works…</p>
]]></description><link>https://forum.magicmirror.builders/post/89162</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89162</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Mar 2021 16:49:51 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-assistant2display youtube video on Fri, 05 Mar 2021 16:22:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> can you troubleshoot with me please?</p>
]]></description><link>https://forum.magicmirror.builders/post/89161</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89161</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Fri, 05 Mar 2021 16:22:08 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-assistant2display youtube video on Fri, 05 Mar 2021 15:56:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanx for your reponse ,</p>
<p dir="auto">Yes, if you see in my script I’m using the MMM-googleassistant + Assistant2Display</p>
<p dir="auto"><img src="/assets/uploads/files/1614959777334-be993cb2-f551-4d2e-ad7c-760af1e5e0a4-image.png" alt="be993cb2-f551-4d2e-ad7c-760af1e5e0a4-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/89159</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89159</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Fri, 05 Mar 2021 15:56:19 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-assistant2display youtube video on Fri, 05 Mar 2021 17:30:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/youssef" aria-label="Profile: youssef">@<bdi>youssef</bdi></a></p>
<p dir="auto">~~assistant2display is no longer supported. the author left mm over a year ago.</p>
<p dir="auto">this has been replaced by MMM-GoogleAssistant and Assistant2Display, by bugsounet.~~</p>
<p dir="auto">he does support on his own forum</p>
<p dir="auto"><a href="https://bugsounet.forums.fr" target="_blank" rel="noopener noreferrer nofollow ugc">https://bugsounet.forums.fr</a></p>
]]></description><link>https://forum.magicmirror.builders/post/89156</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89156</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 05 Mar 2021 17:30:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-assistant2display youtube video on Fri, 05 Mar 2021 14:53:59 GMT]]></title><description><![CDATA[<p dir="auto">Configuration File :</p>
<pre><code>var config = {
	address: "localhost", 	// Address to listen on, can be:
electronOptions: {
         webPreferences : {
              webviewTag: true
	port: 8080,
	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
	language: "en",
	timeFormat: 24,
	units: "metric",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			header: "US Holidays",
						symbol: "calendar-check",
						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
			module: "compliments",
			position: "lower_third"
			module: "currentweather",
				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
				appid: "YOUR_OPENWEATHER_API_KEY"
			module: "weatherforecast",
			header: "Weather Forecast",
			module: "newsfeed",
			position: "bottom_bar",
				feeds: [
						title: "New York Times",
						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
				showSourceTitle: true,
				showPublishDate: true,
				broadcastNewsFeeds: true,
				broadcastNewsUpdates: true
  module: "MMM-GoogleAssistant",
  position: "fullscreen_above",
    debug: false,
    assistantConfig: {
      lang: "en-US",
      projectId: "", // Required to use gaction.
      modelId: "", // (OPTIONAL for gaction)
      instanceId: "", // (OPTIONAL for gaction)
      latitude: 51.508530,
      longitude: -0.076132,
    responseConfig: {
      useScreenOutput: true,
      screenOutputCSS: "screen_output.css",
      screenOutputTimer: 5000,
      screenRotate: false,
      activateDelay: 250,
      useAudioOutput: true,
      useChime: true,
      newChime: false,
      useNative: true,
      playProgram: "mpg321"
    micConfig: { // put there configuration generated by auto-installer
      recorder: "arecord",
      device: "plughw:0",
    snowboy: {
      useSnowboy: true,
      usePMDL: false,
      audioGain: 2.0,
      Frontend: true,
      Model: "jarvis",
      Sensitivity: null
    A2DServer: {
      useA2D: true,
      stopCommand: "stop",
      useYouTube: true,
      youtubeCommand: "youtube",
      displayResponse: true
    recipes: [ "with-MMM-TelegramBot.js" ],
    NPMCheck: {
      useChecker: true,
      delay: 10 * 60 * 1000,
      useAlert: true
  module: "MMM-Assistant2Display",
    debug:false,
    useYoutube: true,
    links: {
      useLinks: false,
      displayDelay: 60 * 1000,
      scrollStep: 25,
      scrollInterval: 1000,
      scrollStart: 5000,
      scrollActivate: false,
      verbose: false
    photos: {
      usePhotos: true,
      displayDelay: 10 * 1000
    volume: {
      useVolume: true,
      volumePreset: "ALSA",
      myScript: null
    briefToday: {
      useBriefToday: false,
      welcome: "brief Today"
    screen: {
      useScreen: false,
      delay: 5 * 60 * 1000,
      turnOffDisplay: true,
      mode: 1,
      ecoMode: true,
      displayCounter: true,
      displayBar: false,
      displayStyle: "Text",
      text: "Auto Turn Off Screen:",
      detectorSleeping: false,
      governorSleeping: false,
      displayLastPresence: true,
      LastPresenceText: "Last Presence:",
      delayed: 0
    touch: {
      useTouch: false,
      mode: 3
    pir: {
      usePir: false,
      gpio: 21,
      reverseValue: false
    governor: {
      useGovernor: false,
      sleeping: "powersave",
      working: "ondemand"
    internet: {
      useInternet: true,
      displayPing: false,
      delay: 2* 60 * 1000,
      scan: "google.fr",
      command: "pm2 restart 0",
      showAlert: true
    cast: {
      useCast: false,
      castName: "MagicMirror_A2D",
      port: 8569
    spotify: {
      useSpotify: false,
      useBottomBar: false,
      useLibrespot: false,
      connectTo: null,
      playDelay: 3000,
      minVolume: 10,
      maxVolume: 100,
      updateInterval: 1000,
      idleInterval: 10000,
      username: "",
      password: "",
      CLIENT_ID: "",
      CLIENT_SECRET: "",
      deviceDisplay: "Listening on",
      usePause: true,
      typeArtist: "artist",
      typePlaylist: "playlist",
      typeAlbum: "album",
      typeTrack: "track"
    NPMCheck: {
      useChecker: true,
      useAlert: true
]]></description><link>https://forum.magicmirror.builders/post/89155</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89155</guid><dc:creator><![CDATA[youssef]]></dc:creator><pubDate>Fri, 05 Mar 2021 14:53:59 GMT</pubDate></item></channel></rss>
