<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Got error when run MM 2.14.0]]></title><description><![CDATA[<p dir="auto">I’m installing a new fresh MM 2.14.0 using installation script . After everything seems OK through installation, but the MM is not loaded. MM and PM2 is installed successfully. When I tried to run manually, got the following error:</p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm run start
&gt; magicmirror@2.14.0 start /home/pi/MagicMirror
&gt; ./run-start.sh $1
./run-start.sh: line 41: [: too many arguments
[07.03.2021 16:04.29.213] [ERROR] App threw an error during load
[07.03.2021 16:04.29.233] [ERROR] Error: Cannot find module 'lodash'
Require stack:
- /home/pi/MagicMirror/node_modules/express-ipfilter/lib/ipfilter.js
- /home/pi/MagicMirror/node_modules/express-ipfilter/index.js
- /home/pi/MagicMirror/js/server.js
    at Module._resolveFilename (internal/modules/cjs/loader.js:798:15)
    at Function../lib/common/reset-search-paths.ts.Module._resolveFilename (electron/js2c/browser_init.js:7718:16)
    at Module._load (internal/modules/cjs/loader.js:691:27)
    at Function.Module._load (electron/js2c/asar.js:748:26)
    at Module.require (internal/modules/cjs/loader.js:853:19)
    at require (internal/modules/cjs/helpers.js:74:18)
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/node_modules/express-ipfilter/lib/ipfilter.js:12:11)
    at Module._compile (internal/modules/cjs/loader.js:968:30)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:986:10)
    at Module.load (internal/modules/cjs/loader.js:816:32)
A JavaScript error occurred in the main process
Uncaught Exception:
Require stack:
<p dir="auto">What’s wrong? Any one have the same/similar problem and already had the solution?<br />
Thx.</p>
]]></description><link>https://forum.magicmirror.builders/topic/14749/got-error-when-run-mm-2-14-0</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 21:09:12 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/14749.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 07 Mar 2021 09:17:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Thu, 11 Mar 2021 06:31:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/89276">Got error when run MM 2.14.0</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> fun…</p>
<p dir="auto">do</p>
<pre><code>cd ~
sudo rm -rf  .npm
rm -rf MagicMirror
<p dir="auto">note the dot in front of npm</p>
<p dir="auto">then run the install script again.</p>
<p dir="auto">It works like a charm. Thx a lot <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> .</p>
]]></description><link>https://forum.magicmirror.builders/post/89384</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89384</guid><dc:creator><![CDATA[slametps]]></dc:creator><pubDate>Thu, 11 Mar 2021 06:31:58 GMT</pubDate></item><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Sun, 07 Mar 2021 13:58:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> fun…</p>
<pre><code>cd ~
sudo rm -rf  .npm
rm -rf MagicMirror
]]></description><link>https://forum.magicmirror.builders/post/89276</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89276</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 07 Mar 2021 13:58:45 GMT</pubDate></item><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Sun, 07 Mar 2021 13:56:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/89272">Got error when run MM 2.14.0</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> ok, don’t know what happened… looks like u ran install 5 separate times…</p>
<p dir="auto">so lets do this</p>
<pre><code>cd ~/MagicMirror
rm  package-lock.json
rm -rf node_modules
npm install --only=prod
<p dir="auto">then try to start MM,</p>
<pre><code>npm start
<p dir="auto">I got the following error when execute<br />
<code>npm install --only=prod</code></p>
<pre><code>pi@raspberrypi:~/MagicMirror $ npm install --only=prod
npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning EINTEGRITY: sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== integrity checksum failed when using sha512: wanted sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
npm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
npm ERR! code EINTEGRITY
npm ERR! errno EINTEGRITY
npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/chai: sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== integrity checksum failed when using sha512: wanted sha512-zd8xmga7H8fqb09boh5SICtctwp4gI+dLMANKCXpdihRn/ggW2ZimSQo/H3cBcfzsjljTDoAiOPc6deEOSWKDw== but got sha512-z4PhNX7vuL3xVChQ1m2AB9Yg5AULVxXcg/SpIdNs6c5H0NE8XYXysP+DGNKHfuwvY7kxvUdBeoGlODJ6+SfaPg==. (0 bytes)
npm ERR!     /home/pi/.npm/_logs/2021-03-07T13_53_31_822Z-debug.log
]]></description><link>https://forum.magicmirror.builders/post/89275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89275</guid><dc:creator><![CDATA[slametps]]></dc:creator><pubDate>Sun, 07 Mar 2021 13:56:09 GMT</pubDate></item><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Sun, 07 Mar 2021 13:47:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/89272">Got error when run MM 2.14.0</a>:</p>
rm -rf node_modules
<p dir="auto">Yap, the installation has failed several times. I’ll try re-install as your direction.</p>
]]></description><link>https://forum.magicmirror.builders/post/89273</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89273</guid><dc:creator><![CDATA[slametps]]></dc:creator><pubDate>Sun, 07 Mar 2021 13:47:39 GMT</pubDate></item><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Sun, 07 Mar 2021 13:41:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> ok, don’t know what happened… looks like u ran install 5 separate times…</p>
rm -rf node_modules
]]></description><link>https://forum.magicmirror.builders/post/89272</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89272</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 07 Mar 2021 13:41:03 GMT</pubDate></item><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Sun, 07 Mar 2021 13:38:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> said in <a href="/post/89270">Got error when run MM 2.14.0</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> : no, it is a fresh install.<br />
<a href="https://drive.google.com/file/d/1aaCob5kI0fwp9sLUlgdf3iSvN5rT6jgj/view?usp=sharing" target="_blank" rel="noopener noreferrer nofollow ugc">Here is the link to install.log</a></p>
<p dir="auto">The raspberry is also a fresh install, I created the disk using Raspberry Pi Imager.</p>
]]></description><link>https://forum.magicmirror.builders/post/89271</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89271</guid><dc:creator><![CDATA[slametps]]></dc:creator><pubDate>Sun, 07 Mar 2021 13:38:24 GMT</pubDate></item><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Sun, 07 Mar 2021 13:35:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> : no, it is a fresh install.<br />
]]></description><link>https://forum.magicmirror.builders/post/89270</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89270</guid><dc:creator><![CDATA[slametps]]></dc:creator><pubDate>Sun, 07 Mar 2021 13:35:11 GMT</pubDate></item><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Sun, 07 Mar 2021 13:28:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> also, did u edit the config.js and change ipWhitelist at all?</p>
]]></description><link>https://forum.magicmirror.builders/post/89269</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89269</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 07 Mar 2021 13:28:27 GMT</pubDate></item><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Sun, 07 Mar 2021 13:21:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> to fix the <a href="http://run-start.sh" target="_blank" rel="noopener noreferrer nofollow ugc">run-start.sh</a> problem do</p>
curl  -sL  https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh &gt; run-start.sh</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/89268</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89268</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 07 Mar 2021 13:21:49 GMT</pubDate></item><item><title><![CDATA[Reply to Got error when run MM 2.14.0 on Sun, 07 Mar 2021 13:23:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> I will look at the run-start problem,<br />
but it appears install did not complete.</p>
<p dir="auto">can u post the ~/install.log file</p>
<p dir="auto">please use the code block markers<br />
select the text after lasting it, then push the button that looks like &lt; /&gt;</p>
]]></description><link>https://forum.magicmirror.builders/post/89266</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/89266</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 07 Mar 2021 13:23:54 GMT</pubDate></item></channel></rss>
